[mpich-discuss] romio large array
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Apr 26 09:57:16 CDT 2010
On Apr 26, 2010, at 9:38 AM, Rob Latham wrote:
> On Mon, Apr 26, 2010 at 08:05:41AM -0500, Dave Goodell wrote:
>> [adding RobL]
>> It looks like ROMIO is checking for reads of more data than INT_MAX
>> bytes in a single call.  I'm guessing that this is defensive because
>> some of the internal code in ROMIO may not be prepared to handle
>> this case.  Rob can probably comment with less speculation.
> that's exactly what's going on.
This is a stricter check than what the standard implies.  ROMIO is
checking that ((type_size*count)<=INT_MAX).  It really should only
need to check that (count<=INT_MAX) as long as all calculations are
internally handled with a larger (64-bit) type.  This would actually
permit the read in this user's instance.  Would it be hard to move to
the latter case?
> Dave, I don't know if the forum is still talking about the MPI_COUNT
> issue, but we get questions like this about once a year. People
> definitely try to read more than 2GB of data at a time.
It is under discussion.  But AFAIK all of the discussion is about how
to fix the "int count" parameters.
-Dave
