[mpich-discuss] mpdboot error
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Apr 23 14:17:43 CDT 2010
I doubt that the OS difference is causing this problem, although there
is always a small chance that it will cause _some_ problem.
You can try the fix listed, but you may still have a problem (the fix
for #963 is available in 1.2.1p1, but there is no fix currently for
#974).
In all cases, I still recommend hydra instead of mpd.
-Dave
On Apr 23, 2010, at 2:03 PM, Jacob Harvey wrote:
> We are running MPICH2-1.2.1 and CentOS 4.8 on the head node with
> CentOS 4.4 on all other nodes. Is the difference in operating systems
> a problem? I'm guessing no because we don't use the head node for
> calculations, but I figure I would ask. Otherwise it looks very
> similar to that bug. Similar to your findings I cannot reproduce this
> behavior on CentOS 5.4 which is running on on our other cluster that
> works just fine. Should I give the quick fix you list in the bug
> report a shot or was this fixed in mpich2-1.2.1p1?
> Jacob
> On Fri, Apr 23, 2010 at 2:47 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
>> What version of MPICH2 are you using?  What operating system are
>> you using
>> (CentOS/RHEL?)?  You may be hitting the bug linked from that FAQ
>> entry:
>> https://trac.mcs.anl.gov/projects/mpich2/ticket/974
>> -Dave
>> On Apr 23, 2010, at 1:42 PM, Jacob Harvey wrote:
>>> Dave,
>>> See that is the weird thing about this is that it seems as though
>>> the
>>> mpd ring is indeed forming. Its more simply that my script hangs on
>>> the line of mpdboot. But I can ssh to the nodes specified for the
>>> job
>>> and see the mpd process running on that node. So the mpd ring forms
>>> but why doesn't mpdboot give control back to the script?
>>> I'm definitely up for more suggestions if anyone has got any, but in
>>> the mean time I'll give hydra a shot. Thanks.
>>> Jacob
>>> On Fri, Apr 23, 2010 at 2:21 PM, Dave Goodell
>>> <goodell at mcs.anl.gov> wrote:
>>>> It's good to hear that it was just a bad mpdboot line.
>>>> As for your further troubles with mpd, please see this page:
>>>> http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions#Q
>>>> :_My_MPD_ring_won.27t_start.2C_what.27s_wrong.3F
>>>> Particularly, I would recommend using hydra if you don't
>>>> specifically
>>>> need
>>>> MPD.
>>>> -Dave
>>>> On Apr 23, 2010, at 1:15 PM, Jacob Harvey wrote:
>>>>> Dave and MPICH2 users,
>>>>> Thanks for your timely response. I did actually have an error in
>>>>> my
>>>>> invocation of mpdboot. I was missing a space on my mpdboot line
>>>>> (doh).
>>>>> ie. I had:
>>>>> mpdboot -n 2-f mpd.hosts
>>>>> But this has actually caused me to run into some other weird
>>>>> problems.
>>>>> I want to run on 2 nodes with 2 procs each (4 tot). But my PBS
>>>>> script
>>>>> seems to hang on booting the mpd ring. So for instance the main
>>>>> part
>>>>> of my PBS script looks like this ($NODES = 2):
>>>>> echo 'Building the MPD ring'
>>>>> $MPI_HOME/bin/mpdboot -n $NODES -f $PBS_NODEFILE -r ssh
>>>>> echo ' '
>>>>> echo 'Inspecting if all MPI nodes have been activated'
>>>>> $MPI_HOME/bin/mpdtrace -l
>>>>> echo ' '
>>>>> echo 'Checking the connectivity'
>>>>> $MPI_HOME/bin/mpdringtest 100
>>>>> echo ' '
>>>>> echo 'Running my code in parallel'
>>>>> echo ' '
>>>>> if [[ `uname -i` == "x86_64" ]]; then
>>>>>   mpirun -np 4 ~/dlpoly/dl_poly_2.20_i86/execute/DLPOLY.X
>>>>> else
>>>>>   mpirun -np 4 ~/dlpoly/dl_poly_2.20_i386/execute/DLPOLY.X
>>>>> fi
>>>>> Yet all I get is the 'Building the mpd ring' line with no further
>>>>> output (from either the PBS script or the program I am running)
>>>>> in my
>>>>> output file. But while the job is "running" I can ssh to the nodes
>>>>> involved in the mpd ring and can see the mpd ring running (either
>>>>> seeing the process in top, or mpdtrace -l). What seems to force
>>>>> mpdboot to move on is specifying more hosts than are available
>>>>> (ie.
>>>>> "mpdboot -n 4 -f mpd.hosts" when only 2 nodes are used). In that
>>>>> case
>>>>> I get the typical "Too many hosts" error but the mpd ring is
>>>>> formed
>>>>> and the job runs as expected. Like I said I've used this same
>>>>> script
>>>>> on another one of our clusters and it works just fine and I've
>>>>> gone
>>>>> through the troubleshooting section in the manual but did not
>>>>> find an
>>>>> error.
>>>>> Any suggestions on why the mpd ring is hanging?
>>>>> Jacob
>>>>> On Fri, Apr 23, 2010 at 1:16 PM, Dave Goodell
>>>>> wrote:
>>>>>> Hi Jacob,
>>>>>> Can you post your mpdboot invocation?  There is probably either a
>>>>>> mistake
>>>>>> in
>>>>>> that line or a bug in mpdboot.
>>>>>> -Dave
>>>>>> On Apr 23, 2010, at 11:41 AM, Jacob Harvey wrote:
>>>>>>> MPICH2 users,
>>>>>>> Has anyone seen this error from mpdboot before?
>>>>>>> Traceback (most recent call last):
>>>>>>>  File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 476, in ?
>>>>>>>  mpdboot()
>>>>>>>  File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 158, in mpdboot
>>>>>>>  totalnumToStart = int(argv[argidx+1])
>>>>>>> ValueError: invalid literal for int(): 2-f
>>>>>>> Its odd because I only get this error when I try to set up an
>>>>>>> mpd ring
>>>>>>> for calculations in a PBS script. But if I try to set up an
>>>>>>> mpd ring
>>>>>>> from the command line then the ring forms just fine. Plus I've
>>>>>>> gone
>>>>>>> through the debugging MPD rings in the manual and did not turn
>>>>>>> up any
>>>>>>> errors in doing so. Another puzzling piece of information is
>>>>>>> that I
>>>>>>> use the same exact PBS script on a different cluster and the
>>>>>>> mpd ring
>>>>>>> forms just fine. So I'm confused as to what is the problem
>>>>>>> here. Any
>>>>>>> thoughts? Thanks in advance!
>>>>>>> Jacob
>>>>>>> Jacob Harvey
>>>>>>> Graduate Student
>>>>>>> University of Massachusetts Amherst
>>>>>>> j.harv8 at gmail.com
>>>>>>> _______________________________________________
>>>>>>> mpich-discuss mailing list
>>>>>>> mpich-discuss at mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>> Jacob Harvey
>>>>> Graduate Student
>>> Jacob Harvey
>>> Graduate Student
> Jacob Harvey
> Graduate Student
