[mpich-discuss] mpdboot error
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Apr 23 13:47:17 CDT 2010
What version of MPICH2 are you using?  What operating system are you
using (CentOS/RHEL?)?  You may be hitting the bug linked from that FAQ
entry: https://trac.mcs.anl.gov/projects/mpich2/ticket/974
-Dave
On Apr 23, 2010, at 1:42 PM, Jacob Harvey wrote:
> Dave,
> See that is the weird thing about this is that it seems as though the
> mpd ring is indeed forming. Its more simply that my script hangs on
> the line of mpdboot. But I can ssh to the nodes specified for the job
> and see the mpd process running on that node. So the mpd ring forms
> but why doesn't mpdboot give control back to the script?
> I'm definitely up for more suggestions if anyone has got any, but in
> the mean time I'll give hydra a shot. Thanks.
> Jacob
> On Fri, Apr 23, 2010 at 2:21 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
>> It's good to hear that it was just a bad mpdboot line.
>> As for your further troubles with mpd, please see this page:
>> http://wiki.mcs.anl.gov/mpich2/index.php/
>> Frequently_Asked_Questions#Q:_My_MPD_ring_won.27t_start.2C_what.
>> 27s_wrong.3F
>> Particularly, I would recommend using hydra if you don't
>> specifically need
>> MPD.
>> -Dave
>> On Apr 23, 2010, at 1:15 PM, Jacob Harvey wrote:
>>> Dave and MPICH2 users,
>>> Thanks for your timely response. I did actually have an error in my
>>> invocation of mpdboot. I was missing a space on my mpdboot line
>>> (doh).
>>> ie. I had:
>>> mpdboot -n 2-f mpd.hosts
>>> But this has actually caused me to run into some other weird
>>> problems.
>>> I want to run on 2 nodes with 2 procs each (4 tot). But my PBS
>>> script
>>> seems to hang on booting the mpd ring. So for instance the main part
>>> of my PBS script looks like this ($NODES = 2):
>>> echo 'Building the MPD ring'
>>> $MPI_HOME/bin/mpdboot -n $NODES -f $PBS_NODEFILE -r ssh
>>> echo ' '
>>> echo 'Inspecting if all MPI nodes have been activated'
>>> $MPI_HOME/bin/mpdtrace -l
>>> echo ' '
>>> echo 'Checking the connectivity'
>>> $MPI_HOME/bin/mpdringtest 100
>>> echo ' '
>>> echo 'Running my code in parallel'
>>> echo ' '
>>> if [[ `uname -i` == "x86_64" ]]; then
>>>    mpirun -np 4 ~/dlpoly/dl_poly_2.20_i86/execute/DLPOLY.X
>>> else
>>>    mpirun -np 4 ~/dlpoly/dl_poly_2.20_i386/execute/DLPOLY.X
>>> fi
>>> Yet all I get is the 'Building the mpd ring' line with no further
>>> output (from either the PBS script or the program I am running) in
>>> my
>>> output file. But while the job is "running" I can ssh to the nodes
>>> involved in the mpd ring and can see the mpd ring running (either
>>> seeing the process in top, or mpdtrace -l). What seems to force
>>> mpdboot to move on is specifying more hosts than are available (ie.
>>> "mpdboot -n 4 -f mpd.hosts" when only 2 nodes are used). In that
>>> case
>>> I get the typical "Too many hosts" error but the mpd ring is formed
>>> and the job runs as expected. Like I said I've used this same script
>>> on another one of our clusters and it works just fine and I've gone
>>> through the troubleshooting section in the manual but did not find
>>> an
>>> error.
>>> Any suggestions on why the mpd ring is hanging?
>>> Jacob
>>> On Fri, Apr 23, 2010 at 1:16 PM, Dave Goodell
>>> <goodell at mcs.anl.gov> wrote:
>>>> Hi Jacob,
>>>> Can you post your mpdboot invocation?  There is probably either a
>>>> mistake
>>>> in
>>>> that line or a bug in mpdboot.
>>>> -Dave
>>>> On Apr 23, 2010, at 11:41 AM, Jacob Harvey wrote:
>>>>> MPICH2 users,
>>>>> Has anyone seen this error from mpdboot before?
>>>>> Traceback (most recent call last):
>>>>>  File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 476, in ?
>>>>>  mpdboot()
>>>>>  File "/opt/mpich2-1.2.1-i86/bin/mpdboot", line 158, in mpdboot
>>>>>  totalnumToStart = int(argv[argidx+1])
>>>>> ValueError: invalid literal for int(): 2-f
>>>>> Its odd because I only get this error when I try to set up an
>>>>> mpd ring
>>>>> for calculations in a PBS script. But if I try to set up an mpd
>>>>> ring
>>>>> from the command line then the ring forms just fine. Plus I've
>>>>> gone
>>>>> through the debugging MPD rings in the manual and did not turn
>>>>> up any
>>>>> errors in doing so. Another puzzling piece of information is
>>>>> that I
>>>>> use the same exact PBS script on a different cluster and the mpd
>>>>> ring
>>>>> forms just fine. So I'm confused as to what is the problem here.
>>>>> Any
>>>>> thoughts? Thanks in advance!
>>>>> Jacob
>>>>> Jacob Harvey
>>>>> Graduate Student
>>>>> University of Massachusetts Amherst
>>>>> j.harv8 at gmail.com
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> mpich-discuss at mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Jacob Harvey
>>> Graduate Student
> Jacob Harvey
> Graduate Student
