[mpich-discuss] Getting started in Win XP
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Thu Apr 22 14:44:20 CDT 2010
 Great! Please refer to the windows developer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-windevguide.pdf) in Section "Runtime Environment" --> "Firewalls" for information on how to use MPICH2 with firewalls.
 Let us know if you need any help.
Jayesh
----- Original Message -----
Cc: "Richard Hanson" <Richard.koolhans at gmail.com>, "Bruce Evans" <EvansBW at gmail.com>
Sent: Thursday, April 22, 2010 11:20:45 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Getting started in Win XP
To: Jayesh (mpich-discuss)
My two PC's are both 32 bit. I found that the firewall was ON on both PC's. I turned the firewall OFF on both PC's and the run worked just fine. I did not need to use IP numbers.
Thanks much for getting me to this point.
Is there a setting of the firewalls I can make that is not as drastic as turning them off completely? Is there a program name or port I can list as an "exception" in the firewall control window?
-- Chuck
On Thu, Apr 22, 2010 at 8:01 AM, < jayesh at mcs.anl.gov > wrote:
# Do the two machines have the same architecture (are they both 32-bit machines) ?
# Does "mpiexec -hosts 2 Issac 1 Gauss 1 hostname" work (It should just print the hostnames of the two machines)?
# Does "mpiexec -n 2 fpi.exe" work on both machines ?
# Do you have any firewall running on the machines ? If so, please try again after turning off the firewall.
# Also try specifying the ipaddresses of the machines instead of hostnames (mpiexec -hosts 2 IPADDRESS_OF_ISSAC 1 IPADDRESS_OF_GAUSS 1 fpi.exe). You can get the ipaddress by typing "ipconfig" at the command prompt.
Let us know the results.
Jayesh
To: "MPICH Discussion" < Mpich-discuss at mcs.anl.gov >
Cc: EvansBW at gmail.com
Sent: Wednesday, April 21, 2010 9:26:51 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Getting started in Win XP
I downloaded MPICH2 for Windows in Nov, 2009. I installed in on two PC's that I call Issac and Gauss that have access to my home wireless network. The installation file is mpich2-1.2-win-ia32.msi. Issac uses XP-Pro and Gauss uses XP-Home.
I purchased the Intel Fortran compiler, Vers 11.1, in July, 2009, for use on Issac, and I regularly use it there. I compiled the test case, fpi.f, on Issac. I (eventually) got a successful execution on a single PC by using the statement:
mpiexec -hosts 1 Issac 1 fpi.exe
I issued this command in a directory that contained mpiexec.exe and fpi.exe. I am the only user of this PC, and I do not use a password -- maybe I should say I have a blank password. Anyway the above command line didn't work initially because it asked for a password, and I didn't have one. I then set up a second User Name and gave it a password. Working under that User Name I again issued the above command line and I gave it the password when it asked for it, and it worked!! I was happy.
Moving on to try running this on my two PC's, I tried the command line:
mpiexec -hosts 2 Issac 1 Gauss 1 fpi.exe
I had Gauss running with a User Name that has a password (which may or may not have any bearing on the situation.)
This failed with the message:
launch failed: CreateProcess(fpi.exe) on 'Gauss' failed, error 2 - The system cannot find the file specified.
Then I tried giving fpi.exe a full path. I used:
mpiexec -hosts 2 Issac 1 Gauss 1 \\Issac\mpi\fpi.exe
That got further, but still not a complete execution. This responded with:
Process 0 of 2 is alive
Enter the number of intervals: (0 quits)
Process 1 of 2 is alive
I entered 50, but there was no response. I entered 0 and still no response, so I killed the run.
I added four Fortran write statements into the test case, fpi.f. Before and after the Call MPI_BCAST and before and after the Call MPI_REDUCE. Each write included the value of myid in the output. I recompiled that. I then tried the last command line above again. It responded with:
Proc 1 before call MPI_BCAST <= My debug write.
50 <= My entry from the keyboard.
Proc 0 before call MPI_BCAST <= My debug write.
and then just hung at that stage.
I conclude that fpi.exe is executing on both PC's, and on both PC's it has successfully gotten through calls to MPI_INIT, MPI_COMM_RANK and MPI_COMM_SIZE. The "print ... alive" statement functioned correctly on both PC's. Execution continued correctly up to the Call to MPI_BCAST. There it died. Why?
I will greatly apprciate suggestions as to how to get this test case to run correctly. I am well acquainted with Fortran programming, but not well acquainted with lower level operating system or networking components.
Hoping for help,
Chuck
mpich-discuss mailing list
