[mpich-discuss] Windows 7 Install problem- mpiexec errors
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Apr 20 09:04:11 CDT 2010
 Do you have a 32-bit or 64-bit version of windows installed in your system (You should use the corresponding version of MPICH2)?
 Can you also try if the nemesis channel works for you (mpiexec -n 2 -channel nemesis hostname)? Do you have any other MPI libraries installed in your machine (Try the full path
to the mpiexec command and see if it works, c:\progra~1\mpich2\bin\mpiexec -n 2 hostname)?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, April 19, 2010 7:01:54 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Windows 7 Install problem- mpiexec errors
Jayesh;
I wish I had better news, but after following your instructions to
de-install and re-install  MPICH2, and starting the daemon, mpiexec
still crashed immediately when started with:
   "mpiexec  -help2"
   or with any other option.
Any ideas??
Rich
>Hi,
>  Can you try running the mpiexec command from an administrator
>prompt (right-click on command prompt and select "Run as
>administrator") and see if it works ?
>  If not, uninstall MPICH2 on your machine. Open an administrator
>prompt (as mentioned above), run "msiexec /i
>mpich2-1.3a1-win-ia32.msi" to install MPICH2 on your machine. Let us
>know if it works.
>Regards,
>Jayesh
>From: "Richard Buck" <rmbuck at earthlink.net>
>To: mpich-discuss at mcs.anl.gov
>Sent: Monday, April 19, 2010 12:26:25 PM GMT -06:00 US/Canada Central
>Subject: [mpich-discuss] Windows 7 Install problem- mpiexec errors
>Folks;
>Following what looked like a good MPICH2 install on Windows 7  and
>starting the daemon with
>    :smpd -install"  successfully, I found that running mpiexec with
>any argument, such as :
>    "mpiexec  -help2"
>   gave the error message:
>   Fatal error in MPI_Init: Other MPI error, error stack:
>MPIR_Init_thread(394)........: Initialization failed
>MPID_Init(135)...............: channel initialization failed
>MPIDI_CH3_Init(35)...........:
>MPIDI_CH3I_Progress_init(309):
>MPIDU_Sock_listen(940).......: listen failed, An attempt was made to
>access a socket in a way
>   forbidden by its access permissions. (errno 10013)
>This happened with the distribution: mpich2-1.3a1-win-ia32.msi
>I did the install as an Administrator.
>Thanks for any help you can give.
>Rich
>_______________________________________________
>mpich-discuss mailing list
>https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
