[mpich-discuss] MPI_MINLOC for MPI_2DOUBLE_PRECISION
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Apr 19 13:07:42 CDT 2010
Ahh, I hadn't seen that known issue, thanks for sending it along.  It
sounds like you need to use a different version of the compiler,
either newer or older.  Or use a different compiler entirely.
-Dave
On Apr 19, 2010, at 1:19 PM, Fabricio Harter wrote:
> Dear Dave,
> I have found a web page with this hint:
> http://mail.cse.ohio-state.edu/pipermail/mvapich-discuss/2007-November/001254.html
> I am running ifort Version 10.0 !
> Attached to this e-mail there are configure.wrf, coppile.log,
> rsl.out.0000 and rsl.error.0000 files. I appreciate your help.
> Thanks in advance,
> Fabricio.
> 2010/4/16 Dave Goodell <goodell at mcs.anl.gov>
> Can you send us your config.log?  MPICH2 does generally support
> MPI_2DOUBLE_PRECISION for MINLOC/MAXLOC, but only when the C and
> Fortran compilers agree about certain things.  If we have your
> config.log it will help us determine why they aren't agreeing in
> your environment.
> -Dave
> On Apr 16, 2010, at 10:53 AM, Fabricio Harter wrote:
> Dear All,
> I built WRFVAR3.2 using MPICH2 on a cluster Dual-Core AMD
> Opteron(tm) Processor 2210 with Intel ifort compiler. The program
> builds, but when I run it reaches a point where MPI_Reduce aborts as
> the following message:
> DYNAMICS OPTION: Eulerian Mass Coordinate
>    alloc_space_field: domain            1,    105610432 bytes
> allocated
>  WRF TILE   1 IS      1 IE     45 JS      1 JE     30
>  WRF NUMBER OF TILES =   1
> [cli_0]: aborting job:
> Fatal error in MPI_Reduce: Invalid MPI_Op, error stack:
> MPI_Reduce(850).............: MPI_Reduce(sbuf=0x37420d8,
> rbuf=0x37420e8, count=1, MPI_2DOUBLE_PRECISION, MPI_MINLOC, root=0,
> comm=0x84000000) failed
> MPIR_MINLOC_check_dtype(215): MPI_Op MPI_MINLOC operation not
> defined for this datatype
> The MPI standards for both MPI 2.1 and MPI 2.2 state that MPI_Reduce
> are supported for that (p. 165 for 2.1 and p. 168 for 2.1)
> Is there a version of MPICH that actually support MPI_MINLOC for
> MPI_2DOUBLE_PREC ?
> Thanks in advance,
> Fabricio Harter.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
> <compile.log><configure.wrf><rsl.error.0000><rsl.out.
> 0000>_______________________________________________
