[mpich-discuss] Dual core problem
    jayesh at mcs.anl.gov
    Mon Apr 12 09:36:23 CDT 2010
 Please provide us the following logs,
# Stop any running instances of smpd using the command "smpd -stop".
# Start smpd in debug mode and collect the debug log using the command, "smpd -d > smpd.log"
# Launch your job in debug mode and collect the debug log using the command, "mpiexec -verbose -n 2 cpi.exe > mpiexec.log"
# Stop smpd in debug mode (Ctrl-C)
# restart smpd using the command, "smpd -start"
# Provide us with mpiexec.log and smpd.log (and any error output)
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, April 12, 2010 2:35:47 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Dual core problem
I am sure my version of windows is 32-bit, I installed it and I checked
it as well.
Is it possible to set that mpiexec (or smpd) is running only on one core?
Thanks
Ladislav Huraj
Jayesh Krishna  wrote / napísal(a):
> Hi,
>  Are you sure that you have 32-bit version of XP (and not 64-bit) installed in your system ?
> (PS: AFAIK, Core 2 duos support both 32-bit and 64-bit versions of windows)
> Regards,
> Jayesh
> From: huraj at ucm.sk
> To: jayesh at mcs.anl.gov
> Sent: Saturday, April 10, 2010 2:04:13 PM GMT -06:00 US/Canada Central
> Hi,
>> 1) Uninstall MPICH2 on your machine.
>> 2) Install mpich2-1.2.1p1 on your machine (Make sure that your OS is
> 32-bit before installing 32-bit version of MPICH2 - Start->Control
> Panel->System)
> This did not help, the same results.
>> 3) Re-compile C:\program files\mpich2\examples\icpi.c (cpi.vcproj)
> Done
>> 4) Run "smpd -status" to get the status of smpd
> "smpd running on oo7note"
> oo7note is name of my notebook
>> 5) Try running cpi.exe as "c:\progra~1\mpich2\bin\mpiexec.exe -n 2
> c:\progra~1\mpich2\examples\cpi.exe"
> Unfortunately, the same results like before; only in one of 6 cases the
> program runs correctly.
>> 6) Run "smpd -version" to get the version of the process manager.
> "1.2.1p1"
>> 7) Type "winver" at the command prompt to get the complete version of
> your OS.
> "Microsoft Windows
> Version 5.1 Service Pack 3 (2600.xpsp_sp3_gdr.091208-2036)"
> I do not know what else I could try.
> Regards,
> Ladislav
>> Hi,
>>  I would recommend the following (To make sure that you installation is
>> fine),
>> Panel->System)
>> 7) Type "winver" at the command prompt to get the complete version of your
>> OS.
>>  Let us know the results. Please provide as much details as possible (The
>> more details you provide the easier it is for us to debug your problem).
>> Regards,
>> Jayesh
>> Cc: "Ladislav Huraj" <ladislav.huraj at ucm.sk>, mpich-discuss at mcs.anl.gov
>> Sent: Friday, April 9, 2010 2:19:55 PM GMT -06:00 US/Canada Central
>> Hi,
>> cpi does not work (or 1/6 that it works)
>> "mpiexec -n 3 hello.exe" does not work (the same probability)
>> "mpiexec -n 1 hostname" works perfectly (it works without problems for
>> each n), it is the first one without problems
>> it seems that the higher number n, the lower probability of correct output
>> Ladislav
>>>  Please provide us more details. Can you run cpi ? Can you run "mpiexec
>>> -n
>>> 3 hello.exe" ? Can you run "mpiexec -n 1 hostname" ?
>>> -Jayesh
>>> From: "Ladislav Huraj" <ladislav.huraj at ucm.sk>
>>> Sent: Friday, April 9, 2010 11:41:55 AM GMT -06:00 US/Canada Central
>>> Unfortunately it does not work
>>> BR,
>>> Ladislav
>>> Jayesh Krishna  wrote / nap�sal(a):
>>>> Hi,
>>>>  Can you cpi (c:\program files\mpich2\examples\cpi.exe) on your
>>>> notebook
>>>>  Does "mpiexec -n 3 hello.exe" work for you (mpiexec launches all procs
>>>> on the localhost by default)?
>>>> Regards,
>>>> Jayesh
>>>> To: mpich-discuss at mcs.anl.gov
>>>> Sent: Friday, April 9, 2010 6:24:05 AM GMT -06:00 US/Canada Central
>>>> My version is 1.2.1p1. I have already tried the older as well as newer
>>>> versions of mpich2 but without success.
>>>> For job I use e.g.:
>>>> mpiexec –hosts 3 localhost localhost localhost hello.exe
>>>> this one works perfectly with the MPI code on my other PC.
>>>> I tried lots of others options which are correct (I always checked the
>>>> correctness on my other PC). From this I deducted that problem seems to
>>>> be
>>>> in notebook not in the code. Funny is that in one of 4 cases the
>>>> outputs
>>>> are correct.
>>>> My OS is 32bit WinXP Professional SP3, it is notebook HP Intel Core2
>>>> Duo
>>>> CP.
>>>>> Hi,
>>>>>  Which version of MPICH2 are you using (If you are using an older
>>>>> version
>>>>> try the latest stable version and see if it helps -
>>>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
>>>>>  How are you running your job (mpiexec options)?
>>>>>  Is your machine 32-bit or 64-bit ?
>>>>> Regards,
>>>>> Jayesh
>>>>> Sent: Friday, April 9, 2010 2:40:31 AM GMT -06:00 US/Canada Central
>>>>> Subject: [mpich-discuss] Dual core problem
>>>>> When I run the MPI program the outputs are different. Sometimes the
>>>>> output
>>>>> is correct, sometimes I obtain error message and sometimes job
>>>>> aborting.
>>>>> See the outputs:
>>>>> [01:4088]......ERROR:result command received but the wait_list is
>>>>> empty.
>>>>> [01:4088]....ERROR:unable to handle the command: "cmd=result src=1
>>>>> dest=1
>>>>> tag=5 cmd_tag=2 cmd_orig=dbput ctx_key=1 result=DBS_SUCCESS "
>>>>> [01:4088]...ERROR:sock_op_close returned while unknown context is in
>>>>> state: SMPD_IDLE
>>>>> [01:2392]......ERROR:result command received but the wait_list is
>>>>> empty.
>>>>> [01:2392]....ERROR:unable to handle the command: "cmd=result src=1
>>>>> dest=1
>>>>> tag=9 cmd_tag=2 cmd_orig=dbput ctx_key=2 result=DBS_SUCCESS "
>>>>> [01:2392]...ERROR:sock_op_close returned while unknown context is in
>>>>> state: SMPD_IDLE
>>>>> or
>>>>> [01:1452]......ERROR:result command received but the wait_list is
>>>>> empty.
>>>>> [01:1452]....ERROR:unable to handle the command: "cmd=result src=1
>>>>> dest=1
>>>>> tag=4 cmd_tag=1 cmd_orig=dbget ctx_key=0 result=DBS_FAIL "
>>>>> job aborted:
>>>>> rank: node: exit code[: error message]
>>>>> 0: localhost: 123
>>>>> 1: localhost: 123
>>>>> 2: localhost: -1073741819: process 2 exited without calling finalize
>>>>> or correctly
>>>>> Received: Hello, world from process 1!
>>>>> Received: Hello, world from process 2!
>>>>> MASTER: All Done!
>>>>> The program code is correct; it runs well on different PC.
>>>>> I am afraid the problem is in my notebook. The notebook is Intel Core2
>>>>> Duo
>>>>> CPU.
>>>>> I tried to change the setting ‘hosts’ in wmpiconfig (to
>>>>> localhost:2) for dual core but nothing has changed.
>>>>> I need it only for local using.
>>>>> Thanks
>>>>> Ladislav
>>>>> __________ Information from ESET Mail Security, version of virus
>>>>> signature
>>>>> database 5012 (20100409) __________
>>>>> The message was checked by ESET Mail Security.
>>>>> http://www.eset.com
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>> signature
>>>>> http://www.eset.com
>>>> signature database 5012 (20100409) __________
>>>> http://www.eset.com
>>>> signature database 5013 (20100409) __________
>>>> http://www.eset.com
>>> signature
>>> http://www.eset.com
>>> signature
>>> database 5014 (20100409) __________
>>> http://www.eset.com
>> __________ Information from ESET Mail Security, version of virus signature
>> http://www.eset.com
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature database 5016 (20100410) __________
> http://www.eset.com
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 5019 (20100412) __________
http://www.eset.com
