[mpich-discuss] Dual core problem
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Sat Apr 10 17:55:33 CDT 2010
 Are you sure that you have 32-bit version of XP (and not 64-bit) installed in your system ?
(PS: AFAIK, Core 2 duos support both 32-bit and 64-bit versions of windows)
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Saturday, April 10, 2010 2:04:13 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Dual core problem
>1) Uninstall MPICH2 on your machine.
>2) Install mpich2-1.2.1p1 on your machine (Make sure that your OS is
32-bit before installing 32-bit version of MPICH2 - Start->Control
Panel->System)
This did not help, the same results.
>3) Re-compile C:\program files\mpich2\examples\icpi.c (cpi.vcproj)
Done
>4) Run "smpd -status" to get the status of smpd
"smpd running on oo7note"
oo7note is name of my notebook
>5) Try running cpi.exe as "c:\progra~1\mpich2\bin\mpiexec.exe -n 2
c:\progra~1\mpich2\examples\cpi.exe"
Unfortunately, the same results like before; only in one of 6 cases the
program runs correctly.
>6) Run "smpd -version" to get the version of the process manager.
"1.2.1p1"
>7) Type "winver" at the command prompt to get the complete version of
your OS.
"Microsoft Windows
Version 5.1 Service Pack 3 (2600.xpsp_sp3_gdr.091208-2036)"
I do not know what else I could try.
Ladislav
> Hi,
>  I would recommend the following (To make sure that you installation is
> fine),
> Panel->System)
> 7) Type "winver" at the command prompt to get the complete version of your
> OS.
>  Let us know the results. Please provide as much details as possible (The
> more details you provide the easier it is for us to debug your problem).
> Regards,
> Jayesh
> From: huraj at ucm.sk
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: "Ladislav Huraj" <ladislav.huraj at ucm.sk>, mpich-discuss at mcs.anl.gov
> Sent: Friday, April 9, 2010 2:19:55 PM GMT -06:00 US/Canada Central
> Hi,
> cpi does not work (or 1/6 that it works)
> "mpiexec -n 3 hello.exe" does not work (the same probability)
> "mpiexec -n 1 hostname" works perfectly (it works without problems for
> each n), it is the first one without problems
> it seems that the higher number n, the lower probability of correct output
> Ladislav
>>  Please provide us more details. Can you run cpi ? Can you run "mpiexec
>> -n
>> 3 hello.exe" ? Can you run "mpiexec -n 1 hostname" ?
>> -Jayesh
>> From: "Ladislav Huraj" <ladislav.huraj at ucm.sk>
>> Sent: Friday, April 9, 2010 11:41:55 AM GMT -06:00 US/Canada Central
>> Unfortunately it does not work
>> BR,
>> Ladislav
>> Jayesh Krishna  wrote / nap�sal(a):
>>> Hi,
>>>  Can you cpi (c:\program files\mpich2\examples\cpi.exe) on your
>>> notebook
>>>  Does "mpiexec -n 3 hello.exe" work for you (mpiexec launches all procs
>>> on the localhost by default)?
>>> Regards,
>>> Jayesh
>>> To: mpich-discuss at mcs.anl.gov
>>> Sent: Friday, April 9, 2010 6:24:05 AM GMT -06:00 US/Canada Central
>>> My version is 1.2.1p1. I have already tried the older as well as newer
>>> versions of mpich2 but without success.
>>> For job I use e.g.:
>>> mpiexec –hosts 3 localhost localhost localhost hello.exe
>>> this one works perfectly with the MPI code on my other PC.
>>> I tried lots of others options which are correct (I always checked the
>>> correctness on my other PC). From this I deducted that problem seems to
>>> be
>>> in notebook not in the code. Funny is that in one of 4 cases the
>>> outputs
>>> are correct.
>>> My OS is 32bit WinXP Professional SP3, it is notebook HP Intel Core2
>>> Duo
>>> CP.
>>>> Hi,
>>>>  Which version of MPICH2 are you using (If you are using an older
>>>> version
>>>> try the latest stable version and see if it helps -
>>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
>>>>  How are you running your job (mpiexec options)?
>>>>  Is your machine 32-bit or 64-bit ?
>>>> Regards,
>>>> Jayesh
>>>> Sent: Friday, April 9, 2010 2:40:31 AM GMT -06:00 US/Canada Central
>>>> Subject: [mpich-discuss] Dual core problem
>>>> When I run the MPI program the outputs are different. Sometimes the
>>>> output
>>>> is correct, sometimes I obtain error message and sometimes job
>>>> aborting.
>>>> See the outputs:
>>>> [01:4088]......ERROR:result command received but the wait_list is
>>>> empty.
>>>> [01:4088]....ERROR:unable to handle the command: "cmd=result src=1
>>>> dest=1
>>>> tag=5 cmd_tag=2 cmd_orig=dbput ctx_key=1 result=DBS_SUCCESS "
>>>> [01:4088]...ERROR:sock_op_close returned while unknown context is in
>>>> state: SMPD_IDLE
>>>> [01:2392]......ERROR:result command received but the wait_list is
>>>> empty.
>>>> [01:2392]....ERROR:unable to handle the command: "cmd=result src=1
>>>> dest=1
>>>> tag=9 cmd_tag=2 cmd_orig=dbput ctx_key=2 result=DBS_SUCCESS "
>>>> [01:2392]...ERROR:sock_op_close returned while unknown context is in
>>>> state: SMPD_IDLE
>>>> or
>>>> [01:1452]......ERROR:result command received but the wait_list is
>>>> empty.
>>>> [01:1452]....ERROR:unable to handle the command: "cmd=result src=1
>>>> dest=1
>>>> tag=4 cmd_tag=1 cmd_orig=dbget ctx_key=0 result=DBS_FAIL "
>>>> job aborted:
>>>> rank: node: exit code[: error message]
>>>> 0: localhost: 123
>>>> 1: localhost: 123
>>>> 2: localhost: -1073741819: process 2 exited without calling finalize
>>>> or correctly
>>>> Received: Hello, world from process 1!
>>>> Received: Hello, world from process 2!
>>>> MASTER: All Done!
>>>> The program code is correct; it runs well on different PC.
>>>> I am afraid the problem is in my notebook. The notebook is Intel Core2
>>>> Duo
>>>> CPU.
>>>> I tried to change the setting ‘hosts’ in wmpiconfig (to
>>>> localhost:2) for dual core but nothing has changed.
>>>> I need it only for local using.
>>>> Thanks
>>>> Ladislav
>>>> __________ Information from ESET Mail Security, version of virus
>>>> signature
>>>> database 5012 (20100409) __________
>>>> The message was checked by ESET Mail Security.
>>>> http://www.eset.com
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>> signature
>>>> http://www.eset.com
>>> signature database 5012 (20100409) __________
>>> http://www.eset.com
>>> signature database 5013 (20100409) __________
>>> http://www.eset.com
>> signature
>> http://www.eset.com
>> signature
>> database 5014 (20100409) __________
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 5016 (20100410) __________
http://www.eset.com
