[mpich-discuss] Dual core problem
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Apr  9 09:14:31 CDT 2010
 Can you cpi (c:\program files\mpich2\examples\cpi.exe) on your notebook ?
 Does "mpiexec -n 3 hello.exe" work for you (mpiexec launches all procs on the localhost by default)?
Jayesh
----- Original Message -----
Sent: Friday, April 9, 2010 6:24:05 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Dual core problem
My version is 1.2.1p1. I have already tried the older as well as newer
versions of mpich2 but without success.
For job I use e.g.:
mpiexec –hosts 3 localhost localhost localhost hello.exe
this one works perfectly with the MPI code on my other PC.
I tried lots of others options which are correct (I always checked the
correctness on my other PC). From this I deducted that problem seems to be
in notebook not in the code. Funny is that in one of 4 cases the outputs
are correct.
My OS is 32bit WinXP Professional SP3, it is notebook HP Intel Core2 Duo CP.
> Hi,
>  Which version of MPICH2 are you using (If you are using an older version
> try the latest stable version and see if it helps -
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
>  How are you running your job (mpiexec options)?
>  Is your machine 32-bit or 64-bit ?
> Regards,
> Jayesh
> From: huraj at ucm.sk
> Sent: Friday, April 9, 2010 2:40:31 AM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] Dual core problem
> When I run the MPI program the outputs are different. Sometimes the output
> is correct, sometimes I obtain error message and sometimes job aborting.
> See the outputs:
> [01:4088]......ERROR:result command received but the wait_list is empty.
> [01:4088]....ERROR:unable to handle the command: "cmd=result src=1 dest=1
> tag=5 cmd_tag=2 cmd_orig=dbput ctx_key=1 result=DBS_SUCCESS "
> [01:4088]...ERROR:sock_op_close returned while unknown context is in
> state: SMPD_IDLE
> [01:2392]......ERROR:result command received but the wait_list is empty.
> [01:2392]....ERROR:unable to handle the command: "cmd=result src=1 dest=1
> tag=9 cmd_tag=2 cmd_orig=dbput ctx_key=2 result=DBS_SUCCESS "
> [01:2392]...ERROR:sock_op_close returned while unknown context is in
> state: SMPD_IDLE
> or
> [01:1452]......ERROR:result command received but the wait_list is empty.
> [01:1452]....ERROR:unable to handle the command: "cmd=result src=1 dest=1
> tag=4 cmd_tag=1 cmd_orig=dbget ctx_key=0 result=DBS_FAIL "
> job aborted:
> rank: node: exit code[: error message]
> 0: localhost: 123
> 1: localhost: 123
> 2: localhost: -1073741819: process 2 exited without calling finalize
> or correctly
> Received: Hello, world from process 1!
> Received: Hello, world from process 2!
> MASTER: All Done!
> The program code is correct; it runs well on different PC.
> I am afraid the problem is in my notebook. The notebook is Intel Core2 Duo
> CPU.
> I tried to change the setting ‘hosts’ in wmpiconfig (to
> localhost:2) for dual core but nothing has changed.
> I need it only for local using.
> Thanks
> Ladislav
> __________ Information from ESET Mail Security, version of virus signature
> database 5012 (20100409) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> mpich-discuss mailing list
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 5012 (20100409) __________
http://www.eset.com
