[mpich-discuss] Problem with .mpd.conf and Condor
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Apr  7 19:47:05 CDT 2010
Can you have Condor treat .mpd.conf as an input file needed by your
program and hence have it copied over to the machine where your program
will run? You can try setting the environment variable HOME to the
directory where .mpd.conf is located.
If that doesn't work, you could use the hydra process manager that
doesn't need the .mpd.conf file. It should be built by default in MPICH2
1.2.1p1 and available by running with mpiexec.hydra. You can also build
MPICH2 with --with-pm=hydra and then use mpiexec directly. Also see
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Milad
> Fatenejad
> Sent: Wednesday, April 07, 2010 6:36 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Problem with .mpd.conf and Condor
> Hello:
> I am trying to run my code on some computers that are using Condor as
> a job scheduler. The computers being used have dual quad-core
> processors - so I can run with a maximum of eight processes. The
> system relies on the fact that all of the files you need for your job
> will be in your run directory. There is no mpd running on the system,
> so I have to start mpd for each run. Right now I have a script that is
> executed by condor which:
> 1. Starts mpd
> 2. Runs my program
> 3. Kills mpd
> This actually does work, except for the fact that mpd is looking in my
> home directory for .mpd.conf...and with Condor the job may be run on
> some random computer where I don't have an account and there is no mpd
> running. Is there a way of specifying the location of .mpd.conf to mpd
> so I can get around this problem? I read about "gforker" in the manual
> - is this something that would be more appropriate for how I am trying
> to use mpich?
> I am a little new to this, so I am sorry if my question is unclear...
> Thank You
> Milad Fatenejad
> mpich-discuss mailing list
