[mpich-discuss] specifying machinefile for MPI_Comm_spawn
    Jitendra Kumar
    jkumar at ncsu.edu
    Wed Apr  7 11:29:46 CDT 2010
I would appreciate your help with a doubt using MPI_Comm_spawn.
  In order to specify the target hosts for spawning new child processes
through MPI_Comm_spawn call, what is correct "key" value that needs to
be set in MPI_Info.
Normally I always specify the hosts to start the MPI processes, by
passing the argument '-machinefile'
mpiexec -machinefile mf -n np ./program
However, passing machinefile key through MPI_Info in MPI_Comm_spawn
seems to have no effect.
MPI_Info_set(hostinfo, "machinefile", "mf")
The spawned processes are getting started on arbitrary nodes on the
cluster.
I tried to set the key "host" through MPI_Info_set(hostinfo, "host",
"node2") and it works. But this way I can specify only single host, and
is a problem if I am starting MPI_Comm_spawn with large number of
processors and wants to have control on where they are started.
I believe I am missing the correct key to set for MPI_Info for passing
the machinefile. Would be a great help if you can provide some pointers.
Jitu
Jitendra Kumar
Doctoral Student
Department of Civil, Construction and Environmental Engineering
North Carolina State University
Raleigh, NC 27695
jkumar at ncsu.edu
http://www4.ncsu.edu/~jkumar
