[mpich-discuss] How to use MPI_TYPE_CREATE_F90_REAL
Jilong Yin yinjilong at gmail.com
Mon Apr 5 22:58:33 CDT 2010
Thank you, Dave and Rajeey.
It seems I have to try other temporary methods.
2010/4/6 Dave Goodell <goodell at mcs.anl.gov>
> I think Rajeev is right, this is a bug in MPICH2.  But the good news is
> that it should be safe to call MPI_TYPE_COMMIT on the unnamed predefined
> types, which would get you un-stuck for the moment.
> -Dave
> On Apr 5, 2010, at 10:41 PM, Rajeev Thakur wrote:
>  Looks like this is a bug in MPICH2. It is saying that the datatype is not
>> committed, whereas the datatype returned by type_create_f90_real is a
>> predefined datatype that does not need to be committed. I have filed a bug
>> report. You can try it here:
>> https://trac.mcs.anl.gov/projects/mpich2/ticket/1028
>> Rajeev
>> From: mpich-discuss-bounces at mcs.anl.gov [mailto:
>> mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jilong Yin
>> Sent: Monday, April 05, 2010 10:24 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] How to use MPI_TYPE_CREATE_F90_REAL
>> Hello, everyone
>>  I am modifying my program to be used in user-specified real precision
>> such as single/double/quad precision.
>>  I use Fortran (Intel fortran)
>>  But when I make the following test program, it failed and reported as
>> this,.
>> Fatal error in PMPI_Bcast: Invalid datatype, error stack:
>> PMPI_Bcast(1301): MPI_Bcast(buf=0012FEE8, count=1, dtype=USER<f90_real>,
>> root=0
>>  MPI_COMM_WORLD) failed
>> PMPI_Bcast(1252): Datatype has not been committed
>>  I searched the web but can find little about this
>> MPI_TYPE_CREATE_F90_REAL,
>> Anyone can help me out?
>> Thank you.
>> ccccccccccccccccccccccccccccccccccccccccc
>>      PROGRAM TEST
>>    IMPLICIT NONE
>>    INCLUDE "MPIF.h"
>> C Define real type in different precision
>>      INTEGER,PARAMETER::SP=SELECTED_REAL_KIND(6,37)
>>    INTEGER,PARAMETER::DP=SELECTED_REAL_KIND(15,307)
>>      INTEGER,PARAMETER::QP=SELECTED_REAL_KIND(33,4931)
>>    INTEGER MYID,NUM_PROCS,IERR
>> C MPI REAL DATA TYPE
>>      INTEGER MPI_REAL_SP,MPI_REAL_DP,MPI_REAL_QP
>>    REAL(KIND=SP)::s
>>    REAL(KIND=DP)::d
>>    REAL(KIND=QP)::q
>> C Initialize MPI enviroment
>>      CALL MPI_INIT(IERR)
>> C get my Rank ID
>>      CALL MPI_COMM_RANK(MPI_COMM_WORLD,MYID,IERR)
>> C get the number of procs
>>      CALL MPI_COMM_SIZE(MPI_COMM_WORLD,NUM_PROCS,IERR)
>> C Output the precision and range for each real type
>>      WRITE(6,10)PRECISION(1.0_SP),RANGE(1.0_SP),
>>     &           PRECISION(1.0_DP),RANGE(1.0_DP),
>>     &           PRECISION(1.0_QP),RANGE(1.0_QP)
>> C Define MPI REAL Type
>>      CALL MPI_TYPE_CREATE_F90_REAL(6,MPI_UNDEFINED,MPI_REAL_SP,IERR)
>>      CALL MPI_TYPE_CREATE_F90_REAL(15,MPI_UNDEFINED,MPI_REAL_DP,IERR)
>>      CALL MPI_TYPE_CREATE_F90_REAL(33,MPI_UNDEFINED,MPI_REAL_QP,IERR)
>> c test real type
>>      IF(MYID.EQ.0) THEN
>>        s=1.0_SP
>>      d=2.0_DP
>>      q=3.0_QP
>>    END IF
>> c broadcast the above 3 values from master node
>>      CALL MPI_BCAST(s,1,MPI_REAL_SP,0,MPI_COMM_WORLD,IERR)
>>      CALL MPI_BCAST(d,1,MPI_REAL_DP,0,MPI_COMM_WORLD,IERR)
>>      CALL MPI_BCAST(q,1,MPI_REAL_QP,0,MPI_COMM_WORLD,IERR)
>> C output the result
>>      PRINT*,'MyID=',MYID,' s=',s,' d=',d,' q=',q
>> C finish the mpi enviroment
>>      CALL MPI_FINALIZE(IERR)
>>      STOP
>> 10    FORMAT('REAL PRECISION: SP(',I2,',',I4,')',1X,
>>     &                       'DP(',I2,',',I4,')',1X,
>>     &                       'QP(',I2,',',I4,')')
>>      END
>> cccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100406/2f52b114/attachment.htm>
