[mpich-discuss] MPI_Comm_spawn_multiple() fails
    Bakkal, Alex
    Abakkal at LOANPERFORMANCE.com
    Mon Apr  5 12:27:00 CDT 2010
Nope. Screen output:
-----Original Message-----
mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Monday, April 05, 2010 10:17 AM
To: Bakkal, Alex
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPI_Comm_spawn_multiple() fails
 Does it work if you launch it using mpiexec (mpiexec -n 1
mpi_spawn.exe)?
Jayesh
----- Original Message -----
From: "Alex Bakkal" <Abakkal at LOANPERFORMANCE.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, April 5, 2010 12:02:13 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] MPI_Comm_spawn_multiple() fails
The mpi_spawn.cpp is attached. I am calling my app directly:
D:\Projects\mpi_spawn\Release>mpi_spawn.exe
Thank you for your help.
Alex
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Monday, April 05, 2010 7:16 AM
To: Bakkal, Alex
 Can you send us the modified test program (attach it in your email) ?
Also let us know how you ran the test (the complete mpiexec command).
Jayesh
Sent: Friday, April 2, 2010 7:22:21 PM GMT -06:00 US/Canada Central
I am very sorry for misleading you in my previous response. The app does
NOT run with
char * progs[NHOST] = { "c:\\mpi_spawn" , "c:\\mpi_spawn" };
It hangs but at least it spawned two instances of mpi_spawn.exe
Sent: Friday, April 02, 2010 3:20 PM
To: Bakkal, Alex
 Does,
 work for you ?
Jayesh
Sent: Friday, April 2, 2010 4:04:11 PM GMT -06:00 US/Canada Central
Yes, spawning one instance (if you mean that by single program) works
fine but spawning two instances of the same program (even located in two
separate folders) hangs.
char * progs[NHOST] = { "c:\\mpi_spawn" , "c:\\tm\\mpi_spawn" };
Thank you.
Alex
Sent: Friday, April 02, 2010 1:59 PM
To: Bakkal, Alex
 I tried spawn() with the host info set to "localhost" and it worked
fine for me (However I spawned using a single program. Does that work
for you ?).
Jayesh
To: jayesh at mcs.anl.gov, mpich-discuss at mcs.anl.gov
Sent: Friday, April 2, 2010 3:24:21 PM GMT -06:00 US/Canada Central
Hi Jayesh,
Thank you for response. My test app, as well as the examples that you
have referred me to, works fine locally until I attempt to set "host"
key in MPI_Info. Unfortunately, I need that key in order to spawn
remotely. That is my ultimate goal.
Thank you anyway.
Alex
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Friday, April 02, 2010 8:07 AM
Cc: Bakkal, Alex
 Couple of suggestions,
# Does it work if you use the same command (same program) for all
instances of the spawned procs ?
# Did you try setting the "path" infos for the commands ?
 You can find some examples at
https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/test/mpi/spawn (Look at
spawnminfo1.c) . Let us know the results.
Jayesh
Sent: Thursday, April 1, 2010 4:58:07 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] MPI_Comm_spawn_multiple() fails
Hello,
I have installed MPICH2 v.1.2.1 on Windows XP Pro machines and was
trying to run the following test app on "mt" channel:
#define NHOST 2
int main( int argc, char * argv[]) {
int supported;
int rank, size;
MPI_Comm parent, intercomm;
MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &supported);
if (supported != MPI_THREAD_MULTIPLE){
printf( "The library does not support MPI_THREAD_MULTIPLE\n" );
exit(-1);
MPI_Comm_get_parent(&parent);
if (parent == MPI_COMM_NULL){
int i;
int nproc[NHOST] = {1 , 1 };
MPI_Info infos[NHOST];
for (i=0; i < NHOST; i++) {
MPI_Info_create(&infos[i]);
MPI_Info_set(infos[i], "host" , "localhost" );
MPI_Comm_spawn_multiple(NHOST,
progs, MPI_ARGVS_NULL, nproc, infos,
0, MPI_COMM_WORLD, &intercomm, MPI_ERRCODES_IGNORE);
MPI_Info_free(&infos[i]);
else {
intercomm = parent;
MPI_Comm_rank(intercomm, &rank);
MPI_Comm_size(intercomm, &size);
printf( "[%d/%d] Hello world\n" , rank, size); fflush(stdout);
MPI_Comm_free(&intercomm);
MPI_Finalize();
return 0;
The app hangs. I can see three (as expected) instances of the program in
the Task Manager but MPI_Comm_spawn_multiple() never returns control to
my app.
I have reduced the number of spawned hosts to one and it ran
successfully. Also, it spawned successfully two hosts with the following
line commented out:
//MPI_Info_set(infos[i], "host" , "localhost" );
I have tried it on two machines with the same result.
Also, I have tried to spawn just one instance but on the remote host and
got the following error messages:
ERROR:unable to read the cmd header on the pmi context, Error = -1
ERROR:Error posting ready, An existing connection was forcibly closed by
the remote host.
I am not sure whether that is related to the first issue?
Any insight would be greately appreciated.
Thank you.
Alex
This message may contain confidential or proprietary information
intended only for the use of the
addressee(s) named above or may contain information that is legally
privileged. If you are not the intended addressee, or the person
responsible for delivering it to the intended addressee, you are hereby
notified that reading, disseminating, distributing or copying this
message is strictly prohibited. If you have received this message by
mistake, please immediately notify us by replying to the message and
delete the original message and any copies immediately thereafter.
Thank you.
FACLD
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100405/64e32041/attachment-0001.htm>
Name: not available
Type: image/jpeg
Desc: Outlook.jpg
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100405/64e32041/attachment-0001.jpeg>
