[mpich-discuss] mpich2-1.2.1p1
    Costa, Michael
    MCosta at fanshawec.ca
    Fri Apr  2 14:22:46 CDT 2010
Rajeev,
Thanks for your prompt input on this. I will try re-configuring with that device.
Mike C.
From: mpich-discuss-bounces at mcs.anl.gov on behalf of Rajeev Thakur
Sent: Fri 4/2/2010 2:52 PM
Subject: Re: [mpich-discuss] mpich2-1.2.1p1
Can you try configuring with --with-device=ch3:sock and see if that works?
Rajeev
	From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Costa, Michael
	Sent: Friday, April 02, 2010 1:01 PM
	Subject: [mpich-discuss] mpich2-1.2.1p1
	I have been struggling with communication errors when ever I run mpiexec. This installation is on PARISC based cluster. Running mpich2-1.2.1p1, I have configured it with --with-device=ch3:nemesis.
	Currently only 2 nodes are in the ring, hp20 and hp14 for testing/setup purposes.
	The following steps may shed some light on the problem, which I'm sure is something I have omitted or failed to do with the initial installation/configuration. It appears that I can run non MPI programs OK, but MPI code like cpi or hello fail.
	hp20:~$ mpdallexit
	mikec at hp20:~$ mpdboot -v -n 2 -f /etc/mpd.hosts
	running mpdallexit on hp20
	LAUNCHED mpd on hp20  via
	RUNNING: mpd on hp20
	LAUNCHED mpd on hp14  via  hp20
	RUNNING: mpd on hp14
	mikec at hp20:~$ mpdtrace
	hp20
	hp14
	mikec at hp20:~$ mpdtrace -l
	hp20_44192 (172.17.81.20)
	hp14_51832 (172.17.81.14)
	mikec at hp20:~$ mpdringtest 10
	time for 10 loops = 0.0491678714752 seconds
	mikec at hp20:~$ mpiexec -n 2 uname -a
	Linux hp20 2.6.32-trunk-parisc #1 Mon Jan 11 03:07:31 UTC 2010 parisc GNU/Linux
	Linux hp14 2.6.32-trunk-parisc #1 Mon Jan 11 03:07:31 UTC 2010 parisc GNU/Linux
	mikec at hp20:~$ mpiexec -n 1 ./cpi
	Process 0 of 1 is on hp20
	pi is approximately 3.1415926544231341, Error is 0.0000000008333410
	wall clock time = 0.003888
	mikec at hp20:~$ mpiexec -n 2 ./cpi
	Process 0 of 2 is on hp20
	Process 1 of 2 is on hp14
	Fatal error in PMPI_Bcast: Other MPI error, error stack:
	PMPI_Bcast(1302)..................: MPI_Bcast(buf=0xc016e33c, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failed
	MPIR_Bcast(1031)..................:
	MPIR_Bcast_binomial(157)..........:
	MPIC_Recv(83).....................:
	MPIC_Wait(513)....................:
	MPIDI_CH3I_Progress(150)..........:
	MPID_nem_mpich2_blocking_recv(948):
	MPID_nem_tcp_connpoll(1720).......:
	state_listening_handler(1787).....: accept of socket fd failed - Resource temporarily unavailable
	rank 1 in job 2  hp20_44192   caused collective abort of all ranks
	  exit status of rank 1: return code 1
	PMPI_Bcast(1302)..................: MPI_Bcast(buf=0xc067f33c, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failed
	MPIR_Bcast_binomial(187)..........:
	MPIC_Send(41).....................:
	MPID_nem_tcp_connpoll(1709).......: Communication error
	Any comments and or suggestions are greatly appreciated.
	Mike C.
	Michael A. Costa
	SET (RCC), CCAI-CCNA/CCNP (Cisco), MInfTech (Griffith)
	Professor - Information Technology Division
	Fanshawe College
	G3001
	1001 Fanshawe College Boulevard
	P.O. Box 7005
	London, ON N5Y 5R6
	Tel: (519) 452-4291  Fax: (519) 452-1801
Name: not available
Type: application/ms-tnef
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100402/ebd34fb6/attachment-0001.bin>
