[mpich-discuss] MPI_Comm_spawn_multiple() fails
    Bakkal, Alex
    Abakkal at LOANPERFORMANCE.com
    Thu Apr  1 16:58:07 CDT 2010
Hello,
I have installed MPICH2 v.1.2.1 on Windows XP Pro machines and was
trying to run the following test app on "mt" channel:
#define NHOST 2
int main(int argc, char* argv[]) {
int supported;
int rank, size;
MPI_Comm parent, intercomm;
MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &supported);
if(supported != MPI_THREAD_MULTIPLE){
printf("The library does not support MPI_THREAD_MULTIPLE\n");
exit(-1);
MPI_Comm_get_parent(&parent);
if (parent == MPI_COMM_NULL){
int i;
int nproc[NHOST] = {1, 1};
char* progs[NHOST] = {"c:\\mpi_spawn", "c:\\tm\\mpi_spawn"};
MPI_Info infos[NHOST];
for (i=0; i < NHOST; i++) {
MPI_Info_create(&infos[i]);
MPI_Info_set(infos[i], "host", "localhost");
MPI_Comm_spawn_multiple(NHOST,
progs, MPI_ARGVS_NULL, nproc, infos,
0, MPI_COMM_WORLD, &intercomm, MPI_ERRCODES_IGNORE);
MPI_Info_free(&infos[i]);
else{
intercomm = parent;
MPI_Comm_rank(intercomm, &rank);
MPI_Comm_size(intercomm, &size);
printf("[%d/%d] Hello world\n", rank, size); fflush(stdout);
MPI_Comm_free(&intercomm);
MPI_Finalize();
return 0;
The app hangs. I can see three (as expected) instances of the program in
the Task Manager but MPI_Comm_spawn_multiple() never returns control to
my app.
I have reduced the number of spawned hosts to one and it ran
successfully. Also, it spawned successfully two hosts with the following
line commented out:
//MPI_Info_set(infos[i], "host", "localhost");
I have tried it on two machines with the same result.
Also, I have tried to spawn just one instance but on the remote host and
got the following error messages:
ERROR:unable to read the cmd header on the pmi context, Error = -1
ERROR:Error posting ready, An existing connection was forcibly closed by
the remote host.
I am not sure whether that is related to the first issue?
Any insight would be greately appreciated.
Thank you.
Alex
This message may contain confidential or proprietary information intended only for the use of the
addressee(s) named above or may contain information that is legally privileged. If you are
not the intended addressee, or the person responsible for delivering it to the intended addressee,
you are hereby notified that reading, disseminating, distributing or copying this message is strictly
prohibited. If you have received this message by mistake, please immediately notify us by
replying to the message and delete the original message and any copies immediately thereafter.
Thank you.
FACLD
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100401/8b0dbe57/attachment.htm>
