[mpich-discuss] Problems running mpi applicationon	differentCPUs
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Sep 29 10:07:20 CDT 2009
Try running the cpi example from the mpich2/examples directory. Try
running some of the tests in test/mpi.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Gaetano Bellanca
> Sent: Tuesday, September 29, 2009 9:13 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problems running mpi
> Dear Rajeev,
> I tested as indicated in the appendix of the installation
> guide using mpdcheck (and also changing the device using
> ch3:nemesis (thank you for the suggestion, Cye)) but nothing
> changes in the behavior of the code.
> However I noted that, changing the machinefile for not to
> have the server machine as a first one, I have different
> behaviors. In particular running with mpiexec -machinefile
> my_machinefile -n 6 my_parallel_code and:
> 1) machinefile as follows
> server
> server
> client1
> client2
> client3
> client4
> client5
> the code starts with the previous error
> Fatal error in MPI_Init: Other MPI error, error stack:
>  > >> MPIR_Init_thread(394): Initialization failed  > >>
> (unknown)(): Other MPI error
>  > >> rank 3 in job 8  c1_4545   caused collective abort of all ranks
>  > >>  exit status of rank 3: return code 1
> 2) machinefile as follows
> client2
> client3
> client4
> client5
> server
> server
> the code starts with a SIGSEGV segmentation fault at the line
> of the MPI_INIT
> 3) machinefile as follows
> client2
> client3
> server
> server
> client4
> client5
> the code starts regularly, but stops working in the first
> file writing procedure.
> It produces a file of 0 bytes, but does not advance in any
> other procedure, and I have to kill to terminate.
> Could it be something relevant to a synchronization/timeout
> between the different machines?
> On another cluster (all Pentium IV 3GHz), the same program is
> slower to start when launched, but everything works fine.
> Regards.
> Gaetano
> Rajeev Thakur ha scritto:
> > ch3:sock won't perform as well as ch3:nemesis though.
> > Rajeev
> >     *From:* mpich-discuss-bounces at mcs.anl.gov
> >     [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf
> Of *Cye Stoner
> >     *Sent:* Monday, September 28, 2009 4:32 PM
> >     *To:* mpich-discuss at mcs.anl.gov
> >     *Subject:* Re: [mpich-discuss] Problems running mpi
> application on
> >     differentCPUs
> >     When deploying MPICH2 to a small cluster, I noticed
> that many had
> >     problems with the "--with-device=ch3:nemesis"
> >     Try using the "--with-device=ch3:sock" interface instead.
> >     Cye
> >     On Mon, Sep 28, 2009 at 12:13 PM, Rajeev Thakur
> >     <thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>> wrote:
> >         Try using the mpdcheck utility to debug as described in the
> >         appendix of
> >         the installation guide. Pick one client and the server.
> >         Rajeev
> >         <mailto:mpich-discuss-bounces at mcs.anl.gov>
> >         <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of
> >         > Gaetano Bellanca
> >         > Sent: Monday, September 28, 2009 6:00 AM
> >         > Cc: mpich-discuss at mcs.anl.gov
> <mailto:mpich-discuss at mcs.anl.gov>
> application
> >         > on different CPUs
> >         > Dear Rajeev,
> >         > thanks for your help. I disabled the firewall on
> the server
> >         (the only
> >         > one running) and tried with any other combination.
> >         > All the clients together are running correctly.
> The same for the
> >         > processors on the server separately.
> >         > The problem is only when I mix processes on the
> server and on
> >         > the client.
> >         > When I run mpdtrace on the server, all the CPUs are
> >         > responding correctly.
> >         > The same happens if I run in parallel 'hostname'
> >         > Probably, it is a problem of my code, but it works on a
> >         cluster of 10
> >         > Pentium IV PEs.
> >         > I discover a 'strange behavior':
> >         > 1) running the code with the server as a first
> machine of the
> >         > pool, the
> >         > code hangs with the previously communicated error;
> >         > 2) if I put the server as a second machine of the
> pool, the
> >         > code starts
> >         > and works regularly up to the writing procedures,
> opens the
> >         > first file
> >         > and then remains indefinitely waiting for something;
> >         > Should I compile mpich2 with some particular
> communicator? I
> >         have
> >         > nemesis, at the moment.
> >         > I'm using this for mpich2 compilation:
> >         > ./configure --prefix=/opt/mpich2/1.1/intel11.1
> --enable-cxx
> >         > --enable-f90
> >         > --enable-fast --enable-traceback --with-mpe
> --enable-f90modules
> >         > --enable-cache --enable-romio
> --with-file-system=nfs+ufs+pvfs2
> >         > --with-device=ch3:nemesis --with-pvfs2=/usr/local
> >         > --with-java=/usr/lib/jvm/java-6-sun-1.6.0.07/
> >         --with-pm=mpd:hydra
> >         > Regards
> >         > Gaetano
> >         > > Try running on smaller subsets of the machines
> to debug the
> >         > problem. It
> >         > > is possible that a process on some machine
> cannot connect
> >         to another
> >         > > because of some firewall settings.
> >         > > Rajeev
> >         > Gaetano Bellanca
> >         > >> Sent: Saturday, September 26, 2009 7:10 AM
> >         > >> Subject: [mpich-discuss] Problems running mpi
> application on
> >         > >> different CPUs
> >         > >> Hi,
> >         > >> I'm sorry but  I posted with a wrong Object my previous
> >         message!!!
> >         > >> I have a small cluster of
> >         > >> a) 1 server: dual processor / quad core
> Intel(R) Xeon(R)
> >         CPU  E5345
> >         > >> b) 4 clients: single processor / dual core Intel(R)
> >         > Core(TM)2 Duo CPU
> >         > >> E8400 connected  with a 1Gbit/s ethernet network.
> >         > >> I compiled mpich2-1.1.1p1 on the first system (a) and
> >         > share mpich on
> >         > >> the other computers via nfs. I have mpd
> running as a root
> >         > on all the
> >         > >> computers (ubunt 8.04 . kernel 2.6.24-24-server)
> >         > >> When I run my code in parallel on the first
> system, it works
> >         > >> correctly; the same happens running the same code  in
> >         > parallel on the
> >         > >> other computers (always running the code from the
> >         server). On the
> >         > >> contrary, running the code using processors
> from both the
> >         > server and
> >         > >> the clients at the same time with the command:
> >         > >> mpiexec -machinefile machinefile -n 4 my_parallel_code
> >         > >> I receive this error message:
> abort of all
> >         ranks
> >         > >> Should I use some particular flags in compilation or at
> >         run time?
> >         > >> Regards.
> >         > >> Gaetano
> >         > >> Gaetano Bellanca - Department of Engineering -
> University
> >         > of Ferrara
> >         > >> Via Saragat, 1 - 44100 - Ferrara - ITALY Voice (VoIP):
> >         +39 0532
> >         > >> 974809 Fax: +39 0532 974870
> >         mailto:gaetano.bellanca at unife.it
> >         <mailto:gaetano.bellanca at unife.it>
> >         > >> L'istruzione costa? Stanno provando con l'ignoranza!
> University of
> >         Ferrara
> >         > Voice (VoIP): +39 0532 974809 Fax: +39 0532 974870
> >     "If you already know what recursion is, just remember
> the answer.
> >     Otherwise, find someone who is standing closer to
> >     Douglas Hofstadter than you are; then ask him or her what
> >     recursion is." - Andrew Plotkin
> Gaetano Bellanca - Department of Engineering - University of
> Ferrara Via Saragat, 1 - 44100 - Ferrara - ITALY Voice
