[mpich-discuss] MPICH2 and OpenPBS/Torque using MPICH2-Hydra
    Pavan Balaji
    balaji at mcs.anl.gov
    Fri Sep 25 12:06:30 CDT 2009
Hmm.. I do see your point. Ok, I've modified Hydra to use the number of
nodes specified to the resource manager, unless the user explicitly
overrides it with the "-n" option.
A new tarball with basic testing is present here:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra
I need to do some more cleanup + performance optimization, but you can
give this one a shot.
  -- Pavan
On 09/25/2009 10:54 AM, Simon Hammond wrote:
> Hi Pavan,
> Thanks for this, I will give it a go when our nodes have cleared out
> the Friday rush.
> On the -n thing we tend to want users to have one script for their
> code which they submit regardless of the number of processors etc (the
> script stays the same). The users generally want to select the number
> of nodes and cores etc via the scheduler so in your example they would
> just select 10 nodes and not the 100 since 90 would end up not being
> used. I guess the problem there is they want PBS to "just work" and
> put their jobs down on the nodes in the way they have described to
> PBS.
> I know I keep banging on about it (and its not meant to be a
> competition) but I think they have got used to an OpenMPI style of
> runtime where everything seems to just glue together and work. For
> MPICH2 ideally we'd like some similar functionality because we have
> codes which *only* work on MPICH2/MVAPICH.
> Maybe this stuff could be got around with some scripting in the PBS
> launch script itself but the placement etc would be pretty loose then.
> What do you think?
> S.
> 2009/9/25 Pavan Balaji <balaji at mcs.anl.gov>:
>> Simon,
>> I did an initial version of the code; tarball here:
>> However, I'm not sure if skipping the "-n" option is a good idea. Even if
>> your allocation has 100 nodes, the application might need to be launched
>> only on 10 nodes. The "-f" option, on the other hand, would be redundant in
>> PBS environments. You don't need to specify it with PBS anymore. Also, this
>> would keep the behavior consistent with other environments such as slurm.
>> Thoughts?
>>  -- Pavan
>> On 09/24/2009 03:25 AM, Simon Hammond wrote:
>>> This would definitely be helpful.
>>> I'm guessing these processes (under SSH) wouldn't be managed in the
>>> same way that PBS would say an OpenMPI job? Getting rid of the -n
>>> would be a good start. Can I ask how node placement and rank
>>> allocation etc would work?
>>> S.
>>> 2009/9/23  <balaji at mcs.anl.gov>:
>>>> PBS support is not added in Hydra yet. See:
>>>> https://trac.mcs.anl.gov/projects/mpich2/ticket/443
>>>> However, so far we were considering PBS support as a bootstrap server
>>>> (which has a lot more functionality than just providing the number of
>>>> nodes). But adding PBS as a resource management kernel (RMK) is possible too
>>>> and should be simpler as well. Doing this will allow you to skip the "-n"
>>>> option in PBS environments, but you'll internally still be using ssh to
>>>> start the processes. If this is helpful for you, we can consider adding it
>>>> for the next release.
>>>>  -- Pavan
>>>> ----- "Si Hammond" <simon.hammond at gmail.com> wrote:
>>>>> Hi everyone,
>>>>> We're trying to get MPICH2 to work under PBS so that users don't need
>>>>> to specify the number of processors etc. We have built the install
>>>>> with the MPICH2-Hydra device and this seems to work (in that jobs will
>>>>> run) but users still have to specify the number of MPI ranks using
>>>>> -n.
>>>>> I found the -rmk flag in some documentation using Google but "-rmk
>>>>> pbs" doesn't seem to work either (the example uses "-rmk lsf")
>>>>> How does a user like myself go about making a PBS-enabled MPICH2 build
>>>>> to the job placement etc is all handled under the covers? Is this
>>>>> possible? OpenMPI seems to have this covered but we'd like to install
>>>>> MPICH2 as well since one of our codes only runs with MPICH2.
>>>>> Thanks for your help.
>>>>> Si Hammond
>>>>> Performance Modelling, Analysis and Optimisation Laboratory
>>>>> High Performance Systems Group
>>>>> Department of Computer Science
>>>>> University of Warwick, CV4 7AL, UK
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
Pavan Balaji
