[mpich-discuss] MPI_THREAD_MULTIPLE
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Sep 25 09:18:46 CDT 2009
If you are starting your program without mpiexec the default channel is
picked. You can control the channel used by the library using the
"MPICH2_CHANNEL" environment variable.
Please set MPICH2_CHANNEL environment variable as follows (and then run
your MPI program),
1) To use the Nemesis channel, MPICH2_CHANNEL=nemesis
2) To use the multithreaded channel, MPICH2_CHANNEL=mt
The default channel (MPICH2_CHANNEL=sock) is the single threaded sock
channel.
Let us know if it works for you.
Jayesh
_____
Sent: Tuesday, September 22, 2009 11:05 AM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPI_THREAD_MULTIPLE
I will do that, but in the meantime, could you run your own test code
below directly, not using mpiexec, and see the result. For me, it's
returning MPI_THREAD_SINGLE - is that how it's supposed to be, i.e. the
thread-safe support can only be enabled if the application is run via
mpiexec?
_____
To: Lubomir Radev <lubomirr at yahoo.com>
Sent: Tuesday, September 22, 2009 8:21:44 AM
Subject: RE: [mpich-discuss] MPI_THREAD_MULTIPLE
Can you send us a test program ?
Jayesh
_____
Sent: Tuesday, September 22, 2009 2:27 AM
To: Jayesh Krishna; mpich-discuss at mcs.anl.gov
This works for me too, returning MPI_THREAD_MULTIPLE, but only when
started via mpiexec.
However, I need to launch my worker processes programmatically by using
MPI_Comm_spawn_multiple(). That's necessitated by the nature of my app -
it's actually a library that clients will be linking against. So the
client process has to spawn workers and communicate with them, which works
just fine from one thread and fails with two. And if I use
MPI_Init_thread() from the client/master process (which isn't started by
mpiexec), it always returns MPI_THREAD_SINGLE.
Should I try to pack all of my MPI communications in one thread or can you
suggest a solution other than mpiexec for multiple threads? Perhaps I
could somehow perform the same thread support initialization that mpiexec
apparently does internally?
Thanks very much.
_____
Cc: Lubomir Radev <lubomirr at yahoo.com>
Sent: Monday, September 21, 2009 9:04:17 AM
Are you launching your MPI job using the "-channel" option of mpiexec
(mpiexec -n 2 -channel nemesis thread_multiple_test.exe)? A simple MPI
program (see below) that queries for the thread level support returns
MPI_THREAD_MULTIPLE for me.
=========== Thread multiple test ===================
#include <iostream>
#include "mpi.h"
int main(int argc, char *argv[])
int provided;
provided = MPI::Init_thread(MPI_THREAD_MULTIPLE);
if(provided == MPI_THREAD_MULTIPLE){
std::cout << "Thread multiple supported" << std::endl;
else{
std::cout << "Thread multiple NOT supported" << std::endl;
MPI::Finalize();
Jayesh
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Lubomir Radev
Sent: Sunday, September 20, 2009 7:23 PM
Yes. I was using 1.0.8p1 originally, but after your suggestion got 1.1.1p1
and the problem persists.
I could reduce my code to a test case exhibiting the issue, but I need to
understand why MPI_Init_thread() won't provide me with MPI_THREAD_MULTIPLE
support and always returns MPI_THREAD_SINGLE regardless of the channel
configuration. I need to get that working first so my multi-threaded code
can assume it operates in a correctly initialized environment and can
legitimately call into MPICH2 simultaneously from more than one thread.
I'm using Boost.MPI wrapper (and Boost.Thread), but that shouldn't matter.
Thanks
_____
Sent: Friday, September 18, 2009 8:42:38 AM
Are you trying the latest stable release, 1.1.1p1, of MPICH2
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=dow
nloads) ?
Jayesh
-----Original Message-----
Sent: Thursday, September 17, 2009 10:08 PM
Subject: [mpich-discuss] MPI_THREAD_MULTIPLE
Hey guys,
I need to call into the thread-safe version of MPICH2 so I tried to
initialize with MPI_Init_thread() and MPI_THREAD_MULTIPLE, but no matter
how I configured the channels on my nodes - tried both mt and nemesis -
that function returns MPI_THREAD_SINGLE as provided thread support.
I'm using 1.0.8p1 on Windows if that matters. Installed from the provided
MSI binary. Perhaps I need to build from sources, configuring it with
thread support?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090925/d9e963c5/attachment.htm>
