[mpich-discuss] MPI_THREAD_MULTIPLE
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Sep 22 10:21:44 CDT 2009
 Can you send us a test program ?
Jayesh
  _____
Sent: Tuesday, September 22, 2009 2:27 AM
To: Jayesh Krishna; mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPI_THREAD_MULTIPLE
This works for me too, returning MPI_THREAD_MULTIPLE, but only when
started via mpiexec.
However, I need to launch my worker processes programmatically by using
MPI_Comm_spawn_multiple(). That's necessitated by the nature of my app -
it's actually a library that clients will be linking against. So the
client process has to spawn workers and communicate with them, which works
just fine from one thread and fails with two. And if I use
MPI_Init_thread() from the client/master process (which isn't started by
mpiexec), it always returns MPI_THREAD_SINGLE.
Should I try to pack all of my MPI communications in one thread or can you
suggest a solution other than mpiexec for multiple threads? Perhaps I
could somehow perform the same thread support initialization that mpiexec
apparently does internally?
Thanks very much.
  _____
Cc: Lubomir Radev <lubomirr at yahoo.com>
Sent: Monday, September 21, 2009 9:04:17 AM
Subject: RE: [mpich-discuss] MPI_THREAD_MULTIPLE
 Are you launching your MPI job using the "-channel" option of mpiexec
(mpiexec -n 2 -channel nemesis thread_multiple_test.exe)? A simple MPI
program (see below) that queries for the thread level support returns
MPI_THREAD_MULTIPLE for me.
=========== Thread multiple test ===================
#include <iostream>
#include "mpi.h"
int main(int argc, char *argv[])
int provided;
provided = MPI::Init_thread(MPI_THREAD_MULTIPLE);
if(provided == MPI_THREAD_MULTIPLE){
std::cout << "Thread multiple supported" << std::endl;
else{
std::cout << "Thread multiple NOT supported" << std::endl;
MPI::Finalize();
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Lubomir Radev
Sent: Sunday, September 20, 2009 7:23 PM
Yes. I was using 1.0.8p1 originally, but after your suggestion got 1.1.1p1
and the problem persists.
I could reduce my code to a test case exhibiting the issue, but I need to
understand why MPI_Init_thread() won't provide me with MPI_THREAD_MULTIPLE
support and always returns MPI_THREAD_SINGLE regardless of the channel
configuration. I need to get that working first so my multi-threaded code
can assume it operates in a correctly initialized environment and can
legitimately call into MPICH2 simultaneously from more than one thread.
I'm using Boost.MPI wrapper (and Boost.Thread), but that shouldn't matter.
Thanks
  _____
Sent: Friday, September 18, 2009 8:42:38 AM
 Are you trying the latest stable release, 1.1.1p1, of MPICH2
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=dow
nloads) ?
Jayesh
-----Original Message-----
Sent: Thursday, September 17, 2009 10:08 PM
Subject: [mpich-discuss] MPI_THREAD_MULTIPLE
Hey guys,
I need to call into the thread-safe version of MPICH2 so I tried to
initialize with MPI_Init_thread() and MPI_THREAD_MULTIPLE, but no matter
how I configured the channels on my nodes - tried both mt and nemesis -
that function returns MPI_THREAD_SINGLE as provided thread support.
I'm using 1.0.8p1 on Windows if that matters. Installed from the provided
MSI binary. Perhaps I need to build from sources, configuring it with
thread support?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090922/f9d659c4/attachment.htm>
