[mpich-discuss] mpich2-1.1.1p1/nemesis error
Bryan Putnam
bfp at purdue.edu
Mon Sep 14 10:41:41 CDT 2009
Hi All,
We've run across a piece of C code that appears to run successfully with
mpich, mvapich2-1.4rc2, mpich2-1.1.1p1 (built with ssm or sockets), but
fails with mpich2-1.1.1p1 (built with nemesis). The code is meant to be
run with two processors, and it either hangs or give an error message in
the case that the two processors are on separate nodes. It appears to work
OK if both processors are on the same node. I've included it here for your
enjoyment if you like to try it out.
Thanks!
Bryan
#include <stdio.h>
#include <string.h>
#include <mpi.h>
double array[256][256][512];
int main(int argc, char *argv[])
int myrank;
MPI_Request req[2];
MPI_Status status1, status2, stats[2];
MPI_Datatype subarray1, subarray2, subarray3, subarray4;
int array_size[] = {256, 256, 512};
int array_subsize1[] = {128,128,512};
int array_subsize2[] = {128,128,512};
int array_start1[] = {0, 0, 0};
int array_start2[] = {128, 128, 0};
int i;
double *ptr = (double *)array;
MPI_Init(&argc, &argv);
MPI_Comm_rank(MPI_COMM_WORLD, &myrank);
printf("MPI_Init okay...\n");
if(myrank == 0)
/* Create a subarray datatype */
MPI_Type_create_subarray(3, array_size, array_subsize1,
array_start1, MPI_ORDER_C, MPI_DOUBLE, &subarray1);
MPI_Type_commit(&subarray1);
MPI_Type_create_subarray(3, array_size, array_subsize2,
array_start2, MPI_ORDER_C, MPI_DOUBLE, &subarray2);
MPI_Type_commit(&subarray2);
for(i = 0; i < 256*256*512; i++)
ptr[i] = 0.0;
printf("data init ok\n");
fflush(stdout);
MPI_Send(array, 1, subarray1, 1, 123, MPI_COMM_WORLD);
printf("sent ok\n");
fflush(stdout);
MPI_Recv(array, 1, subarray2, 1, 124, MPI_COMM_WORLD,
&stats[1]);
printf("received ok\n");
printf("array: [0][0][0] = %f, [128][128][0] = %f\n",
array[0][0][0], array[128][128][0]);
fflush(stdout);
else
array_start1, MPI_ORDER_C, MPI_DOUBLE, &subarray3);
MPI_Type_commit(&subarray3);
array_start2, MPI_ORDER_C, MPI_DOUBLE, &subarray4);
MPI_Type_commit(&subarray4);
ptr[i] = 1.0;
fflush(stdout);
MPI_Recv(array, 1, subarray3, 0, 123, MPI_COMM_WORLD,
&stats[0]);
fflush(stdout);
MPI_Send(array, 1, subarray4, 0, 124, MPI_COMM_WORLD);
fflush(stdout);
MPI_Finalize();
return 0;
