[mpich-discuss] ch3:nemesis performance and SMP cluster
    Vamvakopoulos Manolis
    evamvak at cs.uoi.gr
    Sat Sep  5 17:09:03 CDT 2009
Dear Developers and Users
In our cluster we have already install  mpich2-1.0.8 as a default production
version configure with ch3:ssm device.
With the above lib ,an application  with alltoall communication (let's say
amber9) "runs" efficiently  on 16 procs with 1 procs per node  (16x1)
and 16 procs with two procs per node (8x2) (run's time are comparable)
I make run test with same application and  mpich2-1.1.1p1 with nemesis device
and the same tests was faster (up to 30%) on first case (one proc per node)
same behavior i found with  mpich2-1.1.1p and ch3:ssm device
In all case with mpich2-1.1.1p the runs on 16 procs on 16 different node were
faster
Our cluster consist from DL145 HP with 2 single CPU: opteron 248 2.2 MHZ with
4GB per node with linux 2.6.9-78.0.1.ELsmp SL 4.7 and for the interconnect we
use a full crossbar dedicate Gigabit switch (with high backplane 400Gb)
can somebody  shed a light to this issue
thank you very much in advance
E.V.
University OF Ioannina
Department of Computer Science
P.O. BOX 1186 Ioannina, Greece
Tel: (+30)-26510-98864
Fax: (+30)-26510-98890
