[mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran Compiler(64 bit)
Steven Berg
sjberg at uwaterloo.ca
Thu Sep 3 12:38:02 CDT 2009
Hi Everyone,
Thanks for your help. I have managed to get mpif90 to build with ifort. The
problem was that I was missing a library.
Now I just have to sort out the 64-bit issues with the code I need to run.
Thanks again for all of your help and patience.
Steve
Steven J. Berg
Ph.D. Student
Physics 220C
Department of Earth and Environmental Sciences
University of Waterloo
200 University Ave.
Waterloo, Ontario
N2L 3G1
519 - 888 - 4567 x32738
http://www.science.uwaterloo.ca/~sjberg/
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dorian Krause
Sent: Thursday, September 03, 2009 1:13 PM
Subject: Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran
Compiler(64 bit)
Hi Steve,
in both config files I find the same problem:
./configure: line 4423: icc: command not found
I think you also need to source some iccvars.sh (or similar) to make icc
working ...
Additionally, I don't know the flag "--enable-F90modules", only
"--enable-f90". Don't know if this is a problem ...
Steven Berg wrote:
> I should have attached the output for config.log for MPICH2 in my last
> reply. Here it is.
> Steve
> From: mpich-discuss-bounces at mcs.anl.gov
> Sent: Thursday, September 03, 2009 12:44 PM
> Compiler(64 bit)
> Hi Steve,
> just use
> ./configure -prefix=/home/sjberg/mpich -enable-f77 -enable-f90 (is this
> correct?)
> setting the CC, F77, ... variables should be sufficient for the
> configure script to pick up the correct compiler.
> You can use
> ./configure --help
> to get a description of the flags ...
> Steven Berg wrote:
>> Hi Rajeev,
>> When I try MPICH2-1.1.1p1 I can a configure error
>> Configure: error: unrecognized option: -f90=ifort
>> How do I specify the intel fortran compiler for MPICH2? Here are the
>> commands I entered.
>> #source /opt/intel/Compiler/11.1/046/bin/ifortvars.sh intel64
>> #export CC=icc
>> #export CXX=icpc
>> #export F77=ifort
>> #export FC=ifort
>> #export F90=ifort
>> #export RSHCOMMAND=ssh
>> #./configure -prefix=/home/sjberg/mpich -enable-f77 -enable-F90modules
>> -f90=ifort -cc=icc =c++=icpc -fc=ifort
>> Steve
>> *From:* mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Rajeev Thakur
>> *Sent:* Thursday, September 03, 2009 12:19 PM
>> *To:* mpich-discuss at mcs.anl.gov
>> *Subject:* Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
>> Can you try the latest version of MPICH2 instead? MPICH-1 is too old.
>> Rajeev
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Steven Berg
>> *Sent:* Thursday, September 03, 2009 9:32 AM
>> *Subject:* [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
>> Hi All,
>> I am currently trying to upgrade form 32-bit to 64-bit using Rocks
>> Clusters 5.2. I previously had the 32-bit version installed on
>> 64-bit machines and was able to get mpich1.2.7p1 to build
>> (specifically mpif90). I was using the Intel Fortran Compiler
>> 9.1.052 and the following commands
>> #source /opt/intel/fc/9.1.052/bin/ifortvars.sh
>> #export CC=icc
>> #export CXX=icpc
>> #export F77=ifort
>> #export FC=ifort
>> #export F90=ifort
>> -enable-F90modules -f90=ifort -cc=icc =c++=icpc -fc=ifort
>> #make
>> #make install
>> Using these commands I was able successfully build mpif90 and
>> subsequently compile my code.
>> Since upgrading to the 64-bit version of Rocks Clusters 5.2 and
>> Intel Fortran Compiler 11.1.046 (64-bit install only) I am unable
>> to get mpif90 to build using the following
>> #export CC=icc
>> #export CXX=icpc
>> #export F77=ifort
>> #export FC=ifort
>> #export F90=ifort
>> #make
>> #make install
>> I know I should be using Mpich2, but I was told I need to compile
>> this code with mpich1.2.7p1. I am also fairly new to mpich and
>> clustering, any advice or suggestions are greatly appreciated. I
>> assume the problem has to do with the switch in intel compilers?
>> Thanks in advance.
>> Steve
>> Steven J. Berg
>> Ph.D. Student
>> Physics 220C
>> 200 University Ave.
>> Waterloo, Ontario
>> N2L 3G1
>> <http://www.science.uwaterloo.ca/%7Esjberg/>
