[mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran Compiler(64 bit)
Dorian Krause ddkrause at uni-bonn.de
Thu Sep 3 12:03:50 CDT 2009
Could you check the "config.log" output file (grep for "could not
compile")? There you should see what error causes the configure stop.
Btw.: Did you check the ifort setup, i.e. can you compile a simple hello
world program?
Steven Berg wrote:
> Hi,
> When I run it with
>  #source /opt/intel/Compiler/11.1/046/bin/ifortvars.sh intel64
>  #export F77=ifort
>  #export FC=ifort
>  #export F90=ifort
>  #export RSHCOMMAND=ssh
>  #./configure -prefix=/home/sjberg/mpich2 -enable-f77 -enable-f90
> Configure stops with the following output:
> Checking for linker for Fortran main programs ... configure: error: could
> not compile Fortran test program
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dorian Krause
> Sent: Thursday, September 03, 2009 12:44 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran
> Compiler(64 bit)
> Hi Steve,
> just use
> ./configure -prefix=/home/sjberg/mpich -enable-f77 -enable-f90 (is this
> correct?)
> setting the CC, F77, ... variables should be sufficient for the
> configure script to pick up the correct compiler.
> You can use
> ./configure --help
> to get a description of the flags ...
> Steven Berg wrote:
>> Hi Rajeev,
>> When I try MPICH2-1.1.1p1 I can a configure error
>> Configure: error: unrecognized option: -f90=ifort
>> How do I specify the intel fortran compiler for MPICH2? Here are the
>> commands I entered.
>> #export CC=icc
>> #export CXX=icpc
>> #export F77=ifort
>> #export FC=ifort
>> #export F90=ifort
>> #./configure -prefix=/home/sjberg/mpich -enable-f77 -enable-F90modules
>> -f90=ifort -cc=icc =c++=icpc -fc=ifort
>> Steve
>> *From:* mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Rajeev Thakur
>> *Sent:* Thursday, September 03, 2009 12:19 PM
>> *To:* mpich-discuss at mcs.anl.gov
>> *Subject:* Re: [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
>> Can you try the latest version of MPICH2 instead? MPICH-1 is too old.
>> Rajeev
>>     [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Steven Berg
>>     *Sent:* Thursday, September 03, 2009 9:32 AM
>>     *Subject:* [mpich-discuss] mpich1.2.7p1 with Intel 11.1.046
>>     Hi All,
>>     I am currently trying to upgrade form 32-bit to 64-bit using Rocks
>>     Clusters 5.2. I previously had the 32-bit version installed on
>>     64-bit machines and was able to get mpich1.2.7p1 to build
>>     (specifically mpif90). I was using the Intel Fortran Compiler
>>     9.1.052 and the following commands
>>     #source /opt/intel/fc/9.1.052/bin/ifortvars.sh
>>     #export CC=icc
>>     #export CXX=icpc
>>     #export F77=ifort
>>     #export FC=ifort
>>     #export F90=ifort
>>     -enable-F90modules -f90=ifort -cc=icc =c++=icpc -fc=ifort
>>     #make
>>     #make install
>>     Using these commands I was able successfully build mpif90 and
>>     subsequently compile my code.
>>     Since upgrading to the 64-bit version of Rocks Clusters 5.2 and
>>     Intel Fortran Compiler 11.1.046 (64-bit install only) I am unable
>>     to get mpif90 to build using the following
>>     #export CC=icc
>>     #export CXX=icpc
>>     #export F77=ifort
>>     #export FC=ifort
>>     #export F90=ifort
>>     #make
>>     #make install
>>     I know I should be using Mpich2, but I was told I need to compile
>>     this code with mpich1.2.7p1. I am also fairly new to mpich and
>>     clustering, any advice or suggestions are greatly appreciated. I
>>     assume the problem has to do with the switch in intel compilers?
>>     Thanks in advance.
>>     Steve
>>     Steven J. Berg
>>     Ph.D. Student
>>     Physics 220C
>>     Department of Earth and Environmental Sciences
>>     University of Waterloo
>>     200 University Ave.
>>     Waterloo, Ontario
>>     N2L 3G1
>>     519 - 888 - 4567 x32738
>>     http://www.science.uwaterloo.ca/~sjberg/
>>     <http://www.science.uwaterloo.ca/%7Esjberg/>
