[mpich-discuss] mpich1.2.7p1 with Intel 11.1.046 Fortran Compiler (64 bit)
Dorian Krause ddkrause at uni-bonn.de
Thu Sep 3 10:42:19 CDT 2009
Hi Steve,
what is the error message you get from make?
Dorian
Steven Berg wrote:
> Hi All,
> I am currently trying to upgrade form 32-bit to 64-bit using Rocks
> Clusters 5.2. I previously had the 32-bit version installed on 64-bit
> machines and was able to get mpich1.2.7p1 to build (specifically
> mpif90). I was using the Intel Fortran Compiler 9.1.052 and the
> following commands
> #source /opt/intel/fc/9.1.052/bin/ifortvars.sh
> #export CC=icc
> #export CXX=icpc
> #export F77=ifort
> #export FC=ifort
> #export F90=ifort
> #export RSHCOMMAND=ssh
> #./configure –prefix=/home/sjberg/mpich –enable-f77 –enable-F90modules
> –f90=ifort –cc=icc =c++=icpc –fc=ifort
> #make
> #make install
> Using these commands I was able successfully build mpif90 and
> subsequently compile my code.
> Since upgrading to the 64-bit version of Rocks Clusters 5.2 and Intel
> Fortran Compiler 11.1.046 (64-bit install only) I am unable to get
> mpif90 to build using the following
> #source /opt/intel/Compiler/11.1/046/bin/ifortvars.sh intel64
> #export CC=icc
> #export CXX=icpc
> #export F77=ifort
> #export FC=ifort
> #export F90=ifort
> #make
> #make install
> I know I should be using Mpich2, but I was told I need to compile this
> code with mpich1.2.7p1. I am also fairly new to mpich and clustering,
> any advice or suggestions are greatly appreciated. I assume the
> problem has to do with the switch in intel compilers?
> Thanks in advance.
> Steve
> Steven J. Berg
> Ph.D. Student
> Physics 220C
> Department of Earth and Environmental Sciences
> University of Waterloo
> 200 University Ave.
> Waterloo, Ontario
> N2L 3G1
> 519 - 888 - 4567 x32738
> http://www.science.uwaterloo.ca/~sjberg/
> <http://www.science.uwaterloo.ca/%7Esjberg/>
