[mpich-discuss] (mpiexec 392): no msg recvd from mpd when expecting ack of request
Mr. Teo En Ming (Zhang Enming) space.time.universe at gmail.com
Fri Oct 30 05:23:04 CDT 2009
Dear All,
I have solved the problem.
With reference to
http://lists.xensource.com/archives/html/xen-devel/2009-05/msg01327.html and
http://hightechsorcery.com/2008/03/virtualization-tip-always-disable-checksumming-virtual-ethernet-devices,
I have executed the following command as root on all my 6 compute
nodes
(each compute node is a F11 linux 64-bit PV virtual machine).
# ethtool -K eth0 tx off gso on
Now I can successfully run mpiexec to execute MPI and non-MPI jobs on my
Virtual HPC Compute Cluster.
*Topic: [Xen-users] Using Xen Virtualization Environment for Development and
Testing of Supercomputing and High Performance Computing (HPC) Cluster
MPICH2 MPI-2 Applications
URL:
http://lists.xensource.com/archives/html/xen-devel/2009-10/msg01440.html
Mr. Teo En Ming (Zhang Enming) Dip(Mechatronics) BEng(Hons)(Mechanical
Engineering)
Alma Maters:
(1) Singapore Polytechnic
(2) National University of Singapore
My blog URL: http://teo-en-ming-aka-zhang-enming.blogspot.com
My Youtube videos: http://www.youtube.com/user/enmingteo
Email: space.time.universe at gmail.com
MSN: teoenming at hotmail.com
Mobile Phone (SingTel): +65-9648-9798
Mobile Phone (Starhub Prepaid): +65-8369-2618
Age: 31 (as at 30 Oct 2009)
Height: 1.78 meters
Race: Chinese
Dialect: Hokkien
Street: Bedok Reservoir Road
Country: Singapore
On Fri, Oct 30, 2009 at 4:13 PM, Mr. Teo En Ming (Zhang Enming) <
space.time.universe at gmail.com> wrote:
> Dear All,
> I have googled something which may help to solve my problem.
> *[Xen-devel] Network drop on domU (netfront: rx->offset: 0, size:
> 4294967295)*
> http://lists.xensource.com/archives/html/xen-devel/2009-05/msg01274.html
> Virtualization Tip: Always disable checksumming on virtual ethernet devices
> Let me try to work on it first.
> Engineering)
> Alma Maters:
> Height: 1.78 meters
> Race: Chinese
> Dialect: Hokkien
> Country: Singapore
> On Fri, Oct 30, 2009 at 3:56 PM, Mr. Teo En Ming (Zhang Enming) <
>> Hi,
>> I have reverted to the 2-node troubleshooting scenario. I have started
>> node 1 and node 2.
>> On node 1, I will try to bring up the ring of mpd for the 2 nodes using
>> mpdboot and try to execute mpiexec. On node 2, I will capture the tcpdump
>> messages on virtual network interface eth0.
>> Please see attached PNG screenshots. They are numbered in sequence.
>> Please check if there are any problems.
>> Thank you.
>> Engineering)
>> Alma Maters:
>> Height: 1.78 meters
>> Race: Chinese
>> Dialect: Hokkien
>> Country: Singapore
>> On Fri, Oct 30, 2009 at 2:55 PM, Mr. Teo En Ming (Zhang Enming) <
>>> Hi,
>>> Here are more virtual network interface eth0 kernel messages. Notice the
>>> "net eth0: rx->offset: 0" messages. Are they of significance?
>>> *Node 1*
>>> Oct 30 22:40:34 enming-f11-pv-hpc-node0001 mountd[1304]: authenticated
>>> mount request from 192.168.1.253:1009 for /home/enming/mpich2-install/
>>> bin (/home/enming/mpich2-install/bin)
>>> Oct 30 22:40:56 enming-f11-pv-hpc-node0001 mountd[1304]: authenticated
>>> mount request from 192.168.1.252:877 for /home/enming/mpich2-install/bin
>>> Oct 30 22:41:19 enming-f11-pv-hpc-node0001 mountd[1304]: authenticated
>>> mount request from 192.168.1.251:1000 for
>>> /home/enming/mpich2-install/bin (/home/enming/mpich2-install/bin)
>>> Oct 30 22:41:41 enming-f11-pv-hpc-node0001 mountd[1304]: authenticated
>>> mount request from 192.168.1.250:882 for /home/enming/mpich2-install/bin
>>> Oct 30 22:42:04 enming-f11-pv-hpc-node0001 mountd[1304]: authenticated
>>> mount request from 192.168.1.249:953 for /home/enming/mpich2-install/bin
>>> Oct 30 22:42:34 enming-f11-pv-hpc-node0001 mpd: mpd starting; no mpdid
>>> yet
>>> Oct 30 22:42:34 enming-f11-pv-hpc-node0001 mpd: mpd has
>>> mpdid=enming-f11-pv-hpc-node0001_48545 (port=48545)
>>> Oct 30 22:42:37 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> Oct 30 22:42:38 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> Oct 30 22:42:39 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> Oct 30 22:42:40 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> Oct 30 22:42:46 enming-f11-pv-hpc-node0001 kernel: __ratelimit: 12
>>> callbacks suppressed
>>> Oct 30 22:42:46 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> Oct 30 22:42:47 enming-f11-pv-hpc-node0001 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> *Node 6*
>>> Oct 30 22:42:44 enming-f11-pv-hpc-node0006 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> Oct 30 22:42:48 enming-f11-pv-hpc-node0006 mpd: mpd starting; no mpdid
>>> yet
>>> Oct 30 22:42:48 enming-f11-pv-hpc-node0006 mpd: mpd has
>>> mpdid=enming-f11-pv-hpc-node0006_52805 (port=52805)
>>> Oct 30 22:46:00 enming-f11-pv-hpc-node0006 kernel: net eth0: rx->offset:
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> 0, size: 4294967295
>>> *Node 1 NFS Server Configuration*
>>> [root at enming-f11-pv-hpc-node0001 ~]# cat /etc/exports
>>> /home/enming/mpich2-install/bin        192.168.1.0/24(ro)<http://192.168.1.0/24%28ro%29>
>>> *Node 2 /etc/fstab Configuration Entry for NFS Client*
>>> 192.168.1.254:/home/enming/mpich2-install/bin
>>> /home/enming/mpich2-install/bin    nfs
>>> rsize=8192,wsize=8192,timeo=14,intr
>>> Engineering)
>>> Alma Maters:
>>> Height: 1.78 meters
>>> Race: Chinese
>>> Dialect: Hokkien
>>> Country: Singapore
>>> On Fri, Oct 30, 2009 at 2:14 PM, Mr. Teo En Ming (Zhang Enming) <
>>>> Hi,
>>>> I have noticed that there are Receive Errors (RX-ERR) in all of my 6
>>>> compute nodes. It appears that there may be problems with the virtual
>>>> network interface eth0 in Xen networking.
>>>> Node 1:
>>>> [root at enming-f11-pv-hpc-node0001 ~]# netstat -i
>>>> Kernel Interface table
>>>> Iface       MTU Met    RX-OK RX-ERR RX-DRP RX-OVR    TX-OK TX-ERR TX-DRP
>>>> TX-OVR Flg
>>>> eth0       1500   0     5824     27      0      0     5056      0
>>>> 0      0 BMRU
>>>> lo        16436   0      127      0      0      0      127      0
>>>> 0      0 LRU
>>>> [root at enming-f11-pv-hpc-node0001 ~]# ps -ef | grep mpd
>>>> enming    1505     1  0 21:44 ?        00:00:00 python2.6
>>>> /home/enming/mpich2-install/bin/mpd.py --ncpus=1 -e -d
>>>>  root      1650  1576  0 22:07 pts/0    00:00:00 grep mpd
>>>> Node 2:
>>>> [root at enming-f11-pv-hpc-node0002 ~]# netstat -i
>>>> TX-OVR Flg
>>>>  eth0       1500   0     1504      7      0      0     1417      0
>>>> 0      0 BMRU
>>>> lo        16436   0       44      0      0      0       44      0
>>>> 0      0 LRU
>>>> Node 3:
>>>> [root at enming-f11-pv-hpc-node0003 ~]# netstat -i
>>>> TX-OVR Flg
>>>> eth0       1500   0     1520     12      0      0     1467      0
>>>> 0      0 BMRU
>>>> lo        16436   0       42      0      0      0       42      0
>>>> 0      0 LRU
>>>> Node 4:
>>>> [root at enming-f11-pv-hpc-node0004 ~]# netstat -i
>>>> TX-OVR Flg
>>>> eth0       1500   0     1528     10      0      0     1514      0
>>>> 0      0 BMRU
>>>> 0      0 LRU
>>>> Node 5:
>>>> [root at enming-f11-pv-hpc-node0005 ~]# netstat -i
>>>> TX-OVR Flg
>>>>  eth0       1500   0     1416     11      0      0     1412      0
>>>> 0      0 BMRU
>>>> 0      0 LRU
>>>> Node 6:
>>>> [root at enming-f11-pv-hpc-node0006 ~]# netstat -i
>>>> TX-OVR Flg
>>>> eth0       1500   0     1474      9      0      0     1504      0
>>>> 0      0 BMRU
>>>> 0      0 LRU
>>>> Engineering)
>>>> Alma Maters:
>>>> Height: 1.78 meters
>>>> Race: Chinese
>>>> Dialect: Hokkien
>>>> Country: Singapore
>>>> On Fri, Oct 30, 2009 at 2:07 PM, Mr. Teo En Ming (Zhang Enming) <
>>>>> All the six compute nodes are identical PV virtual machines.
>>>>> Engineering)
>>>>> Alma Maters:
>>>>> Height: 1.78 meters
>>>>> Race: Chinese
>>>>> Dialect: Hokkien
>>>>> Country: Singapore
>>>>> On Fri, Oct 30, 2009 at 2:04 PM, Mr. Teo En Ming (Zhang Enming) <
>>>>>> Hi,
>>>>>> I have changed the communication method from nemesis (high performance
>>>>>> network method) to ssm (socket for nodes and shared memory within a node) by
>>>>>> recompiling MPICH2. I have also pre-set the MAC address of the virtual
>>>>>> network adapter eth0 in each compute node (each compute node is a Xen
>>>>>> paravirtualized virtual machine) by configuring the vif directive in each PV
>>>>>> domU configuration file.
>>>>>> Additionally, I have also turned off iptables to facilitate
>>>>>> troubleshooting and communication between all mpd daemons in each node. SSH
>>>>>> without password is possible between all the compute nodes.
>>>>>> After having done all of the above, I am still encountering the
>>>>>> MPIEXEC 392 error.
>>>>>> mpiexec_enming-f11-pv-hpc-node0001 (mpiexec 392): no msg recvd from
>>>>>> Master Node / Compute Node 1:
>>>>>> [enming at enming-f11-pv-hpc-node0001 ~]$ ps -ef | grep mpd
>>>>>> enming    1499  1455  0 21:44 pts/0    00:00:00 grep mpd
>>>>>> [enming at enming-f11-pv-hpc-node0001 ~]$ mpdboot -n 6
>>>>>> [enming at enming-f11-pv-hpc-node0001 ~]$ mpdtrace -l
>>>>>> enming-f11-pv-hpc-node0001_34188 (192.168.1.254)
>>>>>> enming-f11-pv-hpc-node0005_39315 (192.168.1.250)
>>>>>> enming-f11-pv-hpc-node0004_46914 (192.168.1.251)
>>>>>> enming-f11-pv-hpc-node0003_36478 (192.168.1.252)
>>>>>> enming-f11-pv-hpc-node0002_42012 (192.168.1.253)
>>>>>> enming-f11-pv-hpc-node0006_55525 (192.168.1.249)
>>>>>> Compute Node 2:
>>>>>> [enming at enming-f11-pv-hpc-node0002 ~]$ mpdtrace -l
>>>>>> [enming at enming-f11-pv-hpc-node0002 ~]$ ps -ef | grep mpd
>>>>>> enming    1431     1  0 21:44 ?        00:00:00 python2.6
>>>>>> /home/enming/mpich2-install/bin/mpd.py -h enming-f11-pv-hpc-node0001 -p
>>>>>> 34188 --ncpus=1 -e -d
>>>>>> enming    1481  1436  0 21:46 pts/0    00:00:00 grep mpd
>>>>>> Compute Node 3:
>>>>>> [enming at enming-f11-pv-hpc-node0003 ~]$ mpdtrace -l
>>>>>> [enming at enming-f11-pv-hpc-node0003 ~]$ ps -ef | grep mpd
>>>>>> enming    1422     1  0 21:44 ?        00:00:00 python2.6
>>>>>> enming    1473  1427  0 21:47 pts/0    00:00:00 grep mpd
>>>>>> Compute Node 4:
>>>>>> [enming at enming-f11-pv-hpc-node0004 ~]$ mpdtrace -l
>>>>>> [enming at enming-f11-pv-hpc-node0004 ~]$ ps -ef | grep mpd
>>>>>> enming    1432     1  0 21:44 ?        00:00:00 python2.6
>>>>>> enming    1482  1437  0 21:47 pts/0    00:00:00 grep mpd
>>>>>> Compute Node 5:
>>>>>> [enming at enming-f11-pv-hpc-node0005 ~]$ mpdtrace -l
>>>>>> [enming at enming-f11-pv-hpc-node0005 ~]$ ps -ef | grep mpd
>>>>>> enming    1423     1  0 21:44 ?        00:00:00 python2.6
>>>>>> enming    1475  1429  0 21:48 pts/0    00:00:00 grep mpd
>>>>>> Compute Node 6:
>>>>>> [enming at enming-f11-pv-hpc-node0006 ~]$ mpdtrace -l
>>>>>> [enming at enming-f11-pv-hpc-node0006 ~]$ ps -ef | grep mpd
>>>>>> enming    1427     1  0 21:44 ?        00:00:00 python2.6
>>>>>> /home/enming/mpich2-install/bin/mpd.py -h enming-f11-pv-hpc-node0002 -p
>>>>>> 42012 --ncpus=1 -e -d
>>>>>> enming    1477  1432  0 21:49 pts/0    00:00:00 grep mpd
>>>>>> Should I increase the value of MPIEXEC_RECV_TIMEOUT in the mpiexec.py
>>>>>> file or should I change the communication method to sock?
>>>>>> MPIEXEC 392 error says no msg recvd from mpd when expecting ack of
>>>>>> request. So I am thinking that it could be taking very very long to receive
>>>>>> acknowledgement of request while the MPIEXEC_RECV_TIMEOUT value is too low.
>>>>>> Hence that causes the mpiexec 392 error in my case. I am using a virtual
>>>>>> network adapter and not physical Gigabit network adapter.
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# cat /proc/cpuinfo
>>>>>> processor    : 0
>>>>>> vendor_id    : GenuineIntel
>>>>>> cpu family    : 6
>>>>>> model        : 23
>>>>>> model name    : Pentium(R) Dual-Core  CPU      E6300  @ 2.80GHz
>>>>>> stepping    : 10
>>>>>> cpu MHz        : 2800.098
>>>>>> cache size    : 2048 KB
>>>>>> fpu        : yes
>>>>>> fpu_exception    : yes
>>>>>> cpuid level    : 13
>>>>>> wp        : yes
>>>>>> flags        : fpu de tsc msr pae cx8 cmov pat clflush mmx fxsr sse
>>>>>> sse2 ss ht syscall nx lm constant_tsc rep_good pni ssse3 cx16 hypervisor
>>>>>> lahf_lm
>>>>>> bogomips    : 5600.19
>>>>>> clflush size    : 64
>>>>>> cache_alignment    : 64
>>>>>> address sizes    : 36 bits physical, 48 bits virtual
>>>>>> power management:
>>>>>> processor    : 1
>>>>>> cpu family    : 6
>>>>>> model        : 23
>>>>>> stepping    : 10
>>>>>> cpu MHz        : 2800.098
>>>>>> fpu        : yes
>>>>>> fpu_exception    : yes
>>>>>> cpuid level    : 13
>>>>>> wp        : yes
>>>>>> lahf_lm
>>>>>> bogomips    : 5600.19
>>>>>> clflush size    : 64
>>>>>> power management:
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# cat /proc/meminfo
>>>>>> MemTotal:         532796 kB
>>>>>> MemFree:          386156 kB
>>>>>> Buffers:           12904 kB
>>>>>> Cached:            48864 kB
>>>>>> SwapCached:            0 kB
>>>>>> Active:            34884 kB
>>>>>> Inactive:          43252 kB
>>>>>> Active(anon):      16504 kB
>>>>>> Inactive(anon):        0 kB
>>>>>> Active(file):      18380 kB
>>>>>> Inactive(file):    43252 kB
>>>>>> Unevictable:           0 kB
>>>>>> Mlocked:               0 kB
>>>>>> SwapTotal:       2195448 kB
>>>>>> SwapFree:        2195448 kB
>>>>>> Dirty:                12 kB
>>>>>> Writeback:             0 kB
>>>>>> AnonPages:         16444 kB
>>>>>> Mapped:             8864 kB
>>>>>> Slab:              10528 kB
>>>>>> SReclaimable:       4668 kB
>>>>>> SUnreclaim:         5860 kB
>>>>>> PageTables:         2996 kB
>>>>>> NFS_Unstable:          0 kB
>>>>>> Bounce:                0 kB
>>>>>> WritebackTmp:          0 kB
>>>>>> CommitLimit:     2461844 kB
>>>>>> Committed_AS:      73024 kB
>>>>>> VmallocTotal:   34359738367 kB
>>>>>> VmallocUsed:        6332 kB
>>>>>> VmallocChunk:   34359724899 kB
>>>>>> HugePages_Total:       0
>>>>>> HugePages_Free:        0
>>>>>> HugePages_Rsvd:        0
>>>>>> HugePages_Surp:        0
>>>>>> Hugepagesize:       2048 kB
>>>>>> DirectMap4k:      524288 kB
>>>>>> DirectMap2M:           0 kB
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# lspci -v
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# lsusb
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# ifconfig eth0
>>>>>> eth0      Link encap:Ethernet  HWaddr 00:16:3E:69:E9:11
>>>>>>           inet addr:192.168.1.254  Bcast:192.168.1.255
>>>>>> Mask:255.255.255.0
>>>>>>           inet6 addr: fe80::216:3eff:fe69:e911/64 Scope:Link
>>>>>>           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
>>>>>>           RX packets:5518 errors:26 dropped:0 overruns:0 frame:0
>>>>>>           TX packets:4832 errors:0 dropped:0 overruns:0 carrier:0
>>>>>>           collisions:0 txqueuelen:1000
>>>>>>           RX bytes:872864 (852.4 KiB)  TX bytes:3972981 (3.7 MiB)
>>>>>>           Interrupt:17
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# ethtool eth0
>>>>>> Settings for eth0:
>>>>>>     Link detected: yes
>>>>>> TX-DRP TX-OVR Flg
>>>>>> eth0       1500   0     5589     26      0      0     4875      0
>>>>>> 0      0 BMRU
>>>>>> 0      0 LRU
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# uname -a
>>>>>> Linux enming-f11-pv-hpc-node0001 2.6.29.4-167.fc11.x86_64 #1 SMP Wed
>>>>>> May 27 17:27:08 EDT 2009 x86_64 x86_64 x86_64 GNU/Linux
>>>>>> You have new mail in /var/spool/mail/root
>>>>>> [root at enming-f11-pv-hpc-node0001 ~]# cat /etc/redhat-release
>>>>>> Fedora release 11 (Leonidas)
>>>>>> Please advise.
>>>>>> Thank you.
>>>>>> Engineering)
>>>>>> Alma Maters:
>>>>>> Height: 1.78 meters
>>>>>> Race: Chinese
>>>>>> Dialect: Hokkien
>>>>>> Country: Singapore
>>>>>> On Fri, Oct 30, 2009 at 11:55 AM, Mr. Teo En Ming (Zhang Enming) <
>>>>>>> Hi,
>>>>>>> I am getting the same mpiexec 392 error message as Kenneth Yoshimoto
>>>>>>> from the San Diego Supercomputer Center. His mpich-discuss mailing list
>>>>>>> topic URL is
>>>>>>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2009-October/005882.html
>>>>>>> I have actually already performed the 2-node mpdcheck utility test as
>>>>>>> described in Appendix A.1 of the MPICH2 installation guide. I could start
>>>>>>> the ring of mpd on the 2-node test scenario using mpdboot successfully as
>>>>>>> well.
>>>>>>> 薛正华 (ID: zhxue123) from China reported solving the mpiexec 392
>>>>>>> error. According to 薛正华, the cause of the mpiexec 392 error is the absence
>>>>>>> of high performance network in his environment. He had changed the default
>>>>>>> communication method from nemesis to ssm and also increased the value of
>>>>>>> MPIEXEC_RECV_TIMEOUT in the mpiexec.py python source code. The URL of his
>>>>>>> report is at
>>>>>>> http://blog.csdn.net/zhxue123/archive/2009/08/22/4473089.aspx
>>>>>>> Could this be my problem also?
>>>>>>> Thank you.
>>>>>>> BEng(Hons)(Mechanical Engineering)
>>>>>>> Alma Maters:
>>>>>>> Height: 1.78 meters
>>>>>>> Race: Chinese
>>>>>>> Dialect: Hokkien
>>>>>>> Country: Singapore
>>>>>>> On Fri, Oct 30, 2009 at 11:09 AM, Rajeev Thakur <thakur at mcs.anl.gov>wrote:
>>>>>>>>  You need to do the mpdcheck tests with every pair of compute
>>>>>>>> nodes. Or to isolate the problem, try running on a smaller set of nodes
>>>>>>>> first and increase it one at a time until it fails.
>>>>>>>> Rajeev
>>>>>>>> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
>>>>>>>> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Mr. Teo En Ming
>>>>>>>> (Zhang Enming)
>>>>>>>> *Sent:* Thursday, October 29, 2009 2:35 PM
>>>>>>>> *To:* mpich-discuss at mcs.anl.gov
>>>>>>>> *Subject:* [mpich-discuss] (mpiexec 392): no msg recvd from mpd
>>>>>>>> when expectingack of request
>>>>>>>> Hi,
>>>>>>>> I have just installed MPICH2 in my Xen-based virtual machines.
>>>>>>>> My hardware configuration is as follows:
>>>>>>>> Processor: Intel Pentium Dual Core E6300 @ 2.8 GHz
>>>>>>>> Motherboard: Intel Desktop Board DQ45CB BIOS 0093
>>>>>>>> Memory: 4X 2GB Kingston DDR2-800 CL5
>>>>>>>> My software configuration is as follows:
>>>>>>>> Xen Hypervisor / Virtual Machine Monitor Version: 3.5-unstable
>>>>>>>> Jeremy Fitzhardinge's pv-ops dom0 kernel: 2.6.31.4
>>>>>>>> Host Operating System: Fedora Linux 11 x86-64 (SELinux disabled)
>>>>>>>> Guest Operating Systems: Fedora Linux 11 x86-64 paravirtualized (PV)
>>>>>>>> domU guests (SELinux disabled)
>>>>>>>> I have successfully configured, built and installed MPICH2 in a F11
>>>>>>>> PV guest OS master compute node 1 with NFS server (MPICH2 bin subdirectory
>>>>>>>> exported). The rest of the 5 compute nodes have access to the MPICH2
>>>>>>>> binaries by mounting NFS share from node 1. Please see attached c.txt, m.txt
>>>>>>>> and mi.txt. With Xen virtualization, I have created 6 F11 linux PV guests to
>>>>>>>> simulate 6 HPC compute nodes. The network adapter (NIC) in each guest OS is
>>>>>>>> virtual. The Xen networking type is bridged. Running "lspci -v" and lsusb in
>>>>>>>> each guest OS does not show up anything.
>>>>>>>> According to Appendix A troubleshooting section of the MPICH2
>>>>>>>> install guide, I have verified that the 2-node test scenario with "mpdcheck
>>>>>>>> -s" and "mpdcheck -c" is working. The 2 nodes each acting as server and
>>>>>>>> client respectively can communicate with each other without problems. Both
>>>>>>>> nodes can communicate with each other in server and client modes
>>>>>>>> respectively. I have also tested mpdboot with the 2-node scenario and the
>>>>>>>> ring of mpd is working.
>>>>>>>> After the troubleshooting process, I have successfully created a
>>>>>>>> ring of mpd involving 6 compute nodes. "mpdtrace -l" successfully lists all
>>>>>>>> the 6 nodes. However, when I want to run a job with mpiexec, it gives me the
>>>>>>>> following error:
>>>>>>>> [enming at enming-f11-pv-hpc-node0001 ~]$ mpiexec -n 2 examples/cpi
>>>>>>>> I have also tried starting the mpd ring with the root user but I
>>>>>>>> still encounter the same error above.
>>>>>>>> Thank you.
>>>>>>>> PS. config.log is also attached.
>>>>>>>> Alma Maters:
>>>>>>>> Height: 1.78 meters
>>>>>>>> Race: Chinese
>>>>>>>> Dialect: Hokkien
>>>>>>>> Country: Singapore
>>>>>>>> _______________________________________________
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091030/5f53d74f/attachment-0001.htm>
