[mpich-discuss] installation problem
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Oct 29 10:47:54 CDT 2009
Great! Let us know if you need any help.
(PS: Since you are added to the ticket, you will be notified when the requirement for XP SP3 is removed.)
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Thursday, October 29, 2009 10:41:45 AM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] installation problem
Now that I have installed SP3, MPICH2 is installed OK!
Thank you for your help!
Victor Gavron
Senior Advisor, LANSCE-DO,
MS-H845
505-667-5475
Foreign: TSPA
-----Original Message-----
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Thursday, October 29, 2009 8:30 AM
To: Gavron, Victor
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] installation problem
Are you sure you have Win XP SP3 installed ? You should not get this error message after installing XP SP3. Type "winver" at the command prompt to get the version of windows installed in your machine.
(PS: We are removing this dependency for SP3 in our next release - See ticket http://trac.mcs.anl.gov/projects/mpich2/ticket/776. I have already added you in this ticket.)
Jayesh
Sent: Thursday, October 29, 2009 8:21:41 AM GMT -06:00 US/Canada Central
Responded with error message "The procedure entry point GetLogicalPProcessorInformation could not be located in the dynamic link library KERNEL32.DLL"
Sent: Wednesday, October 28, 2009 4:23 PM
To: Gavron, Victor
Subject: [mpich-discuss] installation problem
Please find attached a zip file at the downloads page (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/temp/MPICH2.zip) containing the MPICH2 1.2 libs/exes/dlls (32-bit). Please follow the instructions below to install MPICH2 manually using the zip file,
# Unzip the contents of zip file into "c:\program files\mpich2" folder.
# Copy the dll files in the lib folder to your system32 folder (copy c:\progra~1\mpich2\lib\*.dll c:\windows\system32).
# Install the process manager manually (smpd -install).
Let us know the results.
Jayesh
