[mpich-discuss] Errors while testing MPICH2 on Vista
Jayesh Krishna jayesh at mcs.anl.gov
Mon Oct 26 13:05:22 CDT 2009
 Where you able to install MPICH2 successfully?
 Check the status of smpd using the "smpd -status" command. If smpd is not installed on your system, open a command prompt "as administrator" and install smpd manually using the "smpd -install -phrase behappy" command.
 Let us know the results.
Jayesh
----- Original Message -----
Sent: Saturday, October 24, 2009 2:39:26 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Errors while testing MPICH2 on Vista
I am trying to test a fresh installation of MPICH2 (version 1.2) on Vista32 and get the following errors:
c:\temp>"c:\Program Files\MPICH2\bin\mpiexec.exe" -n 4 cpi.exe
Please specify an authentication passphrase for smpd: < I type here the passphrase, e.g. behappy >
Error while connecting to host, No connection could be made because the target
machine actively refused it. (10061)
Connect on sock (host=user-PC, port=8676) failed, exhaused all end points
Unable to connect to 'user-PC:8676',
sock error: Error = -1
I will appreciate any comment.
--Guy
mpich-discuss mailing list
