[mpich-discuss] General Scalability Question - correction
Hiatt, Dave M
dave.m.hiatt at citi.com
Mon Oct 26 10:46:13 CDT 2009
Linux defaults to 1024 sockets! Sorry.
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov]On Behalf Of Robertson, Andrew
Sent: Monday, October 26, 2009 10:30 AM
Subject: [mpich-discuss] General Scalability Question
Folks,
Our IT staff is not particularly knowledgeable about parallel computing. Their current upgrade plan centers around quad/quad or dual/hex boxes which would have 16 or 12 cores respectively. I have no doubt that such a machine would run a parallel job efficiently. My question is how well can I harness multiple boxes together?
The applications are all CFD (FLUENT, GASP, STAR, VULCAN). I am talking to the various software vendors about this but would like some info from the programming community.
Assuming the same memory per core am I better off with
High core count (12-16) boxes on a gigabit switch
Lower core count (2 -4) boxes on an infiniband switch.
I understand that if I configure mpich correctly it will use shared memory on the mutli-core multi-processor boxes. If I end up with the high core count boxes, should I spec the frontside bus (or whatever it is called now) as high as possible??
I also have concerns that a single power supply failure takes out more cores, though perhaps that is not such a problem
Any information is greatly appreciated
Thanks
Andy
Andrew Robertson P.E.
CFD Analyst
GASL Operations
Tactical Propulsion and Controls
ATK
77 Raynor Avenue
Ronkokoma NY 11779
631-737-6100 Ext 120
Fax: 631-588-7023
www.atk.com<file://www.atk.com>
!! Knowledge and Thoroughness Baby !!
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091026/840a1f1f/attachment.htm>
