[mpich-discuss] Communication between child node and parent node
Dave Goodell
goodell at mcs.anl.gov
Wed Oct 21 16:55:12 CDT 2009
MPI_Comm_spawn is a collective operation. So if I understand your
question correctly, then make sure that you pass MPI_COMM_WORLD as the
"comm" parameter to MPI_Comm_spawn. Then the resulting
intercommunicator that is returned by MPI_Comm_spawn on the parent and
MPI_Comm_get_parent will connect the two MPI_COMM_WORLDs (one in the
parent and one in the child). You can communicate directly via the
intercommunicator if you wish, or you could merge the
intercommunicator into a new intracommunicator via MPI_Intercomm_merge.
For a good explanation of dynamic processes in MPI, I would recommend
chapter 7 (Dynamic Process Management) of the "Using MPI-2" book: http://www.amazon.com/Using-MPI-2-Scientific-Engineering-Computation/dp/0262571331
The MPI-2.2 Standard itself is also a reasonable guide to the dynamic
process functionality, although it is slightly more oriented towards
MPI implementers: http://www.mpi-forum.org/docs/mpi-2.2/mpi22-report.pdf
-Dave
On Oct 21, 2009, at 4:35 PM, abhishek pandey wrote:
> Another question,
> I have two process at start, lets say A, B in COMM_WORLD and I
> start some child processes from A.
> Now can any child process communicate with process B of COMM_WORLD ?
> If this is possible then please let me know the way.
> Thanks,
> Abhishek
> On Thu, Oct 22, 2009 at 3:43 AM, abhishek pandey
> <hipandey at gmail.com> wrote:
> Thanks Dave.
> -Abhishek
> On Thu, Oct 22, 2009 at 12:59 AM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> Use MPI_Comm_get_parent to get the intercommunicator handle for
> communicating with your parent. See the MPI-2.2 Standard, section
> 10.3.2, page 312.
> -Dave
> On Oct 21, 2009, at 5:52 AM, abhishek pandey wrote:
> Hi,
> How can a child process can communicate with its parent ? I am
> spawning the processes from a node using MPI_Comm_spawn.
> Thanks,
> Abhishek
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
