[mpich-discuss] Problems with mpiexec.hydra in mpich2-1.2
Bryan Putnam
bfp at purdue.edu
Mon Oct 19 10:20:40 CDT 2009
On Mon, 19 Oct 2009, Bryan Putnam wrote:
> On Mon, 19 Oct 2009, Pavan Balaji wrote:
> > Bryan,
> > > I've recently installed mpich2-1.2 on three of our Linux clusters, and
> > > have found that mpiexec.hydra is no longer working on any of them. One is
> > > a Chelsio cluster, the other two are Infiniband, and all three are running
> > > RHEL5.
> > > The first few lines of the errors I'm seeing are appended below.
> > > Note that if I use the same executable built with mpich2-1.2, and then use
> > > the previous mpich2-1.1.1p1 version of mpiexec.hydra. it still works fine.
> > I believe you are running into this issue:
> > http://trac.mcs.anl.gov/projects/mpich2/ticket/893
> > This has been fixed, but the fix didn't make it into mpich2-1.2; it'll
> > be in 1.2.1. In the meanwhile, can you try using PBS as:
> > % mpiexec.hydra -rmk pbs ./hellof
> > .. and let us know if that works OK?
> > Thanks,
> > -- Pavan
> Pavan,
> Using
> mpiexec.hydra -f $PBS_NODEFILE -rmk pbs -np 4 ./hellof
> did not have any effect. If the fix is in mpich2-1.2.1 that sounds good.
> We can still use the OSC mpiexec, or the mpdboot method, or the
> mpiexec.hydra from mpich2-1.1.1p1.
mpiexec.hydra -rmk ./hellof
does appear to work correctly if I do something like
qsub -I -l select=2:ncpus=1:mpiprocs=1,place=scatter
In that case, since there is only 1 processor per node, each node name
only occurs once in the PBS_NODEFILE.
Bryan
> Thanks,
> Bryan
> > Pavan Balaji
> > http://www.mcs.anl.gov/~balaji
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
