[mpich-discuss] relocation R_X86_64_32S against `a local symbol' can not be used when making a shared object; recompile with -fPIC
Mário Costa mario.silva.costa at gmail.com
Mon Oct 19 08:53:35 CDT 2009
Maybe if you can post the build script or part of it where you
compile, and have the flag and library definition e could try to
identify what might be wrong...
Mario
On Mon, Oct 19, 2009 at 2:40 PM, Luís Miranda <luistm at gmail.com> wrote:
> Well, thanks for the suggestion, but the problem is still happening.
> Thanks
> 2009/10/19 Mário Costa <mario.silva.costa at gmail.com>
>> Hi,
>> The problem is that the irradiancecache.so library is dynamic, and you
>> are using mpich static library version libpmpich++.a.
>> Either you are compiling with -static with gnu, or you are specifying
>> the static library libpmpich++.a.
>> If that is the case remove the -static flag from gnu compiler in the
>> byuild script, or use -lmpich++ instead of the library ...
>> Hope this helps,
>> Regards,
>> Mário
>> On Mon, Oct 19, 2009 at 11:56 AM, Luís Miranda <luistm at gmail.com> wrote:
>> > Hi
>> > I'm having this problem, when i try to compile my software in a rocks4.2
>> > cluster.
>> > /usr/bin/ld: /opt/mpich/myrinet/gnu/lib/libpmpich++.a(intercepts.o):
>> > making
>> > /opt/mpich/myrinet/gnu/lib/libpmpich++.a: could not read symbols: Bad
>> > value
>> > collect2: ld returned 1 exit status
>> > make: *** [bin/irradiancecache.so] Error 1
>> > A solution to the problem, isto to compile the mpich with CFLAGS=-fPIC,
>> > but
>> > i can't do this, becouse i'm not the cluster's admin.
>> > Anyone knows any other workaround to the problem?
>> > Thanks
>> > _______________________________________________
>> > mpich-discuss mailing list
>> > mpich-discuss at mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Mário Costa
>> Laboratório Nacional de Engenharia Civil
>> LNEC.CTI.NTIEC
>> Avenida do Brasil 101
>> 1700-066 Lisboa, Portugal
>> Tel : ++351 21 844 3911
