[mpich-discuss] relocation R_X86_64_32S against `a local symbol' can not be used when making a shared object; recompile with -fPIC
Mário Costa
mario.silva.costa at gmail.com
Mon Oct 19 06:12:48 CDT 2009
The problem is that the irradiancecache.so library is dynamic, and you
are using mpich static library version libpmpich++.a.
Either you are compiling with -static with gnu, or you are specifying
the static library libpmpich++.a.
If that is the case remove the -static flag from gnu compiler in the
byuild script, or use -lmpich++ instead of the library ...
Hope this helps,
Mário
On Mon, Oct 19, 2009 at 11:56 AM, Luís Miranda <luistm at gmail.com> wrote:
> Hi
> I'm having this problem, when i try to compile my software in a rocks4.2
> cluster.
> /usr/bin/ld: /opt/mpich/myrinet/gnu/lib/libpmpich++.a(intercepts.o):
> /opt/mpich/myrinet/gnu/lib/libpmpich++.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> make: *** [bin/irradiancecache.so] Error 1
> A solution to the problem, isto to compile the mpich with CFLAGS=-fPIC, but
> i can't do this, becouse i'm not the cluster's admin.
> Anyone knows any other workaround to the problem?
> Thanks
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Mário Costa
Laboratório Nacional de Engenharia Civil
LNEC.CTI.NTIEC
Avenida do Brasil 101
1700-066 Lisboa, Portugal
Tel : ++351 21 844 3911
