[mpich-discuss] Can ch3:nemesis:mx use both MX and TCP networks ?
Scott Atchley
atchley at myri.com
Tue Oct 13 16:36:37 CDT 2009
On Oct 13, 2009, at 2:18 PM, Dave Goodell wrote:
>>>> I always thought (but never tested) that the ch3:nemesis:mx
>>>> cmehannel has the ability to independently select either MX or
>>>> TCP to communicate between any pair of MPI processes when shared
>>>> memory communication isn’t possible (e.g. the two process run on
>>>> different nodes).
>>> When Nemesis:Mx is selected, only MX can be used.
>> Not only it is a runtime selection, but it is a compile time
>> selection.
>> You could compile your application against a shared MPICH2 Nemesis/
>> TCP lib. You could then run that binary and use LD_LIBRARY_PATH to
>> select either a Nem/TCP or a Nem/MX libmpich.so.
> That would work, but it's a bit heavyweight. I believe that
> switching between TCP or MX at runtime is currently possible via an
> environment variable as documented here: http://wiki.mcs.anl.gov/mpich2/index.php/Nemesis_Runtime_Netmod_Selection
> Skimming the doc it looks like some of the names are a bit stale (s/
> newtcp,gm/tcp,mx/g), but the basic idea should still hold and the
> environment variable definitely still has the same name. I'll take
> a quick pass over that doc soon.
Dave,
Interesting, I did not know this existed. I had not run across it in
the README or the manual.
Thanks!
Scott
