[mpich-discuss] cannot run mpich on multiple hosts due toauthentication issues
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Oct 13 15:15:46 CDT 2009
Good to know your problem is solved.
(PS: As you mentioned in your email, pypar might not work with MPICH2 off
the shelf. However it looks like an MPI app and should ideally work with
MPICH2. I would strongly recommend using MPICH2 if possible - MPICH is
old)
Jayesh
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jordan Atlas
Sent: Tuesday, October 13, 2009 11:56 AM
Subject: Re: [mpich-discuss] cannot run mpich on multiple hosts due
Hi Jayesh,
Unfortunately I am using a python package (pypar) that requires MPICH
(my understanding is that it's incompatible with MPICH2). So I'm trying
to get MPICH working in order to later use pypar (note that pypar and
mpich work fine on one machine).
However, disabling the windows firewall on each machine seems to have
fixed the problem!
Thank you for your help,
--Jordan
Jayesh Krishna wrote:
MPICH 1.2.5 is very old. Try using the latest stable version (1.2) of
MPICH2 (available at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=down
loads) and let us know if you still have problems.
Also make sure that you have upgraded WinXP to the latest service pack
(SP3).
(PS: Make sure that you have turned off the windows firewall on your
machines - or look at the windows developer's guide for details on how to
configure MPICH2 with the windows firewall.)
Jayesh
-----Original Message-----
Sent: Monday, October 12, 2009 10:52 AM
Subject: [mpich-discuss] cannot run mpich on multiple hosts due
Hello MPICH list,
I am having an issue similar to that described at
https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2006-March/001207.ht
ml
, but I don't see any responses to this inquiry.
I am using MPICH 1.2.5 on Windows XP.
I can run the cpi.exe example for multiple processes on my host machine
(e.g. mpirun -np 4 cpi.exe).
I am trying to use 2 machines using the command:
C:\Temp>mpirun -np 4 -logon -machinefile machines.txt cpi.exe
When I do this, I get the output:
Mpd needs an account to launch processes with:
account (domain\user): Jordan
password:
easy_connect::WSAETIMEDOUT error, re-attempting
easy_connect(jca33-305-desktop-2)
Error: ConnectToMPD(jca33-305-desktop-2:8675): easy_connect failed:
error 10060, A connection attempt failed because the connected party did
not properly respond after a period of time, or established connection
failed because connected host has failed to respond.
MPIRunLaunchProcess: Connect to jca33-305-desktop-2 failed, error 10060
aborting...
Error 10035, process 2:
SendInitDataToRoot: recv ack failed
A non-blocking socket operation could not be completed immediately.
If I do it without the -logon option I get the same results (without the
prompt for username and password).
I don't have access to a domain account, but both machines have the user
'Jordan' with the same password. Also, both machine names are in the
machines.txt file.
Does anyone have any suggestions?
--Jordan Atlas
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091013/439ee53a/attachment-0001.htm>
