[mpich-discuss] Errors while install MPICH on a 64bit cluster
Anthony Chan
chan at mcs.anl.gov
Tue Oct 13 00:50:47 CDT 2009
All your attached outputs are still from mpich-1.
A.Chan
----- "Lei Yang" <lei.miren.yang at gmail.com> wrote:
> hi, all,
> again, I run mpich2 this time.
> I still got similar error
> mainly about libraries (fortran and C compiler) don't match each
> other..
> i tried both cc=gcc or cc=g++ ...but no success.
> My machine is 64bit cluster, ifort is 10.0.023 for x86-64 system.
> /usr/bin/ld: warning: i386 architecture of input file
> `/opt/mpich/lib/libmpich.a(initfcmn.o)' is incompatible with
> i386:x86-64
> output
> `/opt/mpich/lib/libmpich.a(initfdte.o)' is incompatible with
> i386:x86-64
> output
> which could be the reason (I think...) for this error
> ld: skipping incompatible /opt/mpich/lib/libmpich.a when searching
> for
> -lmpich
> ld: cannot find -lmpich
> Attached are three files for MPICH2 installation.
> Thanks a lot!
> Lei
