[mpich-discuss] cannot run mpich on multiple hosts due to authentication issues
Jordan Atlas jca33 at cornell.edu
Mon Oct 12 10:51:39 CDT 2009
Hello MPICH list,
I am having an issue similar to that described at
https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2006-March/001207.html
, but I don't see any responses to this inquiry.
I am using MPICH 1.2.5 on Windows XP.
I can run the cpi.exe example for multiple processes on my host machine
(e.g. mpirun -np 4 cpi.exe).
I am trying to use 2 machines using the command:
C:\Temp>mpirun -np 4 -logon -machinefile machines.txt cpi.exe
When I do this, I get the output:
Mpd needs an account to launch processes with:
account (domain\user): Jordan
password:
easy_connect::WSAETIMEDOUT error, re-attempting
easy_connect(jca33-305-desktop-2)
Error: ConnectToMPD(jca33-305-desktop-2:8675): easy_connect failed:
error 10060, A connection attempt failed because the connected party did
not properly respond after a period of time, or established connection
failed because connected host has failed to respond.
MPIRunLaunchProcess: Connect to jca33-305-desktop-2 failed, error 10060
aborting...
Error 10035, process 2:
   SendInitDataToRoot: recv ack failed
   A non-blocking socket operation could not be completed immediately.
If I do it without the -logon option I get the same results (without the
prompt for username and password).
I don't have access to a domain account, but both machines have the user
'Jordan' with the same password.  Also, both machine names are in the
machines.txt file.
Does anyone have any suggestions?
--Jordan Atlas
