[mpich-discuss] Errors while install MPICH on a 64bit cluster
Lei Yang
lei.miren.yang at gmail.com
Mon Oct 12 04:19:49 CDT 2009
Hello,
This is Lei Yang (at Guang Zhou, China)
I am trying to install MPICH or MPICH2 on our cluster, but many errors came
up, please help me!!
attached c.txt, m.txt, mi.txt are for configuration, make and make install
results.
(i has been trying to install this for days, please do help!!~)
I think the main issue is that it didn't pass configure test, and showed
'can't find -lfmpich'
I use intel fortran compiler.
my .bashrc file is like this
export F90=/opt/intel/fc/10.0.023/bin/ifort
export FC=F90
export CC=gcc
export F77=F90
and my cluster information is:
Processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel(R) Xeon(R) CPU E5430 @ 2.66GHz
stepping : 10
cpu MHz : 2660.002
cache size : 6144 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov
pat pse36 clflush d
ts acpi mmx fxsr sse sse2 ss ht tm syscall nx lm constant_tsc pni monitor
ds_cpl vmx est tm2 cx16 x
tpr lahf_lm
bogomips : 5323.69
clflush size : 64
cache_alignment : 64
address sizes : 38 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2660.002
physical id : 0
siblings : 4
core id : 2
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
pat pse36 clflush d
tpr lahf_lm
bogomips : 5320.00
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2660.002
physical id : 0
siblings : 4
core id : 1
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
pat pse36 clflush d
tpr lahf_lm
bogomips : 5320.06
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2660.002
physical id : 0
siblings : 4
core id : 3
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
pat pse36 clflush d
tpr lahf_lm
bogomips : 5320.01
clflush size : 64
power management:
Thanks very much!!!
LED
The South China Sea Institute of Oceanology, CAS
Guangzhou, China, 510301
Tel:86-20-89023199
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091012/6c2b50f7/attachment-0001.htm>
rm -rf serv_p4 *.o clientlib.a lclient
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich1
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory mpi-io/fortran
cleaning directory test
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp large_file psimple error status noncontig_coll2 fcoll_test fperf fmisc pfcoll_test
Making clean in .
test -z "-r *~ " || rm -f -r *~
Making clean in contrib
Making clean in test_suite
test -z "mpi2c++_test" || rm -f mpi2c++_test
rm -f *.o core *.core
Making clean in examples
test -z "chapter_10_mpi2 hello_world pi ring topology user_bcast" || rm -f chapter_10_mpi2 hello_world pi ring topology user_bcast
test -z "" || rm -f
Making clean in balky
Making clean in src
Making clean in .
test -z "libpmpi++.a" || rm -f libpmpi++.a
Making clean in mpi2c++
rm -f *.ti *.ii
cd src && make --no-print-directory clean
cleaning src/pt2pt
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/pt2pt/*.o
cleaning src/env
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/env/*.o
cleaning src/dmpi
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/dmpi/*.o
cleaning src/util
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/util/*.o
cleaning src/context
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/context/*.o
cleaning src/coll
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/coll/*.o
cleaning src/topol
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/topol/*.o
cleaning src/profile
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/profile/*.o
cleaning src/misc2
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/misc2/*.o
cleaning src/external
rm -f *.o *~ /home/yanglei/mpich-1.2.7p1/src/external/*.o
cleaning mpid/ch_p4
rm -f *~ adi2recv.o adi2send.o adi2init.o adi2probe.o adi2ssend.o adi2hsend.o adi2hrecv.o adi2pack.o adi2mpack.o adi2hssend.o bswap2.o adi2req.o adi2cancel.o chbeager.o chbrndv.o chdebug.o chchkdev.o chshort.o chflow.o chinit.o chnodename.o chhetero.o chtick.o p4priv.o queue.o cmnargs.o tr2.o sbcnst2.o session.o chpackflow.o objtrace.o calltrace.o chcancel.o ch_ldebug.o libmpid.a mprerr.o
rm -f /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/*.o
(cd ./p4; if [ -s Makefile ] ; then make clean; \
rm -f lib/libp4.a ; fi )
cleaning lib
rm -f *~ *.o *.bak tags TAGS core /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/*.o
cleaning alog
rm -f *~ *.o *.bak tags TAGS core /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/alog/*.o
cleaning usc
rm -f *~ *.o *.bak tags TAGS core /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/usc/*.o
cleaning include
cleaning bin
cleaning servers
rm -f *~ *.o *.bak tags TAGS core /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/servers/*.o
cleaning contrib
cleaning messages
cleaning monitors
cleaning lib_f
cleaning messages_f
cleaning contrib_f
cleaning doc
cleaning usc/usctest
cleaning misc
rm -f *~ *.o *.bak
cleaning examples
rm -f sendchar *.o
Making clean in directory test
Making clean in directory pt2pt
Making clean in directory coll
Making clean in directory topol
Making clean in directory env
Making clean in directory context
Making clean in directory profile
Making clean in directory io
Making clean in directory perftest
test -z "mpptest goptest buflimit " || rm -f mpptest goptest buflimit
rm -f tunepkt pktuse copytest vectest stress ctest cluster tcomm
rm -f work.pc work.pcl
cleaning examples/basic
rm -f *.o *~ PI* cpi systest srtest fpi cpilog cpi_autolog hello++ iotest pi3f90 upshot rdb.* startup.* core
rm -f hello++.ti hello++.ii
cleaning examples/test/pt2pt
cleaning examples/test/coll
cleaning examples/test/topol
cleaning examples/test/context
cleaning examples/test/env
cleaning examples/test/profile
cleaning examples/perftest
cleaning src/infoexport
rm -f *.o
rm -f *.i
rm -f *.s
rm -f *.cxx.log
rm -f *.cxx.errors
rm -f libtvmpich.so.1.0
rm -f libtvmpich.so*
rm -f /home/yanglei/mpich-1.2.7p1/src/infoexport/*.o
rm -f *~ *.o aditest1 aditest2 aditest3 aditest4 aditest5 aditest6 aditest7 aditest8 aditest9 aditest10 aditest11 aditest12 aditest13 timers trunc
rm -f /home/yanglei/tmp/mpich1.2.7/lib/lib*.a
rm -f /home/yanglei/tmp/mpich1.2.7/lib/shared/lib*.so*
make --no-print-directory mpi-modules
make --no-print-directory mpilib
making mpir in directory mpid/ch_p4
(cd ./p4 && \
make p4inmpi MPIARCH=LINUX MPILIBNAME=mpich)
making p4 on architecture=LINUX
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_globals.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_MD.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_error.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_args.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_alloc.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_debug.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_procgroup.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_tsr.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_mon.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_broadcast.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_utils.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_bm.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_rm.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_sock_util.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_sock_cr.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_sock_conn.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_sock_sr.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_sock_list.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_secure.c
gcc -I../../../../include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -DRSHCOMMAND='"/usr/bin/ssh"' -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -I.. -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/lib/p4_shmem_sr.c
ar lruv /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a p4_globals.o p4_MD.o p4_error.o p4_args.o p4_alloc.o p4_debug.o p4_procgroup.o p4_tsr.o p4_mon.o p4_broadcast.o p4_utils.o p4_bm.o p4_rm.o p4_sock_util.o p4_sock_cr.o p4_sock_conn.o p4_sock_sr.o p4_sock_list.o p4_secure.o p4_shmem_sr.o
ar: creating /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a
a - p4_globals.o
a - p4_MD.o
a - p4_error.o
a - p4_args.o
a - p4_alloc.o
a - p4_debug.o
a - p4_procgroup.o
a - p4_tsr.o
a - p4_mon.o
a - p4_broadcast.o
a - p4_utils.o
a - p4_bm.o
a - p4_rm.o
a - p4_sock_util.o
a - p4_sock_cr.o
a - p4_sock_conn.o
a - p4_sock_sr.o
a - p4_sock_list.o
a - p4_secure.o
a - p4_shmem_sr.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a
gcc -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DLINUX -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/alog -I../../../../include -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/alog/alog.c
gcc -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DLINUX -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/alog -I../../../../include -I../include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/alog/alogf.c
ar lruv /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a alog.o alogf.o
a - alog.o
a - alogf.o
gcc -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DLINUX -DHAVE_RPC_RPC_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_ARPA_INET_H=1 -DHAVE_SYS_SOCKETVAR_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1 -DHAVE_TERMIO_H=1 -DHAVE_TERMIOS_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_WAIT_H=1 -DTIME_WITH_SYS_TIME=1 -DHAVE_TIME_H=1 -DBOTH_STRING_INCS=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DUSE_STDARG=1 -DHAVE_SIGPROCMASK=1 -DHAVE_SIGEMPTYSET=1 -DHAVE_SIGADDSET=1 -DHAVE_SIGHOLD=1 -DHAVE_SIGSETMASK=1 -DHAVE_SIGBLOCK=1 -DHAVE_SIGACTION=1 -DSEMUN_UNDEFINED=1 -DSEMCTL_ARG_UNION=1 -DHAVE_STRERROR=1 -DHAVE_VPRINTF=1 -DHAVE_SYS_UIO_H=1 -DHAVE_WRITEV=1 -DHAVE_SCHED_H=1 -DUSE_SCHED_YIELD=1 -DUSE_YIELD=1 -DHAVE_GETWD=1 -DNO_ECHO=1 -DHAS_RSHCOMMAND=1 -DUSE_NONBLOCKING_LISTENER_SOCKETS=1 -DHAVE_XDRMEM_CREATE=1 -DHAVE_XDR_FLOAT=1 -DHAS_XDR=1 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/usc -I../include -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4/usc/usc.c
ar lruv /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a usc.o
a - usc.o
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2send.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2init.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2probe.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2ssend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2hsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2hrecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2pack.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2mpack.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2hssend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c bswap2.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2req.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c adi2cancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chbeager.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chbrndv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chdebug.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chchkdev.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chshort.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chflow.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chinit.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chnodename.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chhetero.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chtick.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c /home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4priv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c queue.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c cmnargs.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c tr2.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c sbcnst2.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c session.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chpackflow.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c objtrace.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c calltrace.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c chcancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DHAVE_MPICH_MPID_H -DMPID_DEVICE_CODE -DHAVE_UNAME=1 -DHAVE_NETDB_H=1 -DHAVE_GETHOSTBYNAME=1 -DMPID_DEBUG_NONE -DMPID_STAT_NONE -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -I/home/yanglei/mpich-1.2.7p1/mpid/ch2 -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -Ip4 -Ip4/include -c ch_ldebug.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a adi2recv.o adi2send.o adi2init.o adi2probe.o adi2ssend.o adi2hsend.o adi2hrecv.o adi2pack.o adi2mpack.o adi2hssend.o bswap2.o adi2req.o adi2cancel.o chbeager.o chbrndv.o chdebug.o chchkdev.o chshort.o chflow.o chinit.o chnodename.o chhetero.o chtick.o p4priv.o queue.o cmnargs.o tr2.o sbcnst2.o session.o chpackflow.o objtrace.o calltrace.o chcancel.o ch_ldebug.o
making mpir in directory src/pt2pt
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/isend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/irecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/wait.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/test.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/mperror.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/address.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/cancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/commreq_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/probe.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/start.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/testany.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/waitall.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/send.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/sendrecv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/iprobe.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/testall.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/waitany.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/create_recv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/create_send.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/sendrecv_rep.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/getcount.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/bsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/ssend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/rsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/bufattach.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/buffree.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/ibsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/issend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/irsend.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/waitsome.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/testsome.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/testcancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/bsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/rsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/ssend_init.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/startall.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/sendutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_commit.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_contig.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_extent.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_hind.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_hvec.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_ind.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_lb.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_struct.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_ub.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_util.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/type_vec.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/getelements.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/pack_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/pack.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/pt2pt -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/pt2pt/unpack.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a isend.o irecv.o wait.o test.o mperror.o address.o cancel.o commreq_free.o probe.o start.o testany.o waitall.o send.o recv.o sendrecv.o iprobe.o testall.o waitany.o create_recv.o create_send.o sendrecv_rep.o getcount.o bsend.o ssend.o rsend.o bufattach.o buffree.o ibsend.o issend.o irsend.o waitsome.o testsome.o testcancel.o bsend_init.o rsend_init.o ssend_init.o startall.o sendutil.o type_commit.o type_contig.o type_extent.o type_free.o type_hind.o type_hvec.o type_ind.o type_lb.o type_size.o type_struct.o type_ub.o type_util.o type_vec.o getelements.o pack_size.o pack.o unpack.o
making mpir in directory src/env
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/abort.c
gcc -g -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/debugutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/init.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/initthread.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/initutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/finalize.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/initialize.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errorstring.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/initdte.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/getpname.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errcreate.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errset.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errget.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errfree.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/errclass.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/wtime.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/wtick.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DHAVE_CATOPEN=1 -DHAVE_CATCLOSE=1 -DHAVE_CATGETS=1 -DHAVE_GENCAT=1 -DHAVE_NL_TYPES_H=1 -c /home/yanglei/mpich-1.2.7p1/src/env/nerrmsg.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/env -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/env/getversion.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a abort.o debugutil.o init.o initthread.o initutil.o finalize.o initialize.o errorstring.o initdte.o getpname.o errcreate.o errset.o errget.o errfree.o errclass.o wtime.o wtick.o nerrmsg.o getversion.o msgqdllloc.o
making mpir in directory src/dmpi
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/dmpi -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/dmpi/dmpipk.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/dmpi -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/dmpi/pkutil.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a dmpipk.o pkutil.o
making mpir in directory src/util
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/util -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/util/util_hbt.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/util -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/util/mpirutil.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/util -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/util/ptrcvt.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/util -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/util/bsendutil2.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a util_hbt.o mpirutil.o ptrcvt.o bsendutil2.o
making mpir in directory src/context
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/keyval_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/keyvalcreate.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/attr_getval.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/attr_delval.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/attr_util.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/attr_putval.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_excl.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_diff.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_incl.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_inter.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_rexcl.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_rincl.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/groupcompare.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_union.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_util.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_group.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_name_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_name_put.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_size.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_util.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_split.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/context_util.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/group_tranks.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_testic.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/commcompare.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_rsize.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/comm_rgroup.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/ic_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/ic_merge.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/null_copyfn.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/null_del_fn.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/context -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/context/dup_fn.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a keyval_free.o keyvalcreate.o attr_getval.o attr_delval.o attr_util.o attr_putval.o group_excl.o group_diff.o group_free.o group_incl.o group_inter.o group_rexcl.o group_rincl.o groupcompare.o group_rank.o group_size.o group_union.o group_util.o comm_dup.o comm_free.o comm_group.o comm_create.o comm_rank.o comm_name_get.o comm_name_put.o comm_size.o comm_util.o comm_split.o context_util.o group_tranks.o comm_testic.o commcompare.o comm_rsize.o comm_rgroup.o ic_create.o ic_merge.o null_copyfn.o null_del_fn.o dup_fn.o
making mpir in directory src/coll
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/barrier.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/bcast.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/gather.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/gatherv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/scatter.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/scatterv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/allgather.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/allgatherv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/alltoall.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/alltoallv.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/reduce.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/allreduce.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/red_scat.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/scan.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/global_ops.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/opcreate.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/opfree.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/oputil.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/inter_fns.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/intra_fns_new.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/coll -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/coll/intra_scan.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a barrier.o bcast.o gather.o gatherv.o scatter.o scatterv.o allgather.o allgatherv.o alltoall.o alltoallv.o reduce.o allreduce.o red_scat.o scan.o global_ops.o opcreate.o opfree.o oputil.o inter_fns.o intra_fns_new.o intra_scan.o
making mpir in directory src/topol
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/topo_test.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graphdimsget.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graph_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cartdim_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/dims_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_map.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graph_map.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graphcreate.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_rank.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_coords.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graphnbrcnt.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/graph_nbr.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_shift.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/cart_sub.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/topol -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/topol/topo_util.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a topo_test.o graphdimsget.o graph_get.o cartdim_get.o cart_get.o dims_create.o cart_map.o graph_map.o cart_create.o graphcreate.o cart_rank.o cart_coords.o graphnbrcnt.o graph_nbr.o cart_shift.o cart_sub.o topo_util.o
making mpir in directory src/profile
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/profile -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/profile/pcontrol.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a pcontrol.o
making mpir in directory src/misc2
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/finalized.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/requestc2f.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/statusc2f.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/type_blkind.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/subarray.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/darray.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_create.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_dup.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_get.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_getnth.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_set.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_delete.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_free.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_getnks.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_getvln.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_c2f.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/misc2 -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/misc2/info_f2c.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a finalized.o requestc2f.o statusc2f.o type_blkind.o subarray.o darray.o info_create.o info_dup.o info_get.o info_getnth.o info_set.o info_delete.o info_free.o info_getnks.o info_getvln.o info_c2f.o info_f2c.o
making mpir in directory src/external
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/external -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/external/statuscancel.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/external -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/external/statuselm.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/external -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/external/type_get_cont.c
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/external -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/external/type_get_env.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a statuscancel.o statuselm.o type_get_cont.o type_get_env.o
gcc -DHAVE_CONFIG_H -I. -I/home/yanglei/mpich-1.2.7p1/src/infoexport -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DFOR_MPI2=0 -g -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/infoexport/dll_mpich.c
if test "ignore" != "ignore" ; then \
rm -f libtvmpich.so.1.0; \
( CC="gcc" ; export CC ; CLINKER="gcc" ; export CLINKER ; \
/home/yanglei/mpich-1.2.7p1/util/makesharedlib -lib=libtvmpich.a -obj="dll_mpich.o" \
-kind=ignore -local ; ) ; fi
ln -s -f libtvmpich.so.1.0 libtvmpich.so.1
ln -s -f libtvmpich.so.1 libtvmpich.so
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a
Making Fortran interface
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/abortf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/addressf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/allgatherf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/allgathervf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/allreducef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/alltoallf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/alltoallvf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/attr_delvalf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/attr_getvalf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/attr_putvalf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/barrierf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/bcastf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/bsend_initf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/bsendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/bufattachf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/buffreef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cancelf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_coordsf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_createf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_getf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_mapf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_rankf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_shiftf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cart_subf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/cartdim_getf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_createf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_dupf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_freef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_groupf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_namegetf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_nameputf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_rankf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_rgroupf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_rsizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_sizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_splitf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_testicf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/commcomparef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/commreqfreef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/create_recvf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/create_sendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/darrayf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/dims_createf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/dup_fnf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errclassf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errcreatef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errfreef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errgetf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errorstringf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/errsetf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/finalizedf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/finalizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/fstrutils.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/gatherf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/gathervf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/getcountf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/getelementsf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/getpnamef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/getversionf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graph_getf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graph_mapf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graph_nbrf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graphcreatef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graphdimsgtf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/graphnbrcntf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_difff.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_exclf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_freef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_inclf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_interf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_rankf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_sizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_unionf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/groupcomparf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/grouptranksf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_rinclf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/group_rexclf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/ibsendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/ic_createf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/ic_mergef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/initf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/initializef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/iprobef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/irecvf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/irsendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/isendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/issendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/keyval_freef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/keyvalcreatf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/null_copyfnf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/null_del_fnf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/opcreatef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/opfreef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/pack_sizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/packf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/pcontrolf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/probef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/recvf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/red_scatf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/reducef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/rsend_initf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/rsendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/scanf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/scatterf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/scattervf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/sendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/sendrecvf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/sendrecvrepf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/ssend_initf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/ssendf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/startallf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/startf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/statuscancelf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/statuselmf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/statusf2c.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/subarrayf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/testallf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/testanyf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/testcancelf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/testf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/testsomef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/topo_testf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_blkindf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_commitf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_contigf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_extentf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_freef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_get_envf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_getcontf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_hindf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_hvecf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_indf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_lbf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_sizef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_structf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_ubf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/type_vecf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/unpackf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/waitallf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/waitanyf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/waitf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/waitsomef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/wtickf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/wtimef.c
ifort -I/home/yanglei/tmp/mpich1.2.7/src/fortran/src -c farg.f
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_createf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_deletef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_dupf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_freef.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_getf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_getnksf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_getnthf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_getvlnf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/info_setf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/open_portf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/close_portf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_acceptf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/comm_connectf.c
gcc -I. -I/home/yanglei/mpich-1.2.7p1/src/fortran/src -I../include -I/home/yanglei/mpich-1.2.7p1/src/fortran/include -I.. -I/home/yanglei/mpich-1.2.7p1/include -I/home/yanglei/tmp/mpich1.2.7/include -I/home/yanglei/tmp/mpich1.2.7/mpid/ch_p4 -I/home/yanglei/mpich-1.2.7p1/mpid/util -I/home/yanglei/mpich-1.2.7p1/mpid/ch_p4 -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/src/fortran/src/initfutil.c
In file included from /home/yanglei/mpich-1.2.7p1/src/fortran/include/mpi_fortimpl.h:32,
from /home/yanglei/mpich-1.2.7p1/src/fortran/src/initfutil.c:18:
../mpi_fortconf.h:85:1: warning: "HAVE_WEAK_SYMBOLS" redefined
In file included from /home/yanglei/mpich-1.2.7p1/src/fortran/src/initfutil.c:12:
/home/yanglei/tmp/mpich1.2.7/include/mpichconf.h:131:1: warning: this is the location of the previous definition
ifort -I/home/yanglei/tmp/mpich1.2.7/src/fortran/src -c initfcmn.f
ifort -I/home/yanglei/tmp/mpich1.2.7/src/fortran/src -c initfdte.f
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a abortf.o addressf.o allgatherf.o allgathervf.o allreducef.o alltoallf.o alltoallvf.o attr_delvalf.o attr_getvalf.o attr_putvalf.o barrierf.o bcastf.o bsend_initf.o bsendf.o bufattachf.o buffreef.o cancelf.o cart_coordsf.o cart_createf.o cart_getf.o cart_mapf.o cart_rankf.o cart_shiftf.o cart_subf.o cartdim_getf.o comm_createf.o comm_dupf.o comm_freef.o comm_groupf.o comm_namegetf.o comm_nameputf.o comm_rankf.o comm_rgroupf.o comm_rsizef.o comm_sizef.o comm_splitf.o comm_testicf.o commcomparef.o commreqfreef.o create_recvf.o create_sendf.o darrayf.o dims_createf.o dup_fnf.o errclassf.o errcreatef.o errfreef.o errgetf.o errorstringf.o errsetf.o finalizedf.o finalizef.o fstrutils.o gatherf.o gathervf.o getcountf.o getelementsf.o getpnamef.o getversionf.o graph_getf.o graph_mapf.o graph_nbrf.o graphcreatef.o graphdimsgtf.o graphnbrcntf.o group_difff.o group_exclf.o group_freef.o group_inclf.o group_interf.o group_rankf.o group_sizef.o group_unionf.o groupcomparf.o grouptranksf.o group_rinclf.o group_rexclf.o ibsendf.o ic_createf.o ic_mergef.o initf.o initializef.o iprobef.o irecvf.o irsendf.o isendf.o issendf.o keyval_freef.o keyvalcreatf.o null_copyfnf.o null_del_fnf.o opcreatef.o opfreef.o pack_sizef.o packf.o pcontrolf.o probef.o recvf.o red_scatf.o reducef.o rsend_initf.o rsendf.o scanf.o scatterf.o scattervf.o sendf.o sendrecvf.o sendrecvrepf.o ssend_initf.o ssendf.o startallf.o startf.o statuscancelf.o statuselmf.o statusf2c.o subarrayf.o testallf.o testanyf.o testcancelf.o testf.o testsomef.o topo_testf.o type_blkindf.o type_commitf.o type_contigf.o type_extentf.o type_freef.o type_get_envf.o type_getcontf.o type_hindf.o type_hvecf.o type_indf.o type_lbf.o type_sizef.o type_structf.o type_ubf.o type_vecf.o unpackf.o waitallf.o waitanyf.o waitf.o waitsomef.o wtickf.o wtimef.o farg.o info_createf.o info_deletef.o info_dupf.o info_freef.o info_getf.o info_getnksf.o info_getnthf.o info_getvlnf.o info_setf.o open_portf.o close_portf.o comm_acceptf.o comm_connectf.o initfutil.o initfcmn.o initfdte.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichfsup.a initfutil.o initfcmn.o initfdte.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpichfsup.a
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libfmpich.a abortf.o addressf.o allgatherf.o allgathervf.o allreducef.o alltoallf.o alltoallvf.o attr_delvalf.o attr_getvalf.o attr_putvalf.o barrierf.o bcastf.o bsend_initf.o bsendf.o bufattachf.o buffreef.o cancelf.o cart_coordsf.o cart_createf.o cart_getf.o cart_mapf.o cart_rankf.o cart_shiftf.o cart_subf.o cartdim_getf.o comm_createf.o comm_dupf.o comm_freef.o comm_groupf.o comm_namegetf.o comm_nameputf.o comm_rankf.o comm_rgroupf.o comm_rsizef.o comm_sizef.o comm_splitf.o comm_testicf.o commcomparef.o commreqfreef.o create_recvf.o create_sendf.o darrayf.o dims_createf.o dup_fnf.o errclassf.o errcreatef.o errfreef.o errgetf.o errorstringf.o errsetf.o finalizedf.o finalizef.o fstrutils.o gatherf.o gathervf.o getcountf.o getelementsf.o getpnamef.o getversionf.o graph_getf.o graph_mapf.o graph_nbrf.o graphcreatef.o graphdimsgtf.o graphnbrcntf.o group_difff.o group_exclf.o group_freef.o group_inclf.o group_interf.o group_rankf.o group_sizef.o group_unionf.o groupcomparf.o grouptranksf.o group_rinclf.o group_rexclf.o ibsendf.o ic_createf.o ic_mergef.o initf.o initializef.o iprobef.o irecvf.o irsendf.o isendf.o issendf.o keyval_freef.o keyvalcreatf.o null_copyfnf.o null_del_fnf.o opcreatef.o opfreef.o pack_sizef.o packf.o pcontrolf.o probef.o recvf.o red_scatf.o reducef.o rsend_initf.o rsendf.o scanf.o scatterf.o scattervf.o sendf.o sendrecvf.o sendrecvrepf.o ssend_initf.o ssendf.o startallf.o startf.o statuscancelf.o statuselmf.o statusf2c.o subarrayf.o testallf.o testanyf.o testcancelf.o testf.o testsomef.o topo_testf.o type_blkindf.o type_commitf.o type_contigf.o type_extentf.o type_freef.o type_get_envf.o type_getcontf.o type_hindf.o type_hvecf.o type_indf.o type_lbf.o type_sizef.o type_structf.o type_ubf.o type_vecf.o unpackf.o waitallf.o waitanyf.o waitf.o waitsomef.o wtickf.o wtimef.o farg.o info_createf.o info_deletef.o info_dupf.o info_freef.o info_getf.o info_getnksf.o info_getnthf.o info_getvlnf.o info_setf.o open_portf.o close_portf.o comm_acceptf.o comm_connectf.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libfmpich.a
making romio
make --no-print-directory mpiolib
compiling ROMIO in directory mpi-io
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/close.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/open.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/set_view.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iread.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iwrite.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/seek.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_posn.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/delete.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_all.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_at.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_atall.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iread_at.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iwrite_at.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_all.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_bytoff.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_at.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_atall.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_view.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_group.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_amode.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_extent.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fsync.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_atom.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/set_atom.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/set_size.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_size.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/prealloc.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/file_f2c.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/file_c2f.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/set_info.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_info.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/rd_atallb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/rd_atalle.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_allb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_alle.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/wr_atallb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/wr_atalle.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_allb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_alle.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_posn_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iread_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iwrite_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/seek_sh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_ord.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_orde.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_ordb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/read_ordb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_ord.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/write_orde.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/mpiu_greq.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/mpich2_fileutil.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/register_datarep.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/get_errh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/set_errh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iotest.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iotestall.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iotestany.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iotestsome.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iowait.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iowaitall.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iowaitany.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/iowaitsome.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/ioreq_c2f.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io -I../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../adio/include -I../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/../../../include -I../../../include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/ioreq_f2c.c
/home/yanglei/mpich-1.2.7p1/romio/mpi-io/ioreq_f2c.c: In function 'PMPIO_Request_f2c':
/home/yanglei/mpich-1.2.7p1/romio/mpi-io/ioreq_f2c.c:55: warning: assignment makes integer from pointer without a cast
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o get_errh.o set_errh.o iotest.o iotestall.o iotestany.o iotestsome.o iowait.o iowaitall.o iowaitany.o iowaitsome.o ioreq_c2f.o ioreq_f2c.o
compiling ROMIO in directory adio/common
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_close.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_init.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_end.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_open.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/flatten.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/async_list.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/req_malloc.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/malloc.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_read_coll.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/eof_offset.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_write_coll.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/lock.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_read_str.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_write_str.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/iscontig.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/get_fp_posn.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_seek.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_delete.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_flush.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_hints.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/error.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_fstype.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_get_sh_fp.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_set_sh_fp.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/shfp_fname.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/byte_offset.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/status_setb.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_aggregate.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/cb_config_list.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_read_str_naive.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/gencheck.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_set_view.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_iopen.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_write_str_naive.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_resize.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_read.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_write.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_iread.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_iwrite.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_done.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_wait.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/adi_close.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_prealloc.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_fcntl.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_iread_fake.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_iwrite_fake.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_done_fake.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_wait_fake.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_subarray.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/ad_darray.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/common/../../../../../src/include -I../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/adio/common/strfns.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o async_list.o req_malloc.o malloc.o ad_read_coll.o eof_offset.o ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o status_setb.o ad_aggregate.o cb_config_list.o ad_read_str_naive.o gencheck.o ad_set_view.o ad_iopen.o ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o ad_subarray.o ad_darray.o strfns.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a
compiling ROMIO in directory mpi-io/glue/mpich1
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DHAVE_MPI_INFO_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../mpi-io -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../adio/include -I../../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../../../../src/include -I../../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/mpio_file.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DHAVE_MPI_INFO_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../mpi-io -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../adio/include -I../../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/../../../../../../src/include -I../../../../../../src/include -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/glue/mpich1/mpio_err.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a mpio_file.o mpio_err.o
compiling ROMIO in directory adio/ad_testfs
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_close.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_read.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_rdcoll.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_wrcoll.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_open.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_write.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_done.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_fcntl.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_iread.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_iwrite.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_wait.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_flush.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_seek.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_resize.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_hints.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs_delete.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_testfs/ad_testfs.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o ad_testfs_delete.o ad_testfs.o
compiling ROMIO in directory adio/ad_ufs
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/ad_ufs_open.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_ufs/ad_ufs.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a ad_ufs_open.o ad_ufs.o
compiling ROMIO in directory adio/ad_nfs
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_read.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_open.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_write.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_done.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_fcntl.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_iread.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_iwrite.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_wait.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_setsh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs_getsh.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/../../../../include -I../../../../include -c /home/yanglei/mpich-1.2.7p1/romio/adio/ad_nfs/ad_nfs.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a ad_nfs_read.o ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o
compiling ROMIO in directory mpi-io/fortran
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/closef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/readf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/openf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/writef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_extentf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/ireadf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iwritef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iotestf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iowaitf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/seekf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/deletef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_allf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_atf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_atallf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iread_atf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iwrite_atf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_posnf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_allf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_atf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_atallf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_bytofff.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/set_viewf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_viewf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_groupf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_amodef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/fsyncf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_atomf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/set_atomf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/set_infof.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_infof.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/set_sizef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_sizef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/preallocf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/rd_atallbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/rd_atallef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_allbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_allef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/wr_atallbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/wr_atallef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_allbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_allef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_posn_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iread_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/iwrite_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/seek_shf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_ordf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_ordef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_ordbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/read_ordbf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_ordf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/write_ordef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/set_errhf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPIO_FORTRAN_SRC -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -I. -I../../include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/../../adio/include -I../../adio/include -I/home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/.. -c /home/yanglei/mpich-1.2.7p1/romio/mpi-io/fortran/get_errhf.c
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpich.a closef.o readf.o openf.o writef.o get_extentf.o ireadf.o iwritef.o iotestf.o iowaitf.o seekf.o deletef.o read_allf.o read_atf.o read_atallf.o iread_atf.o iwrite_atf.o get_posnf.o write_allf.o write_atf.o write_atallf.o get_bytofff.o set_viewf.o get_viewf.o get_groupf.o get_amodef.o fsyncf.o get_atomf.o set_atomf.o set_infof.o get_infof.o set_sizef.o get_sizef.o preallocf.o rd_atallbf.o rd_atallef.o read_allbf.o read_allef.o wr_atallbf.o wr_atallef.o write_allbf.o write_allef.o get_posn_shf.o iread_shf.o read_shf.o write_shf.o iwrite_shf.o seek_shf.o read_ordf.o read_ordef.o write_ordbf.o read_ordbf.o write_ordf.o write_ordef.o set_errhf.o get_errhf.o
making C++ interface
Configuring MPI-2 C++ bindings, version 1.0.6b13
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make --no-print-directory sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking host system type... x86_64-unknown-linux-gnu
checking for awk... /usr/bin/awk
checking for wc... /usr/bin/wc
checking MPICH version... 1.2.7 (good)
checking for MPICH's underlying C++ compiler... g++
checking if want profiling support... yes
checking for /home/yanglei/tmp/mpich1.2.7/bin/mpicxx... /home/yanglei/tmp/mpich1.2.7/bin/mpicxx
checking whether the C++ compiler (/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DMPICH_SKIP_MPICXX ) works... yes
checking whether the C++ compiler (/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DMPICH_SKIP_MPICXX ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether /home/yanglei/tmp/mpich1.2.7/bin/mpicxx accepts -g... yes
checking how to run the C++ preprocessor... /home/yanglei/tmp/mpich1.2.7/bin/mpicxx -E
checking for AIX... no
checking whether ln -s works... yes
checking for template repository directory... not used
checking for compiler exception flags... -fexceptions
checking for throw/catch... no (g++ exceptions broken)
checking for mpi.h... yes
checking for getservbyname in -lsocket... no
checking for gethostbyaddr in -lnsl... yes
checking for sigwait in -lthread... no
checking whether to use MPI(_ERR)_PENDING... MPI_ERR_PENDING
checking for MPI_GET_VERSION... yes
checking for MPI_STATUS_IGNORE... yes, but broken
checking for MPI_STATUSES_IGNORE... yes, but broken
checking for ranlib... ranlib
checking for ar... ar
checking for sh... /bin/sh
checking for type bool... yes
checking size of of int... 4
checking size of of MPI2CPP_BOOL_T... 1
checking type of MPI attributes... long
checking for signal declaration... SYSV
checking for namespace support... yes
checking for FORTRAN constants... yes
checking for optional FORTRAN constants... some
checking for optional C constants... no
creating ./config.status
creating Makefile
creating src/Makefile
creating src/mpi2c++/Makefile
creating contrib/Makefile
creating contrib/test_suite/Makefile
creating contrib/examples/Makefile
creating balky/Makefile
creating balky/balky
creating balky/mini-balky
creating src/mpi2c++/mpi2c++_config.h
src/mpi2c++/mpi2c++_config.h is unchanged
Making all in src
Making all in mpi2c++
make[5]: Nothing to be done for `all'.
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi++.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/intercepts.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/pmpi++.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/op.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/comm.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/intracomm.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/topology.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/intercomm.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/request.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/group.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/datatype.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/status.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/errhandler.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/exception.cc
/home/yanglei/tmp/mpich1.2.7/bin/mpicxx -DHAVE_CONFIG_H -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/mpi2c++ -I/home/yanglei/mpich-1.2.7p1/MPI-2-C++/src -fexceptions -I../include -I.. -I/home/yanglei/tmp/mpich1.2.7/MPI-2-C++/src -DMPICH_SKIP_MPICXX -I../include -I.. -c /home/yanglei/mpich-1.2.7p1/MPI-2-C++/src/functions.cc
rm -f libpmpi++.a
ar cru libpmpi++.a mpi++.o intercepts.o pmpi++.o op.o comm.o intracomm.o topology.o intercomm.o request.o group.o datatype.o status.o errhandler.o exception.o functions.o
ranlib libpmpi++.a
Making all in balky
make[4]: Nothing to be done for `all'.
make[4]: Nothing to be done for `all-am'.
making Fortran 90 module for MPI
Types are integer1 integer2 integer4 integer8 real4 complex4 real8 complex8 logical1 logical2 logical4 logical8 character
sed -e 's/^C/!/g' ../include/mpif.h > mpif.h
/opt/intel/fc/10.0.023/bin/ifort -c -I. mpi_constants.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi_constants.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a
/opt/intel/fc/10.0.023/bin/ifort -c mpi1.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__ch_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__ch_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__ch_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__ch_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__ch_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__ch_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__ch_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__ch_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__ch_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__ch_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co4_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co4_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co4_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co4_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co8_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co8_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__co8_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__co8_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in1_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in1_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in1_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in1_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in1_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in1_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in1_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in1_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in1_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in1_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in2_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in2_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in2_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in2_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in2_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in2_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in2_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in2_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in2_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in2_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in4_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in4_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in4_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in4_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in8_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in8_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__in8_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__in8_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo1_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo1_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo1_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo1_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo1_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo1_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo1_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo1_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo1_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo1_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo2_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo2_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo2_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo2_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo2_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo2_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo2_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo2_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo2_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo2_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo4_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo4_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo4_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo4_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo8_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo8_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__lo8_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__lo8_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re4_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re4_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re4_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re4_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re8_sv.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re8_sv.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi1__re8_vs.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi1__re8_vs.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__ch_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__ch_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__ch_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__ch_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__ch_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__ch_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__co8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__co8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in1_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in1_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in1_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in1_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in1_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in1_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in2_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in2_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in2_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in2_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in2_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in2_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__in8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__in8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo1_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo1_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo1_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo1_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo1_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo1_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo2_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo2_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo2_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo2_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo2_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo2_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__lo8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__lo8_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re4_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re4_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re4_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re4_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re4_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re4_v.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re8_s.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re8_s.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re8_v2.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re8_v2.o
/opt/intel/fc/10.0.023/bin/ifort -c mpi2__re8_v.f90
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a mpi2__re8_v.o
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90.a ./mpi.o
if [ ! -d /home/yanglei/tmp/mpich1.2.7/include/f90choice ] ; then \
mkdir /home/yanglei/tmp/mpich1.2.7/include/f90choice ; fi
cp mpi*.mod /home/yanglei/tmp/mpich1.2.7/include/f90choice
if [ ! -d .tmp ] ; then mkdir .tmp ; fi
cp mpi-nochoice.f90 .tmp/mpi.f90
rm -f .tmp/mpi2.mod .tmp/mpi1.mod .tmp/mpi_constants.mod
ar cr /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90nc.a .tmp/mpi.o mpi1.o mpi2.o \
mpi_constants.o
ranlib /home/yanglei/tmp/mpich1.2.7/lib/libmpichf90nc.a
if [ ! -d /home/yanglei/tmp/mpich1.2.7/include/f90base ] ; then \
mkdir /home/yanglei/tmp/mpich1.2.7/include/f90base ; fi
cp mpi-base.mod /home/yanglei/tmp/mpich1.2.7/include/f90base/mpi.mod
cp mpi_constants.mod /home/yanglei/tmp/mpich1.2.7/include/f90base
cp mpi1.mod /home/yanglei/tmp/mpich1.2.7/include/f90base
cp mpi2.mod /home/yanglei/tmp/mpich1.2.7/include/f90base
make --no-print-directory mpi-lib-test
make --no-print-directory profileliblink
Testing that MPI applications can be linked...
make --no-print-directory linktest
make overtake
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DUSE_STDARG=1 -DHAVE_PROTOTYPES=1 -DHAVE_SIGNAL_H=1 -DHAVE_SIGACTION=1 -DHAVE_SLEEP=1 -DHAVE_SYSCONF=1 -c /home/yanglei/mpich-1.2.7p1/examples/test/pt2pt/overtake.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STRING_H=1 -DUSE_STDARG=1 -DHAVE_PROTOTYPES=1 -DHAVE_SIGNAL_H=1 -DHAVE_SIGACTION=1 -DHAVE_SLEEP=1 -DHAVE_SYSCONF=1 -c /home/yanglei/mpich-1.2.7p1/examples/test/pt2pt/test.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -o overtake overtake.o test.o
/usr/bin/ld: warning: i386 architecture of input file `/home/yanglei/tmp/mpich1.2.7/lib/libmpich.a(initfcmn.o)' is incompatible with i386:x86-64 output
/usr/bin/ld: warning: i386 architecture of input file `/home/yanglei/tmp/mpich1.2.7/lib/libmpich.a(initfdte.o)' is incompatible with i386:x86-64 output
make clean
make --no-print-directory mpi-addons
make --no-print-directory mpelib
Making MPE Profiling Libraries
rm -f dbxtest dbxtest2 testlog clog_print clog2alog clog2slog
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/bin/clog_print
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/bin/clog2alog
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/bin/slog_print
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/bin/clog2slog
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.so
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libtmpe.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/liblmpe.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libampe.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe_nompi.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe_f2cmpi.a
rm -f /home/yanglei/tmp/mpich1.2.7/mpe/lib/mpe_prof.o
make --no-print-directory mpe_debug_objs
make --no-print-directory libslog.a
sleep 1
make --no-print-directory /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.a
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_graphics.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xcolor.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xframe.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xinit.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xwmap.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xmouse.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xkey.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog_sysio.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_log.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog_merge.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog_time.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog_util.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/clog2alog.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/decomp.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_seq.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c dbxerr.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/examine.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/privtags.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/getgrank.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpehname.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_io.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_graphicsf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/xmousef.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_logf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/decompf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_seqf.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/getgrankf.c
ar cr /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.a mpe_graphics.o xcolor.o xframe.o xinit.o xwmap.o xmouse.o xkey.o clog_sysio.o mpe_log.o clog.o clog_merge.o clog_time.o clog_util.o clog2alog.o decomp.o mpe_seq.o dbxerr.o examine.o privtags.o getgrank.o mpehname.o mpe_io.o mpe_graphicsf.o xmousef.o mpe_logf.o decompf.o mpe_seqf.o getgrankf.o
ranlib /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.a
make --no-print-directory /home/yanglei/tmp/mpich1.2.7/mpe/lib/libtmpe.a
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/trc_wrappers.c
ar cr /home/yanglei/tmp/mpich1.2.7/mpe/lib/libtmpe.a trc_wrappers.o
ranlib /home/yanglei/tmp/mpich1.2.7/mpe/lib/libtmpe.a
make --no-print-directory /home/yanglei/tmp/mpich1.2.7/mpe/lib/liblmpe.a
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/log_wrap.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c -DUSE_PMPI /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_log.c
ar cr /home/yanglei/tmp/mpich1.2.7/mpe/lib/liblmpe.a log_wrap.o mpe_plog.o clog.o clog_util.o clog_merge.o clog2alog.o clog_time.o
ranlib /home/yanglei/tmp/mpich1.2.7/mpe/lib/liblmpe.a
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/visual_mess.c
ar cr /home/yanglei/tmp/mpich1.2.7/mpe/lib/libampe.a visual_mess.o
ranlib /home/yanglei/tmp/mpich1.2.7/mpe/lib/libampe.a
make --no-print-directory /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe_nompi.a
rm -f mpe_graphics.o xcolor.o xframe.o xinit.o xwmap.o xmouse.o xkey.o mpehname.o
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_graphics.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xcolor.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xframe.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xinit.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xwmap.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xmouse.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/xkey.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/src/../include -DMPE_NOMPI -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpehname.c
ar cr /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe_nompi.a mpe_graphics.o xcolor.o xframe.o xinit.o xwmap.o xmouse.o xkey.o mpehname.o
ranlib /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe_nompi.a
make --no-print-directory /home/yanglei/tmp/mpich1.2.7/mpe/lib/mpe_prof.o
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/mpe_prof.c
make --no-print-directory clog_print
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/printlog.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o clog_print printlog.o clog_util.o clog_sysio.o
rm -f printlog.o clog_util.o clog_sysio.o
make --no-print-directory clog2alog
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -DMPE_GRAPHICS -I.. -I/home/yanglei/mpich-1.2.7p1/mpe/include -I../slog_api -I/home/yanglei/mpich-1.2.7p1/mpe/slog_api/include -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/src/ctoalog.c
gcc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o clog2alog ctoalog.o clog2alog.o clog_util.o clog_sysio.o
** Testing if C application can be linked with logging library
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/mpe/include -c /home/yanglei/mpich-1.2.7p1/mpe/contrib/test/cpi.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_log cpi.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -llmpe -lmpe -lm
** C application can be linked with logging library
** Testing if C application can be linked with tracing library
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_trace cpi.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -ltmpe -lm
** C application can be linked with tracing library
** Testing if C application can be linked with animation library
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_anim cpi.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -lampe -lmpe -L/usr/lib64 -lX11 -lm
** C application can be linked with animation library
** Testing if C application can be linked with graphics library
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/mpe/include -c /home/yanglei/mpich-1.2.7p1/mpe/contrib/test/cxgraphics.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cxgraphics cxgraphics.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -lmpe -L/usr/lib64 -lX11 -lm
** C application can be linked with graphics library
** Testing if C application can use both automatic and manual logging together
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/mpe/include -c /home/yanglei/mpich-1.2.7p1/mpe/contrib/test/cpilog.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpilog cpilog.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -llmpe -lmpe -lm
** C application can use both automatic and manual logging together
** Testing if Fortran77 application can be linked with logging library
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -I/home/yanglei/tmp/mpich1.2.7/mpe/include -c /home/yanglei/mpich-1.2.7p1/mpe/contrib/test/fpi.f
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -o fpilog fpi.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -lfmpich -llmpe -lmpe -lm
ld: skipping incompatible /home/yanglei/tmp/mpich1.2.7/lib/libfmpich.a when searching for -lfmpich
ld: cannot find -lfmpich
make[5]: *** [fpilog] Error 1
** Fortran77 application CANNOT be linked with logging library
** Testing if Fortran77 application can be linked with graphics library
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -I/home/yanglei/tmp/mpich1.2.7/mpe/include -c /home/yanglei/mpich-1.2.7p1/mpe/contrib/test/fxgraphics.f
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -o fxgraphics fxgraphics.o -L/home/yanglei/tmp/mpich1.2.7/mpe/lib -lmpe -L/usr/lib64 -lX11 -lm
ld: skipping incompatible /home/yanglei/tmp/mpich1.2.7/mpe/lib/libmpe.a when searching for -lmpe
ld: cannot find -lmpe
make[5]: *** [fxgraphics] Error 1
** Fortran77 application CANNOT be linked with graphics library
Making trace_sample
cd src && make --no-print-directory
/bin/sh ../libtool --mode=compile gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/src/trace_impl.c
mkdir .libs
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/src/trace_impl.c -fPIC -DPIC -o .libs/trace_impl.o
/bin/sh ../libtool --mode=compile gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace/logformat_trace_InputLog.c
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace/logformat_trace_InputLog.c -fPIC -DPIC -o .libs/logformat_trace_InputLog.o
if [ "yes" = "yes" ] ; then \
/bin/sh ../libtool --mode=link gcc -o libTraceInput.la trace_impl.lo logformat_trace_InputLog.lo -module -no-undefined -avoid-version \
-export-symbols /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/src/JavaTraceInput.sym \
-rpath /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib ; \
else \
fi
echo "{ global:" > .libs/libTraceInput.ver
cat /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/src/JavaTraceInput.sym | sed -e "s/\(.*\)/\1;/" >> .libs/libTraceInput.ver
echo "local: *; };" >> .libs/libTraceInput.ver
gcc -shared .libs/trace_impl.o .libs/logformat_trace_InputLog.o -Wl,-soname -Wl,libTraceInput.so -Wl,-version-script -Wl,.libs/libTraceInput.ver -o .libs/libTraceInput.so
creating libTraceInput.la
(cd .libs && rm -f libTraceInput.la && ln -s ../libTraceInput.la libTraceInput.la)
/bin/sh ../libtool --mode=install /usr/bin/install -c libTraceInput.la /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib
/usr/bin/install -c .libs/libTraceInput.so /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib/libTraceInput.so
/usr/bin/install -c .libs/libTraceInput.lai /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib/libTraceInput.la
PATH="$PATH:/sbin" ldconfig -n /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/sh ../libtool --finish /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/lib
during execution
during linking
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace/trace_print.c
gcc -o /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/bin/textlog_print trace_impl.o trace_print.o
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/../src/logformat/trace/trace_check_timeorder.c
gcc -o /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_sample/bin/textlog_check_timeorder trace_impl.o trace_check_timeorder.o
Making trace_rlog
/bin/sh ../libtool --mode=compile gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/trace_input.c
mkdir .libs
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/trace_input.c -fPIC -DPIC -o .libs/trace_input.o
/bin/sh ../libtool --mode=compile gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/rlogutil.c
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/rlogutil.c -fPIC -DPIC -o .libs/rlogutil.o
/bin/sh ../libtool --mode=compile gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace/logformat_trace_InputLog.c
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace/logformat_trace_InputLog.c -fPIC -DPIC -o .libs/logformat_trace_InputLog.o
/bin/sh ../libtool --mode=link gcc -o libTraceInput.la trace_input.lo rlogutil.lo logformat_trace_InputLog.lo -module -no-undefined -avoid-version \
-export-symbols /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/JavaTraceInput.sym \
-rpath /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib ; \
else \
fi
cat /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/src/JavaTraceInput.sym | sed -e "s/\(.*\)/\1;/" >> .libs/libTraceInput.ver
gcc -shared .libs/trace_input.o .libs/rlogutil.o .libs/logformat_trace_InputLog.o -Wl,-soname -Wl,libTraceInput.so -Wl,-version-script -Wl,.libs/libTraceInput.ver -o .libs/libTraceInput.so
/bin/sh ../libtool --mode=install /usr/bin/install -c libTraceInput.la /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib
/usr/bin/install -c .libs/libTraceInput.so /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib/libTraceInput.so
/usr/bin/install -c .libs/libTraceInput.lai /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib/libTraceInput.la
PATH="$PATH:/sbin" ldconfig -n /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib
during execution
during linking
/bin/sh ../libtool --finish /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/lib
during execution
during linking
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace/trace_print.c
gcc -o /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/bin/rlog_print trace_input.o rlogutil.o trace_print.o
gcc -I.. -I/usr/java/latest/include -I/usr/java/latest/include/linux -I/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -c /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/../src/logformat/trace/trace_check_timeorder.c
gcc -o /home/yanglei/tmp/mpich1.2.7/mpe/slog2sdk/trace_rlog/bin/rlog_check_timeorder trace_input.o rlogutil.o trace_check_timeorder.o
Copying MPE include files to /home/yanglei/tmp/mpich1.2.7/include
Copying MPE libraries to /home/yanglei/tmp/mpich1.2.7/lib
Copying MPE utility programs to /home/yanglei/tmp/mpich1.2.7/bin
About to run installation test for C programs...
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/include -c cpi.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_log cpi.o -L/home/yanglei/tmp/mpich1.2.7/lib -llmpe -lmpe -lm
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_trace cpi.o -L/home/yanglei/tmp/mpich1.2.7/lib -ltmpe -lm
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_anim cpi.o -L/home/yanglei/tmp/mpich1.2.7/lib -lampe -lmpe -L/usr/lib64 -lX11 -lm
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/include -c cxgraphics.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cxgraphics cxgraphics.o -L/home/yanglei/tmp/mpich1.2.7/lib -lmpe -L/usr/lib64 -lX11 -lm
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/home/yanglei/tmp/mpich1.2.7/include -c cpilog.c
/home/yanglei/tmp/mpich1.2.7/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpilog cpilog.o -L/home/yanglei/tmp/mpich1.2.7/lib -llmpe -lmpe -lm
About to run installation test for Fortran programs...
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -I/home/yanglei/tmp/mpich1.2.7/include -c fpi.f
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -o fpilog fpi.o -L/home/yanglei/tmp/mpich1.2.7/lib -lfmpich -llmpe -lmpe -lm
make[4]: *** [fpilog] Error 1
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -I/home/yanglei/tmp/mpich1.2.7/include -c fxgraphics.f
/home/yanglei/tmp/mpich1.2.7/bin/mpif77 -o fxgraphics fxgraphics.o -L/home/yanglei/tmp/mpich1.2.7/lib -lmpe -L/usr/lib64 -lX11 -lm
ld: skipping incompatible /home/yanglei/tmp/mpich1.2.7/lib/libmpe.a when searching for -lmpe
make[4]: *** [fxgraphics] Error 1
Copying SLOG2SDK's lib
Copying SLOG2SDK's doc
Copying SLOG2SDK's logfiles
Creating SLOG2SDK's bin
Copying TRACE_RLOG's lib
Copying TRACE_RLOG's logfiles
-rpath /home/yanglei/tmp/mpich1.2.7/lib ; \
else \
fi
rm -fr .libs/libTraceInput.la .libs/libTraceInput.lai .libs/libTraceInput.so .libs/libTraceInput.ver
/bin/sh ../libtool --mode=install /usr/bin/install -c libTraceInput.la /home/yanglei/tmp/mpich1.2.7/lib
/usr/bin/install -c .libs/libTraceInput.so /home/yanglei/tmp/mpich1.2.7/lib/libTraceInput.so
/usr/bin/install -c .libs/libTraceInput.lai /home/yanglei/tmp/mpich1.2.7/lib/libTraceInput.la
PATH="$PATH:/sbin" ldconfig -n /home/yanglei/tmp/mpich1.2.7/lib
during execution
during linking
/bin/sh ../libtool --finish /home/yanglei/tmp/mpich1.2.7/lib
during execution
during linking
Copying TRACE_RLOG's bin
Installed TRACE_RLOG in /home/yanglei/tmp/mpich1.2.7
/home/yanglei/tmp/mpich1.2.7/sbin/mpeuninstall may be used to remove the installation
Installed SLOG2SDK in /home/yanglei/tmp/mpich1.2.7
Installed MPE in /home/yanglei/tmp/mpich1.2.7
Finished making MPE Profiling Libraries
make --no-print-directory mpi-utils
gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -c /home/yanglei/mpich-1.2.7p1/mpid/server/serv_p4.c -I./ -o serv_p4.o
gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -c -I./ /home/yanglei/mpich-1.2.7p1/mpid/server/server_ssl.c
gcc -o serv_p4 serv_p4.o server_ssl.o -lcrypt
bin/mpicc -o /home/yanglei/tmp/mpich1.2.7/bin/mpichversion /home/yanglei/mpich-1.2.7p1/util/mpichversion.c
/home/yanglei/mpich-1.2.7p1/util/mpichversion.c: In function 'main':
/home/yanglei/mpich-1.2.7p1/util/mpichversion.c:67: warning: incompatible implicit declaration of built-in function 'exit'
rm -f /home/yanglei/mpich-1.2.7p1/bin/mpireconfig.dat
rm -f /home/yanglei/tmp/mpich1.2.7/bin/mpireconfig.dat
creating util/mympiinstall
Completed build of MPI. Check the output for errors Also try executing 'make
testing' in examples/test (This relies on mpirun, which currently works for
many but not all systems. For workstation networks, mpirun requires that you
first setup a "machines" file listing the machines available; this is covered
in the installation manual.)
Send bugs and comments to mpi-bugs at mcs.anl.gov
Bugs and comments in the C++ support should be sent to mpi2cpp-devel at osl.iu.edu
Bugs and comments in the MPI-IO support should be sent to
romio-maint at mcs.anl.gov
With any bug report, please send
The version of MPICH (e.g., 1.2.7)
The output of running your program with the -mpiversion argument
(e.g., mpirun -np 1 a.out -mpiversion)
The output of
uname -a
for your system. If you are on an SGI system, also
hinv
If the problem is with a script like configure or mpirun, run the script with
the -echo argument (e.g., mpirun -echo -np 4 a.out )
If you are using a network of workstations, also send the output of
bin/tstmachines.
Configuring with args --with-arch=LINUX --with-device=ch_p4 -cc=gcc -fc=ifort -disable-short-longs --prefix=/opt/mpich
Configuring MPICH Version 1.2.7 (release) of : 2005/11/04 11:54:51
Use the environment variable CC instead of configure argument -cc=gcc
Use the environment variable FC instead of configure argument -fc=ifort
checking whether filesystem respects case in file names... yes
checking for install
checking for ar... found /usr/bin/ar ()
checking for ranlib
checking for gnumake... yes using --no-print-directory
checking whether make supports include... yes
checking for OSF V3 make... no
checking for virtual path format... VPATH
checking for xlC
checking for g++
checking whether g++ returns correct error code... yes
Compiling C++ interface with g++
checking whether selected C++ compiler can compile iostream.h... yes
Include C++ bindings for MPI from http://www.osl.iu.edu/research/mpi2c++
Send bug reports about the C++ to mpi2cpp-devel at osl.iu.edu
checking for g++ compiler exception flags... -fexceptions
checking whether the compiler gcc accepts ANSI prototypes... yes
checking for ifort... found /opt/intel/fc/10.0.023/bin/ifort (1)
checking for ar... found /usr/bin/ar (ar)
checking for whether compiler works... yes
checking whether the compiler gcc accepts ## for concatenation in cpp... yes
checking whether the compiler gcc accepts const modifier... yes
checking for extension on executables... none
checking how to run the C preprocessor
checking for AIX
checking for minix/config.h
checking for volatile... yes
Running device-specific setup program
About to do p4 device
Finished setting p4arch...
Configuring p4 subsystem...
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking whether signals work correctly... yes
checking whether cross-compiling... no
checking for remsh... no
checking for rsh... /usr/kerberos/bin/rsh
checking whether /usr/kerberos/bin/rsh works... no
Errors while trying to run true on cluster.hpc.cc with rsh
connect to address 210.77.90.28 port 544: Connection refused
trying normal rsh (/usr/bin/rsh)
cluster.hpc.cc: Connection refused
checking for ssh... /usr/bin/ssh
checking whether /usr/bin/ssh works... yes
checking size of int... 4
checking size of long... 8
checking for gettimeofday... yes
checking for BSDgettimeofday... no
checking for setsid... yes
checking for isatty... yes
creating localdefs
creating mpich-mpid.h
Configuring with args -p4arch=LINUX -p4make=make --no-print-directory -opt= -cc=gcc -p4comm= -p4device=ch_p4 -srcdir=/home/yanglei/mpich-1.2.7p1/mpid/ch_p4/p4 -exec-prefix=/opt/mpich -libbuild_dir=/home/yanglei/tmp/mpich1.2.7/lib -cflags= -rsh=/usr/bin/ssh --disable-short-longs
Setting p4arch to LINUX
Setting p4make to make --no-print-directory
Setting p4comm to
Setting p4device to ch_p4
Setting RSHCOMMAND to /usr/bin/ssh
checking for ranlib
checking for rpc/rpc.h... yes
checking for netinet/in.h... yes
checking for arpa/inet.h... yes
checking for sys/socketvar.h... yes
checking for stdlib.h... yes
checking for unistd.h... yes
checking for string.h... yes
checking for strings.h... yes
checking for termio.h... yes
checking for termios.h... yes
checking for sys/types.h... yes
checking for sys/wait.h... yes
checking that time.h and sys/time.h can both be included... yes
checking for time.h... yes
checking that string.h and strings.h can be included... yes
checking for correct headers with rpc/rpc.h... yes
checking for correct headers with netinet/in.h... yes
checking for stdarg.h... yes
checking whether stdarg is oldstyle... no
checking whether stdarg is correct... yes
checking whether programs using stdarg link... yes
checking for sigprocmask... yes
checking for sigemptyset... yes
checking for sigaddset... yes
checking for sighold... yes
checking for sigsetmask... yes
checking for sigblock... yes
checking for sigaction... yes
checking for for struct sigaction... yes
checking for for union semun... no
checking for whether semctl needs union semun... yes
checking for strerror... yes
checking for whether sys_errlist needs do be defined... yes
checking for -lcrypt... yes
checking for vprintf... yes
checking for sys/uio.h... yes
checking for writev... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for getwd... yes
checking for echo off supported with sgttyb... no
checking for if getsockopt wants socklen_t... yes
checking if xdr_array wants u_int... yes
checking for xdrmem_create... yes
checking for xdr_float... yes
checking for XDR includes and functions... yes
checking for rpc/xdr.h compiles... yes
checking byte ordering
creating config.status
creating Makefile
creating lib/Makefile
creating alog/Makefile
creating usc/Makefile
creating usc/usctest/Makefile
creating messages/Makefile
creating include/Makefile
creating lib_f/Makefile
creating contrib_f/Makefile
creating bin/Makefile
creating doc/Makefile
creating messages_f/Makefile
creating misc/Makefile
creating monitors/Makefile
creating servers/Makefile
creating p4_config.h
Finished configuring the p4 subsystem
Configuring new p4 secure server
checking whether the C compiler (gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR ) works... yes
checking whether the C compiler (gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR ) is a cross-compiler... no
checking for library containing xdr_array... none required
checking for library containing socket... none required
checking for library containing crypt... -lcrypt
checking how to run the C preprocessor... gcc -E
checking for fcntl.h... yes
checking for sys/select.h... yes
checking for index... yes
checking for rindex... yes
checking for seteuid... yes
checking for setresuid... yes
checking for setegid... yes
checking for setresgid... yes
checking for Kerberos (/usr/kerberos)... yes
checking for ka_UserAuthenticateGeneral... no
checking for AFS (/usr/afsws)... no
checking for SSL in cache... no. checking manually
checking for include directory for ssl... no
checking for getopt... yes
checking for posix signal in cache... no. checking manually
checking for waitpid... yes
checking for setpgrp... yes
checking whether setpgrp takes no argument... yes
checking if getsockopt wants socklen_t... yes
creating Makefile
creating server.h
server.h is unchanged
Finished configuring the p4 secure server
checking for gethrtime... no
checking for clock_gettime... no
checking for clock_getres... no
checking for how many arguments gettimeofday takes... two - whew
checking for signal.h... yes
checking for weak symbol support... pragma weak
checking whether weak symbols are visible to other files... yes
checking for perl5... no
checking for perl... found /usr/bin/perl (perl)
checking for byte ordering... little endian
checking for XDR include... yes
checking for XDR functions... yes
checking for uname... yes
checking for netdb.h... yes
checking for gethostbyname... yes
checking whether C++ compiler also has gethostbyname... yes
checking whether Fortran programs can link with needed C functions... yes
checking whether C++ programs can link with needed C functions... yes
checking for catopen... yes
checking for catclose... yes
checking for catgets... yes
checking for gencat... found /usr/bin/gencat (1)
checking for nl_types.h... yes
checking for ANSI C header files
checking for malloc return type... void
checking for system... yes
checking for nice... yes
checking for strdup... yes
checking for memory.h... yes
checking for sys/ioctl.h... yes
checking for sys/sockio.h... no
checking whether the compiler gcc runs... yes
checking whether the compiler ifort runs... yes
checking for correct handling of conditionals...... yes
checking for correct handling of conditionals part 2 ...... yes
checking for correct handling of #elif... yes
checking that constant folding in arrays works... yes
checking that structs are handled properly... yes
checking that compiler truncates unsigned char correctly ...... yes
checking that compiler/hardware has commutative arithmetic ...... yes
checking that compiler assigns to char correctly ...... yes
checking that compiler does not call unknown routines for long doubles... yes
checking that compiler accepts args correctly ...... yes
checking whether ranlib works... yes
checking for broken handling of common symbols... no
checking for ar... found /usr/bin/ar (1)
checking for size of void *... 8
checking for pointers greater than 32 bits... yes
checking for size of int... 4
checking for int large enough for pointers... no
checking for C integer type for MPI_Aint...
checking for size of long... 8
C integer type for MPI_Aint is... long
checking for structure alignment... largest
checking for sync... found /bin/sync (1)
checking whether mpich can be used as the library name... yes
Configuring Fortran subsystem
checking for cc... gcc
checking whether the C compiler sets its return status correctly... yes
checking for an ANSI C-conforming const... no
checking for Fortran 77 compiler default output file name... a.out
checking whether the Fortran 77 compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU Fortran 77 compiler... no
checking whether ifort accepts -g... yes
checking that f works as the extension for Fortran 90 program... yes
checking whether we are using the GNU Fortran 90 compiler... no
checking whether /opt/intel/fc/10.0.023/bin/ifort accepts -g... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make allows comments in actions... yes
checking whether make sets CFLAGS... yes
checking for ranlib... ranlib
checking for routines to access the command line from Fortran 77... searching...
checking whether ifort works with GETARG and IARGC... yes
checking how to compile and link Fortran 90 programs with Fortran 77 programs that access the command line... searching...
checking if /opt/intel/fc/10.0.023/bin/ifort works... yes
checking how to get verbose linking output from ifort ... -v
checking for Fortran libraries of ifort ... -L/opt/intel/fc/10.0.023/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32/.. -L/usr/lib -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl
checking whether C can link with -L/opt/intel/fc/10.0.023/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32/.. -L/usr/lib -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl... no
checking for which libraries can be used... -lm -lgcc_s -ldl
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower underscore
checking for which Fortran libraries are needed to link C with Fortran... none
checking whether Fortran accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran has pointer declaration... yes
checking for size of Fortran type integer... 0
checking for size of Fortran type real... 0
checking for size of Fortran type double precision... 0
checking for egrep... grep -E
checking for ANSI C header files... yes
checking whether stdarg works... yes
checking for sys/stat.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for char... yes
checking size of char... 1
checking for short... yes
checking size of short... 2
checking for int... yes
checking for long... yes
checking for long long... yes
checking size of long long... 8
checking for float... yes
checking size of float... 4
checking for double... yes
checking size of double... 8
checking for long double... yes
checking size of long double... 16
checking for void*... yes
checking size of void*... 8
checking for C type matching Fortran integer*1... char
checking for C type matching Fortran integer*2... short
checking for C type matching Fortran integer*4... int
checking for C type matching Fortran integer*8... long
checking for C type matching Fortran real*4... float
checking for C type matching Fortran real*8... double
checking for C type matching Fortran real*16... long_double
checking for C type matching Fortran integer... unavailable
checking whether C compiler allows unaligned doubles... yes
checking for type of weak symbol support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking for values of Fortran logicals... could not determine
checking for Fortran 90 integer kind for 8-byte integers... 8
checking for Fortran 90 integer kind for 8-byte integers... 8 (cached)
Setting up F90 Module support
checking whether the Fortran 77 compiler (ifort ) works... yes
checking whether the Fortran 77 compiler (ifort ) is a cross-compiler... no
checking whether we are using GNU Fortran 77... no
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (/opt/intel/fc/10.0.023/bin/ifort ) works... yes
checking whether the Fortran 90 compiler (/opt/intel/fc/10.0.023/bin/ifort ) is a cross-compiler... no
checking for a BSD compatible install... /usr/bin/install -c
checking whether ln -s works... yes
checking for ar... ar
checking whether make echos directory changes... yes using --no-print-directory
checking for module suffix... mod
checking for case of module names... lower
checking for module directory path flag... -I
checking that the compiler /opt/intel/fc/10.0.023/bin/ifort accepts .f90 suffix... yes
checking whether Fortran 90 is compatible with Fortran 77... yes
updating cache /dev/null
creating ./config.status
creating Makefile
checking whether using gcc and g77 together... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/farg.f
config.status: creating include/mpif.h
config.status: creating include/mpi_fortdefs.h
config.status: creating src/mpif77
config.status: creating src/mpif77.conf
config.status: creating src/mpif90
config.status: creating src/mpif90.conf
config.status: creating src/initfcmn.f
config.status: creating src/initfdte.f
config.status: creating mpi_fortconf.h
config.status: executing default-1 commands
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
Done configuring Fortran subsystem
Configuring ROMIO, for support of MPI-IO
checking whether compiler allows define a(b) a(b,__LINE__)... yes
Configuring with args --with-mpi=mpich --disable-short-longs --cache-file=/dev/null
checking for architecture... LINUX
ROMIO home directory is /home/yanglei/mpich-1.2.7p1/romio
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are using the GNU C compiler... yes
checking for gcc option to accept ANSI C... none needed
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking for inline... inline
checking for unistd.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking that weak symbols are visible to other files... yes
checking whether struct flock compatible with MPI_Offset... yes
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS. See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing pthread_create... -lpthread
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for sys/types.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for doctext... no
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for restrict... __restrict
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
setting CC to /home/yanglei/tmp/mpich1.2.7/bin/mpicc
setting F77 to ifort
setting TEST_CC to /home/yanglei/tmp/mpich1.2.7/bin/mpicc
setting TEST_F77 to /home/yanglei/tmp/mpich1.2.7/bin/mpif77
setting CFLAGS to -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating localdefs
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating adio/include/romioconf.h
Finished configuring ROMIO
Configuring MPE Profiling Libraries with --enable-mpich --disable-checkMPI --with-f2cmpilibs=-lfmpich --with-flib_path_leader=-L --prefix=/opt/mpich --disable-short-longs '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' --includedir=/opt/mpich/include
checking gnumake... no
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH build
checking host system type... x86_64-unknown-linux-gnu
checking whether the C compiler (gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H ) works... yes
checking whether the C compiler (gcc -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H ) is a cross-compiler... no
checking for object suffix... o
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking whether MPI_CC has been set ... /home/yanglei/tmp/mpich1.2.7/bin/mpicc
checking whether MPI_F77 has been set ... /home/yanglei/tmp/mpich1.2.7/bin/mpif77
checking for Fortran 77 libraries... -L/opt/intel/fc/10.0.023/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32/.. -L/usr/lib -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl
checking Whether C can link with -L/opt/intel/fc/10.0.023/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/32/.. -L/usr/lib -lifport -lifcore -limf -lm -lipgo -lirc -lgcc_s -lirc_s -ldl... no
checking which libraries can be used... -lm -lgcc_s -ldl
checking for MPI_STATUS_IGNORE ... yes
checking for X... libraries /usr/lib64, headers
checking for dbx... no
checking for gdb... no
checking for working const... yes
checking whether byte ordering is bigendian... no
checking for long pointers... yes
checking for sysinfo... yes
checking for mkstemp... yes
checking for large file support ... yes
checking for sys/systeminfo.h... no
checking for getopt.h... yes
checking for stdarg is correct... yes
checking if compiler accepts prototypes... yes
checking for sighandler_t... no
creating Makefile
creating sbin/mpeinstall
creating src/Makefile_nompi
creating src/dbxerr.c
creating contrib/life/Makefile
creating contrib/mandel/Makefile
creating contrib/mastermind/Makefile
creating contrib/test/Makefile
creating mpeconf.h
mpeconf.h is unchanged
configuring in slog2sdk
running /bin/sh /home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/configure --enable-mpich --disable-checkMPI --with-f2cmpilibs=-lfmpich --with-flib_path_leader=-L --prefix=/opt/mpich --disable-short-longs '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' --includedir=/opt/mpich/include --cache-file=.././config.cache --srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk
Configuring SLOG2SDK with '--enable-mpich' '--disable-checkMPI' '--with-f2cmpilibs=-lfmpich' '--with-flib_path_leader=-L' '--prefix=/opt/mpich' '--disable-short-longs' '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' '--includedir=/opt/mpich/include' '--cache-file=.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk'
checking if CLASSPATH is set... no, good to go
checking build system type... x86_64-unknown-linux-gnu
checking for java in user's PATH... found /usr/java/latest/bin/java
checking if /usr/java/latest/bin/java works... yes
checking if /usr/java/latest/bin/java runs simple jar file... yes
checking if /usr/java/latest/bin/java runs simple Swing class... yes
checking if /usr/java/latest/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "1.6.0_07-b06", i.e. Java 2 SDK
checking for cygpath... no
checking for leftover Makefiles in subpackages ... "trace_sample" "trace_rlog" cleaned
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
configure: configuring in trace_sample
configure: running /bin/sh '/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample/configure' --prefix=/opt/mpich '--enable-mpich' '--disable-checkMPI' '--with-f2cmpilibs=-lfmpich' '--with-flib_path_leader=-L' '--prefix=/opt/mpich' '--disable-short-longs' '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' '--includedir=/opt/mpich/include' '--cache-file=.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk' --cache-file=../.././config.cache --srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample
Configuring TRACE_SAMPLE implementation with '--enable-mpich' '--disable-checkMPI' '--with-f2cmpilibs=-lfmpich' '--with-flib_path_leader=-L' '--prefix=/opt/mpich' '--disable-short-longs' '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' '--includedir=/opt/mpich/include' '--cache-file=.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk' '--cache-file=../.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_sample' 'CC=gcc' 'CFLAGS= -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H' 'F77=ifort '
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for an ANSI C-conforming const... yes
checking for __int64... no
checking size of __int64... 0
checking for sed... sed
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking how to recognise dependent libraries... pass_all
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for ifort option to produce PIC... -fPIC
checking if ifort PIC flag -fPIC works... yes
checking if ifort supports -c -o file.o... yes
checking whether the ifort linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... ifort: command line warning #10156: ignoring option '-p'; no argument required
ifort: command line error: no files specified; for help type "ifort -help"
GNU/Linux ld.so
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking for malloc in -lefence... no
checking for strstr... yes
checking target system type... x86_64-unknown-linux-gnu
checking for javah in user's PATH... found /usr/java/latest/bin/javah
checking if /usr/java/latest/bin/javah works... unknown!
checking if /usr/java/latest exists... yes
checking for <jni.h> include flag... found -I/usr/java/latest/include -I/usr/java/latest/include/linux
checking for <jni.h> usability... yes
config.status: creating bin/traceprint
config.status: creating bin/traceTOslog2
config.status: creating trace_impl.h
configure: configuring in trace_rlog
configure: running /bin/sh '/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog/configure' --prefix=/opt/mpich '--enable-mpich' '--disable-checkMPI' '--with-f2cmpilibs=-lfmpich' '--with-flib_path_leader=-L' '--prefix=/opt/mpich' '--disable-short-longs' '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' '--includedir=/opt/mpich/include' '--cache-file=.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk' --cache-file=../.././config.cache --srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog
Configuring TRACE_RLOG implementation with '--enable-mpich' '--disable-checkMPI' '--with-f2cmpilibs=-lfmpich' '--with-flib_path_leader=-L' '--prefix=/opt/mpich' '--disable-short-longs' '--libdir=${exec_prefix}/lib' '--bindir=${exec_prefix}/bin' '--includedir=/opt/mpich/include' '--cache-file=.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk' '--cache-file=../.././config.cache' '--srcdir=/home/yanglei/mpich-1.2.7p1/mpe/slog2sdk/trace_rlog' 'CC=gcc' 'CFLAGS= -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H' 'F77=ifort '
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
GNU/Linux ld.so
SLOG2SDK: "trace_sample" "trace_rlog" have been configured
Done configuring MPE Profiling Libraries
checking whether head command is broken... no
creating Makefile
creating util/Makefile
creating examples/Makefile
creating src/pt2pt/Makefile
creating src/coll/Makefile
creating src/context/Makefile
creating src/dmpi/Makefile
creating src/env/Makefile
creating src/topol/Makefile
creating src/profile/Makefile
creating src/coll2/Makefile
creating src/util/Makefile
creating src/infoexport/Makefile
creating examples/basic/Makefile
creating src/misc2/Makefile
creating src/external/Makefile
creating mpichconf.h
creating util/mpicc
creating util/mpicxx
creating util/mpiinstall
creating util/mpirun
creating util/mpichlib.conf
creating util/mpiman
creating util/chkserv
creating util/chkmachine
creating util/tstmachines
creating include/mpidefs.h
creating include/mpif.f90
Creating mpif.h from Fortran and Romio contributions
Configuring the test suite...
Configuring with args -basecc=gcc -cc=/home/yanglei/tmp/mpich1.2.7/bin/mpicc -make=make --no-print-directory -device=ch_p4 -mpichpath=/home/yanglei/tmp/mpich1.2.7/bin --enable-boot -cflags= -DUSE_SOCKLEN_T -DUSE_U_INT_FOR_XDR -DHAVE_MPICHCONF_H --disable-long-long --disable-long-double -basefc=ifort -fc=/home/yanglei/tmp/mpich1.2.7/bin/mpif77 --enable-io
checking for gnumake... no
checking for sleep... yes
checking for sysconf... yes
checking for sizeof MPI_Offset... 8
checking for libraries needed for Fortran command line access... unable to determine
creating Makefile
creating pt2pt/Makefile
creating coll/Makefile
creating topol/Makefile
creating context/Makefile
creating env/Makefile
creating profile/Makefile
creating io/Mfile
creating pt2pt/runtests
creating coll/runtests
creating topol/runtests
creating context/runtests
creating command/runtests
creating env/runtests
creating profile/runtests
creating io/rtest
creating io/misc.c
creating io/fmisc.f
creating io/fcoll_test.f
creating io/pfcoll_test.f
creating io/large_file.c
creating io/fperf.f
Configuring the performance tests ...
checking whether build environment is sane... yes
checking whether make --no-print-directory sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking for cit... no
checking for gnuplot... no
checking whether C compiler accepts option -O4 -Ofast... no
checking whether C compiler accepts option -Ofast... no
checking whether C compiler accepts option -fast... no
checking whether C compiler accepts option -O3... yes
checking whether routines compiled with -O3 can be linked with ones compiled without -O3... yes
checking for library containing fabs... -lm
checking for sys/time.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
creating Makefile
creating mpptestconf.h
mpptestconf.h is unchanged
creating mpid/ch_p4/Makefile
creating mpid/tests/Makefile
mpichconf.h is unchanged
*# You should register your copy of MPICH with us by sending mail
*# to majordomo at mcs.anl.gov containing the message
*# subscribe mpi-users
*# This will allow us to notify you of new releases of MPICH.
*# You can also check the MPICH home page at
*# http://www.mcs.anl.gov/mpi/mpich
Old style arguments to configure were found:
Use the environment variable CC instead of configure argument -cc=gcc Use the environment variable FC instead of configure argument -fc=ifort
Configuration completed.
if [ "/opt/mpich" = "/opt/mpich" ] ; then \
./bin/mpiinstall ; \
else \
./bin/mpiinstall -prefix=/opt/mpich ; \
fi
Installing documentation ...
Done installing documentation
Installing manuals
Done installing manuals
Installing MPE
Copying MPE include files to /opt/mpich/include
Copying MPE libraries to /opt/mpich/lib
Copying MPE utility programs to /opt/mpich/bin
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/opt/mpich/include -c cpi.c
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_log cpi.o -L/opt/mpich/lib -llmpe -lmpe -lm
/usr/bin/ld: warning: i386 architecture of input file `/opt/mpich/lib/libmpich.a(initfcmn.o)' is incompatible with i386:x86-64 output
/usr/bin/ld: warning: i386 architecture of input file `/opt/mpich/lib/libmpich.a(initfdte.o)' is incompatible with i386:x86-64 output
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_trace cpi.o -L/opt/mpich/lib -ltmpe -lm
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpi_anim cpi.o -L/opt/mpich/lib -lampe -lmpe -L/usr/lib64 -lX11 -lm
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/opt/mpich/include -c cxgraphics.c
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cxgraphics cxgraphics.o -L/opt/mpich/lib -lmpe -L/usr/lib64 -lX11 -lm
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -I/opt/mpich/include -c cpilog.c
/opt/mpich/bin/mpicc -DMPI_LINUX -DUSE_STDARG -DHAVE_PROTOTYPES -o cpilog cpilog.o -L/opt/mpich/lib -llmpe -lmpe -lm
/opt/mpich/bin/mpif77 -I/opt/mpich/include -c fpi.f
/opt/mpich/bin/mpif77 -o fpilog fpi.o -L/opt/mpich/lib -lfmpich -llmpe -lmpe -lm
ld: skipping incompatible /opt/mpich/lib/libfmpich.a when searching for -lfmpich
make[2]: *** [fpilog] Error 1
/opt/mpich/bin/mpif77 -I/opt/mpich/include -c fxgraphics.f
/opt/mpich/bin/mpif77 -o fxgraphics fxgraphics.o -L/opt/mpich/lib -lmpe -L/usr/lib64 -lX11 -lm
ld: skipping incompatible /opt/mpich/lib/libmpe.a when searching for -lmpe
make[2]: *** [fxgraphics] Error 1
Replacing existing file /opt/mpich/lib/clog2print.jar...
Replacing existing file /opt/mpich/lib/clog2TOdrawable.jar...
Replacing existing file /opt/mpich/lib/clog2TOslog2.jar...
Replacing existing file /opt/mpich/lib/clogprint.jar...
Replacing existing file /opt/mpich/lib/clogTOdrawable.jar...
Replacing existing file /opt/mpich/lib/clogTOslog2.jar...
Replacing existing file /opt/mpich/lib/jumpshot.jar...
Replacing existing file /opt/mpich/lib/jumpshot_launcher.jar...
Replacing existing file /opt/mpich/lib/logconvertor.jar...
Replacing existing file /opt/mpich/lib/slog2filter.jar...
Replacing existing file /opt/mpich/lib/slog2navigator.jar...
Replacing existing file /opt/mpich/lib/slog2printrecur.jar...
Replacing existing file /opt/mpich/lib/slog2printserial.jar...
Replacing existing file /opt/mpich/lib/slog2update205to206.jar...
Replacing existing file /opt/mpich/lib/traceprint.jar...
Replacing existing file /opt/mpich/lib/traceTOslog2.jar...
Replacing existing file /opt/mpich/doc/jumpshot-4/usersguide.pdf...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/About24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/adj_row_count.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/adj_row_height.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Backward24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/contents.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Convert24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ConvertCancel24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ConvertOk24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/convertor_done.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/convertor_init.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/convertor_parameters.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/convertor_progress.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Delete24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Down24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Edit24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Find24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/FindBack24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/FindFore24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Forward24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/HandCloseUpLeft25.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/HandOpenUpLeft25.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Help24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_arrow_infobox.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_arrow.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_mpi_overhead.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_state_all_cumu_excl.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_state_infobox.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/histogram_state_over_incl.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Home24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/index.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Information24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/internals.pl...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/labels.pl...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_checkbox_menu.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_color_chooser.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_name.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_popup.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_sort_menu.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_s.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_topo.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/legend_v.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/main.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/mouse_hand_mode.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/mouse_zoom_mode.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/New24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/next_g.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/next.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node10.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node11.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node12.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node13.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node14.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node15.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node16.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node17.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node18.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node19.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node1.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node20.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node21.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node22.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node23.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node24.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node25.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node26.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node27.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node28.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node29.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node2.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node30.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node31.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node32.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node33.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node34.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node3.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node4.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node5.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node6.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node7.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node8.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/node9.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Open24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Paste24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/preference_pview_state.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Preferences24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/prev_g.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/prev.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Print24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Properties24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Refresh24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Stop24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_infobox_duration.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_infobox_preview_state.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_infobox_real_primitive.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_infobox_time.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_mpi_overhead.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_nesting_detail.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_nesting_legend_innermost.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_nesting_legend_middle.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_nesting_legend_outermost.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_nesting_preview_all.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_popup_finer.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_popup.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_0_excl.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_0.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_1_excl.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_1.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_2.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_3.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_preview_detail_4.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_search_preview.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/timeline_search_preview_zoomed.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/TreeCollapse24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/TreeExpand24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/Up24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/up_g.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/up.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/usersguide.css...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/usersguide.html...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/WARNINGS...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/WinRedo.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/WinUndo.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/yaxis_label_panel_expanded.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/yaxis_label_panel_simple.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ZoomIn24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ZoomMinusUpLeft25.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ZoomOut24.png...
Replacing existing file /opt/mpich/doc/jumpshot-4/html/ZoomPlusUpLeft25.png...
Replacing existing file /opt/mpich/logfiles/fpilog.clog...
Replacing existing file /opt/mpich/logfiles/fpilog.slog2...
Replacing existing file /opt/mpich/lib/libTraceInput.la...
Replacing existing file /opt/mpich/lib/libTraceInput.so...
Replacing existing file /opt/mpich/logfiles/barrier.rlog...
-rpath /opt/mpich/lib ; \
else \
fi
/bin/sh ../libtool --mode=install /usr/bin/install -c libTraceInput.la /opt/mpich/lib
/usr/bin/install -c .libs/libTraceInput.so /opt/mpich/lib/libTraceInput.so
/usr/bin/install -c .libs/libTraceInput.lai /opt/mpich/lib/libTraceInput.la
PATH="$PATH:/sbin" ldconfig -n /opt/mpich/lib
/opt/mpich/lib
during execution
during linking
/bin/sh ../libtool --finish /opt/mpich/lib
/opt/mpich/lib
during execution
during linking
Replacing existing file /opt/mpich/bin/rlog_check_timeorder...
Replacing existing file /opt/mpich/bin/rlogprint...
Replacing existing file /opt/mpich/bin/rlog_print...
Replacing existing file /opt/mpich/bin/rlogTOslog2...
Installed TRACE_RLOG in /opt/mpich
/opt/mpich/sbin/mpiuninstall may be used to remove the installation
Installed SLOG2SDK in /opt/mpich
creating Makefile
About to run installation test...
/opt/mpich/bin/mpicc -c cpi.c
/opt/mpich/bin/mpicc -o cpi cpi.o -lm
/opt/mpich/bin/mpicc -c simpleio.c
/opt/mpich/bin/mpicc -o simpleio simpleio.o
/opt/mpich/bin/mpicxx -c hello++.cc
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/backward/iostream.h:31,
from hello++.cc:29:
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <iostream> instead of the deprecated header <iostream.h>. To disable this warning use -Wno-deprecated.
/opt/mpich/bin/mpicxx -o hello++ hello++.o
/opt/mpich/bin/mpif77 -c pi3.f
/opt/mpich/bin/mpif77 -o pi3 pi3.o
ld: skipping incompatible /opt/mpich/lib/libmpich.a when searching for -lmpich
ld: cannot find -lmpich
make[2]: *** [pi3] Error 1
/opt/mpich/bin/mpif77 -c pi3p.f
/opt/mpich/bin/mpif77 -o pi3p pi3p.o
make[2]: *** [pi3p] Error 1
make[1]: *** [all] Error 2
rm -f *.o *~ PI* cpi pi3 simpleio hello++ pi3f90 cpilog
rm -rf SunWS_cache ii_files pi3f90.f pi3p cpip *.ti *.ii
installed MPICH in /opt/mpich
/opt/mpich/sbin/mpiuninstall may be used to remove the installation.
