[mpich-discuss] MPICH2 and Windows Vista
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Oct 9 09:22:07 CDT 2009
Let us know if you need help.
(PS: Try re-compiling the code and running it - it could be as simple as a
user privilege issue.)
Jayesh
_____
From: Ian D Chivers [mailto:ian.chivers at chiversandbryan.co.uk]
Sent: Friday, October 09, 2009 6:05 AM
To: 'Jayesh Krishna'
Subject: RE: [mpich-discuss] MPICH2 and Windows Vista
Hi
I've tried one of the simple Fortran 90 programs
(pi3.f90) and this works.
Many apologies.
I will look into my own code
Mea culpa!
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: 08 October 2009 17:44
To: ian.chivers at chiversandbryan.co.uk
Cc: mpich-discuss at mcs.anl.gov
# Have you registered your username/password correctly (mpiexec -remove;
mpiexec -register; mpiexec -validate)?
# Can you run simple non-MPI programs like hostname (mpiexec -n 2
hostname)?
# Are you using a shared drive for your executable (Use the "-map" option
to map shared drives for your MPI job)?
Make sure that you copy-paste the command and the output of the command
in your email (Don't re-type).
On a side note, MPICH2 currently does not support heterogeneous systems.
So you cannot run jobs spanning 32-bit and 64-bit systems.
Jaeysh
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
Sent: Thursday, October 08, 2009 10:53 AM
Subject: [mpich-discuss] MPICH2 and Windows Vista
I'm having problems running mpich2 under windows vista.
The systems are running
System A: vista home premium sp2 64 bit - mpich2-1.0.8-win-x86-640 System
B: vista home premium sp2 64 bit - mpich2-1.1.1p1-win-x86-64
System C: vista home basic sp2 32 bit - mpich2-1.1.1p1win-ia32
earlier this year I had system A working. B and C were installed this
week.
On system A all I remember having to do was switch the Windows firewall
off.
with A, B and C I have now tried switching off
Windows firewall
User Account Control
On system A i can do
smpd -install
and from another dos box I can run
smpd -status
and this reports that smpd is running.
However when trying
mpiexec -n 4 mpi_example01.exe
i get
launch failed: CreateProcess(mpi_example01.exe) on 'hornbeam' failed,
error 5 - Access is denied.
I get similar problems on B and C.
Is this problem resolvable with Vista?
If not what versions of the Windows operating system do people recommend
with MPICH2?
It is quite frustrating because I was getting quite good program speed up
on the quad core system earlier this year.
thanks in advance
ian chivers
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091009/eb603172/attachment.htm>
