[mpich-discuss] Fwd: regarding MPICH2-1.1.1p1 installation
Anuj Patel indyaah at gmail.com
Mon Oct 5 12:33:16 CDT 2009
---------- Forwarded message ----------
Date: Mon, Oct 5, 2009 at 10:31 PM
Subject: regarding MPICH2-1.1.1p1 installation
To: mpich2-maint at mcs.anl.gov
Dear Sir/Madam,
We are currently working on Cluster Configuration on Fedora Core 11, with
MPICH2-1.1.1p1 and while i performed the following command
make installcheck PACKAGE=mpich2-1.1.1p1
we had error. I have redirectd o/p in a file and attached here with if you
can analyze and reply to it we'll be very thankful to you.
Thank you
Anuj Patel
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091005/f8e993c7/attachment.htm>
for dir in src/util/thread src/env src/packaging/pkgconfig src/packaging/envmods  src/binding/f77 src/binding/f90 src/binding/cxx  src/openpa src/pm/mpd src/mpe2 - ; do \
		if [ "$dir" = "-" ] ; then break ; fi ; \
		(cd $dir && make installcheck ; ) ; done
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/util/thread'
make[1]: Nothing to be done for `installcheck'.
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/util/thread'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/env'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/env'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/packaging/pkgconfig'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/packaging/pkgconfig'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/packaging/envmods'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/packaging/envmods'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/binding/f77'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/binding/f77'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/binding/f90'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/binding/f90'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/binding/cxx'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/binding/cxx'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/openpa'
Making installcheck in src
make[2]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/openpa/src'
make[2]: Nothing to be done for `installcheck'.
make[2]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/openpa/src'
Making installcheck in test
make[2]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/openpa/test'
make[2]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/openpa/test'
make[2]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/openpa'
make[2]: Nothing to be done for `installcheck-am'.
make[2]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/openpa'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/openpa'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/pm/mpd'
make[1]: *** No rule to make target `installcheck'.  Stop.
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/pm/mpd'
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/mpe2'
Running installation linktest for C logging program...
*** Link C program with the MPI tracing library .......................... Yes.
*** Link C program with the MPI logging library .......................... Yes.
*** Link C program with the MPI and manual logging libraries ............. Yes.
Running installation linktest for Fortran logging program...
*** Link F77 program with the MPI and manual logging libraries ........... Yes.
Running installation linktest for C graphics program...
*** Link C program with the MPI animation library ........................ Yes.
*** Link C program with the X11 graphics library ......................... Yes.
Running installation linktest for Fortran graphics program...
*** Link F77 program with the X11 graphics library ....................... Yes.
Running installation linktest for C collchk program...
*** Link C program with the MPI collective/datatype checking library ..... Yes.
Running installation linktest for Fortran collchk program...
*** Link F77 program with the MPI collective/datatype checking library ... Yes.
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/mpe2'
make installcheck-postamble
make[1]: Entering directory `/root/mpi/mpich2-1.1.1p1'
make[2]: Entering directory `/root/mpi/mpich2-1.1.1p1/src/mpe2'
Running installation runtest for C logging program...
*** Test C program with the MPI tracing library .......................... No.
    The failed command is :
/root/mpi/mpich2-install/bin/mpiexec -n 4 cpi_trace
mpiexec failed: gethostbyname_ex failed for indyaah.destiny
*** Test C program with the MPI logging library .......................... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 cpi_log
*** Test C program with the MPI and manual logging libraries ............. No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 cpilog
Running installation runtest for Fortran logging program...
*** Test F77 program with the MPI and manual logging libraries ........... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 fpilog
Running installation runtest for C graphics program...
*** Test C program with the MPI animation library ........................ No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 cpi_anim
*** Test C program with the X11 graphics library ......................... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 cxgraphics
Running installation runtest for Fortran graphics program...
*** Test F77 program with the X11 graphics library ....................... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 fxgraphics
Running installation runtest for C collchk program...
*** Test C program with the MPI collective/datatype checking library ..... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 wrong_int_byte
Running installation runtest for Fortran collchk program...
*** Test F77 program with the MPI collective/datatype checking library ... No.
/root/mpi/mpich2-install/bin/mpiexec -n 4 wrong_reals
make[2]: Leaving directory `/root/mpi/mpich2-1.1.1p1/src/mpe2'
make[1]: Leaving directory `/root/mpi/mpich2-1.1.1p1'
