[mpich-discuss] Problems running mpi applicationon	differentCPUs
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sat Oct  3 17:22:50 CDT 2009
Just run a few from the test/mpi/coll directory by hand. Run make in
that directory, then do mpiexec -n 5 name_of_executable. If they run,
there may be a bug in your code.
Rajeev
> -----Original Message-----
> From: Gaetano Bellanca [mailto:gaetano.bellanca at unife.it]
> Sent: Saturday, October 03, 2009 2:58 AM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problems running mpi
> Dear Rajeev
> cpi test (and other tests in examples directory) works
> without problems.
> I tried to run make in the test directory and had this error message:
> make[2]: Entering directory
> `/home/bellanca/software/mpich2/1.1.1p1/mpich2-1.1.1p1_intel/t
> est/mpid/ch3'
> make[2]: *** No rule to make target `../../../lib/lib.a',
> needed by `reorder'.  Stop.
> How should I run the tests from the  ../test directory?
> I tried with make testing, but I had a lot of unexpected
> output from mpd
> Regards
> Gaetano
> Rajeev Thakur ha scritto:
> > Try running the cpi example from the mpich2/examples directory. Try
> > running some of the tests in test/mpi.
> > Rajeev
> >> From: mpich-discuss-bounces at mcs.anl.gov
> >> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gaetano
> >> Bellanca
> >> Sent: Tuesday, September 29, 2009 9:13 AM
> >> To: mpich-discuss at mcs.anl.gov
> >> Subject: Re: [mpich-discuss] Problems running mpi applicationon
> >> differentCPUs
> >> Dear Rajeev,
> >> I tested as indicated in the appendix of the installation
> guide using
> >> mpdcheck (and also changing the device using ch3:nemesis
> (thank you
> >> for the suggestion, Cye)) but nothing changes in the
> behavior of the
> >> code.
> >> However I noted that, changing the machinefile for not to have the
> >> server machine as a first one, I have different behaviors. In
> >> particular running with mpiexec -machinefile my_machinefile -n 6
> >> my_parallel_code and:
> >> 1) machinefile as follows
> >> server
> >> server
> >> client1
> >> client2
> >> client3
> >> client4
> >> client5
> >> the code starts with the previous error Fatal error in MPI_Init:
> >> Other MPI error, error stack:
> >>  > >> MPIR_Init_thread(394): Initialization failed  > >>
> >> (unknown)(): Other MPI error
> >>  > >> rank 3 in job 8  c1_4545   caused collective abort
> of all ranks
> >>  > >>  exit status of rank 3: return code 1
> >> 2) machinefile as follows
> >> client2
> >> client3
> >> client4
> >> client5
> >> server
> >> server
> >> the code starts with a SIGSEGV segmentation fault at the
> line of the
> >> MPI_INIT
> >> 3) machinefile as follows
> >> client2
> >> client3
> >> server
> >> server
> >> client4
> >> client5
> >> the code starts regularly, but stops working in the first file
> >> writing procedure.
> >> It produces a file of 0 bytes, but does not advance in any other
> >> procedure, and I have to kill to terminate.
> >> Could it be something relevant to a
> synchronization/timeout between
> >> the different machines?
> >> On another cluster (all Pentium IV 3GHz), the same program
> is slower
> >> to start when launched, but everything works fine.
> >> Regards.
> >> Gaetano
> >>> ch3:sock won't perform as well as ch3:nemesis though.
> >>> Rajeev
> >>>     *From:* mpich-discuss-bounces at mcs.anl.gov
> >>>     [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf
> >> Of *Cye Stoner
> >>>     *Sent:* Monday, September 28, 2009 4:32 PM
> >>>     *To:* mpich-discuss at mcs.anl.gov
> >>>     *Subject:* Re: [mpich-discuss] Problems running mpi
> >> application on
> >>>     differentCPUs
> >>>     When deploying MPICH2 to a small cluster, I noticed
> >> that many had
> >>>     problems with the "--with-device=ch3:nemesis"
> >>>     Try using the "--with-device=ch3:sock" interface instead.
> >>>     Cye
> >>>     On Mon, Sep 28, 2009 at 12:13 PM, Rajeev Thakur
> >>>     <thakur at mcs.anl.gov <mailto:thakur at mcs.anl.gov>> wrote:
> >>>         Try using the mpdcheck utility to debug as
> described in the
> >>>         appendix of
> >>>         the installation guide. Pick one client and the server.
> >>>         Rajeev
> >>>         <mailto:mpich-discuss-bounces at mcs.anl.gov>
> >>>         <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of
> >>>         > Gaetano Bellanca
> >>>         > Sent: Monday, September 28, 2009 6:00 AM
> >> <mailto:mpich-discuss at mcs.anl.gov>
> >> application
> >>>         > on different CPUs
> >>>         > Dear Rajeev,
> >>>         > thanks for your help. I disabled the firewall on
> >> the server
> >>>         (the only
> >>>         > one running) and tried with any other combination.
> >>>         > All the clients together are running correctly.
> >> The same for the
> >>>         > processors on the server separately.
> >>>         > The problem is only when I mix processes on the
> >> server and on
> >>>         > the client.
> >>>         > When I run mpdtrace on the server, all the CPUs are
> >>>         > responding correctly.
> >>>         > The same happens if I run in parallel 'hostname'
> >>>         > Probably, it is a problem of my code, but it works on a
> >>>         cluster of 10
> >>>         > Pentium IV PEs.
> >>>         > I discover a 'strange behavior':
> >>>         > 1) running the code with the server as a first
> >> machine of the
> >>>         > pool, the
> >>>         > code hangs with the previously communicated error;
> >>>         > 2) if I put the server as a second machine of the
> >> pool, the
> >>>         > code starts
> >>>         > and works regularly up to the writing procedures,
> >> opens the
> >>>         > first file
> >>>         > and then remains indefinitely waiting for something;
> >>>         > Should I compile mpich2 with some particular
> >> communicator? I
> >>>         have
> >>>         > nemesis, at the moment.
> >>>         > I'm using this for mpich2 compilation:
> >>>         > ./configure --prefix=/opt/mpich2/1.1/intel11.1
> >> --enable-cxx
> >>>         > --enable-f90
> >>>         > --enable-fast --enable-traceback --with-mpe
> >> --enable-f90modules
> >>>         > --enable-cache --enable-romio
> >> --with-file-system=nfs+ufs+pvfs2
> >>>         > --with-device=ch3:nemesis --with-pvfs2=/usr/local
> >>>         > --with-java=/usr/lib/jvm/java-6-sun-1.6.0.07/
> >>>         --with-pm=mpd:hydra
> >>>         > Regards
> >>>         > Gaetano
> >>>         > > Try running on smaller subsets of the machines
> >> to debug the
> >>>         > problem. It
> >>>         > > is possible that a process on some machine
> >> cannot connect
> >>>         to another
> >>>         > > because of some firewall settings.
> >>>         > > Rajeev
> >>>         > Gaetano Bellanca
> >>>         > >> Sent: Saturday, September 26, 2009 7:10 AM
> >>>         > >> Subject: [mpich-discuss] Problems running mpi
> >> application on
> >>>         > >> different CPUs
> >>>         > >> Hi,
> >>>         > >> I'm sorry but  I posted with a wrong Object
> my previous
> >>>         message!!!
> >>>         > >> I have a small cluster of
> >>>         > >> a) 1 server: dual processor / quad core
> >> Intel(R) Xeon(R)
> >>>         CPU  E5345
> >>>         > >> b) 4 clients: single processor / dual core Intel(R)
> >>>         > Core(TM)2 Duo CPU
> >>>         > >> E8400 connected  with a 1Gbit/s ethernet network.
> >>>         > >> I compiled mpich2-1.1.1p1 on the first system (a) and
> >>>         > share mpich on
> >>>         > >> the other computers via nfs. I have mpd
> >> running as a root
> >>>         > on all the
> >>>         > >> computers (ubunt 8.04 . kernel 2.6.24-24-server)
> >>>         > >> When I run my code in parallel on the first
> >> system, it works
> >>>         > >> correctly; the same happens running the same code  in
> >>>         > parallel on the
> >>>         > >> other computers (always running the code from the
> >>>         server). On the
> >>>         > >> contrary, running the code using processors
> >> from both the
> >>>         > server and
> >>>         > >> the clients at the same time with the command:
> >>>         > >> mpiexec -machinefile machinefile -n 4
> my_parallel_code
> >>>         > >> I receive this error message:
> >>>         > >> Fatal error in MPI_Init: Other MPI error,
> error stack:
> >> abort of all
> >>>         ranks
> >>>         > >> Should I use some particular flags in
> compilation or at
> >>>         run time?
> >>>         > >> Regards.
> >>>         > >> Gaetano
> >>>         > >> Gaetano Bellanca - Department of Engineering -
> >> University
> >>>         > of Ferrara
> >>>         > >> Via Saragat, 1 - 44100 - Ferrara - ITALY
> Voice (VoIP):
> >>>         +39 0532
> >>>         > >> 974809 Fax: +39 0532 974870
> >>>         <mailto:gaetano.bellanca at unife.it>
> >>>         > >> L'istruzione costa? Stanno provando con l'ignoranza!
> >> University of
> >>>         Ferrara
> >>>         > Voice (VoIP): +39 0532 974809 Fax: +39 0532 974870
> >>>     "If you already know what recursion is, just remember
> >> the answer.
> >>>     Otherwise, find someone who is standing closer to
> >>>     Douglas Hofstadter than you are; then ask him or her what
> >>>     recursion is." - Andrew Plotkin
> >> Gaetano Bellanca - Department of Engineering - University
> of Ferrara
> >> Via Saragat, 1 - 44100 - Ferrara - ITALY Voice
> Gaetano Bellanca - Department of Engineering - University of
> Ferrara Via Saragat, 1 - 44100 - Ferrara - ITALY Voice
