[mpich-discuss] -channel shm
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Oct 1 14:50:03 CDT 2009
Make sure that you uninstall any existing versions of MPICH2 before
installing a new version.
Jayesh
_____
Sent: Thursday, October 01, 2009 2:47 PM
To: 'Jayesh Krishna'
Subject: RE: [mpich-discuss] -channel shm
Jayesh,
I found the problem - we don't have the mpich2nemesis.dll in our standard
installation directory.
F:\2010_winter_update\test_problems\bug 2619\test\Design 1\Scenario
1>f:\2010_winter_update\build\x64\mpiexec2 -n 5 -channel nemesis
\build\x64\cfdcalc "Scenario 1" -b -mpi
Unable to load 'mpich2nemesis.dll', error 126
MPI_Comm_size fails to determine the number of processors
MPI_Comm_rank fails to determine the processor id
ProgramDir = F:/2010_winter_update/build/x64
I need to check our version of mpich2 and make sure we have
mpich2nemesis.dll available in our installation directory.
Thanks, Dave.
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Thursday, October 01, 2009 11:46 AM
To: 'dave waite'
Cc: mpich-discuss at mcs.anl.gov
Make sure that you are using the latest stable version of MPICH2
(1.1.1p1) available at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=down
loads .
Let us know if you still have problems (If you still have problems in
your email include the complete command that you use to launch your MPI
job. If possible, include a test program so that we can recreate your
problem.).
Jayesh
_____
Sent: Thursday, October 01, 2009 1:26 PM
Jayesh,
When I run using -n 5 -channel shm, my application has one master rank
and 4 slave ranks. When I run using -n 5 -channel nemesis, all 5
instances of my application have rank = master. Is there some other
mpiexec arguments needed when running nemesis?
Dave Waite.
Sent: Thursday, October 01, 2009 11:00 AM
To: 'dave waite'
The SHM channel is old (It is already deprecated on unix, it will be
deprecated on windows in the upcoming release). Use the newer Nemesis
channel (-channel nemesis) instead.
Jayesh
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of dave waite
Sent: Thursday, October 01, 2009 12:43 PM
Subject: [mpich-discuss] -channel shm
Using mpich2 on windows, when we run mpiexec using the -localonly -channel
shm options, we see that all cores spin at all times(100% CPU Usage
History, Windows Task Manager). Without, the -channel shm option, cores
show cpu activity only when they are actively computing. Is that a way to
use the -channel shm option and not have the infinite spin limit on the
cores?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091001/82249387/attachment-0001.htm>
