[mpich-discuss] MPI_Comm_accept() / connect() errors
Blesson Varghese b.varghese at student.reading.ac.uk
Thu Oct 1 05:56:52 CDT 2009
The following is the information you have requested.
- The output of the "ompi_info --all" is attached with the email
- PATH Variable:
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr
/local/maui/bin/:
- LD_LIBRARY_PATH variable was empty
- The following is the output of ifconfig on hpcc00 from where the error has
been generated:
eth0      Link encap:Ethernet  HWaddr 00:12:3f:4c:2d:78
          inet addr:134.225.200.100  Bcast:134.225.200.255
Mask:255.255.255.0
          inet6 addr: fe80::212:3fff:fe4c:2d78/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:15912728 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15312376 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2951880321 (2.7 GB)  TX bytes:2788249498 (2.5 GB)
          Interrupt:16
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:3507489 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3507489 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1794266658 (1.6 GB)  TX bytes:1794266658 (1.6 GB)
Blesson.
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jeff Squyres
Sent: 30 September 2009 13:23
Subject: Re: [mpich-discuss] MPI_Comm_accept() / connect() errors
Can you send all the information listed here:
     http://www.open-mpi.org/community/help/
Thanks.
On Sep 30, 2009, at 8:16 AM, Blesson Varghese wrote:
> Hi,
> I am running MPI 2.0 on Ubuntu 4.2.4, kernel version 2.6.24.
> I have been trying to execute the server.c and client.c program
> provided in http://www.mpi-forum.org/docs/mpi21-report/node213.htm#Node213
> , using accept() and connect() function in MPI. However, the
> following errors are generated.
> [hpcc00:16522] *** An error occurred in MPI_Comm_connect
> [hpcc00:16522] *** on communicator MPI_COMM_WORLD
> [hpcc00:16522] *** MPI_ERR_INTERN: internal error
> [hpcc00:16522] *** MPI_ERRORS_ARE_FATAL (goodbye)
> I ran the server program as mpirun -np 1 server. This program gave
> me the output port as 0.1.0:2000. I used this port name as the
> command line argument to execute the client program as mpirun -np 1
> client 0.1.1:2000
> Could you please advice?
> Many thanks,
> Blesson.
Jeff Squyres
jsquyres at cisco.com
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091001/011908e6/attachment-0001.txt>
