[mpich-discuss] Windows version
Jayesh Krishna jayesh at mcs.anl.gov
Wed Nov 25 11:00:48 CST 2009
 The MPI programs that you write in C or fortran should work with MPICH2 on windows. We provide pre-compiled libraries, compatible with gnu compilers like gcc/g77, with the MPICH2 installation on windows that can be used with gcc/g77 from a cygwin environment.
 You can run your MPI programs on the local machine or a cluster of machines.
(PS: A lot of our users also install MPICH2 on cygwin - configure/make/make install)
Jayesh
----- Original Message -----
From: "Nesan Antonyraj" <Gnananesan-Antonyraj at utc.edu>
To: balaji at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Wednesday, November 25, 2009 10:47:13 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Windows version
Is the Windows version to be used in conjunction with Windows based programming, like Visual C, C++?  I still need a Cluster to test MPI, am I correct?
Nesan.
-----Original Message-----
To: Gnananesan-Antonyraj at utc.edu
Date: Tue, 24 Nov 2009 20:00:23 -0600
Subject: Re: [mpich-discuss] mpich2 configure error
Hmm.. It looks like you have clock_gettime on your system, but it's not
a part of librt.a. This is partly an error in configure itself, which
I'll poke into.
In the meanwhile, can you configure with
--enable-timer-type=gettimeofday and see if that gets you past this problem?
Alternatively, we provide windows binaries on our website:
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
if you want to use those instead.
 -- Pavan
On 11/24/2009 07:49 PM, Nesan Antonyraj wrote:
> Thanks Mr. Balaji.  Attached is the configure output text c.txt.  I am configuring within cygwin with the command,
> c:/nesan/libraries/mpich2-1.2.1/configure -prefix=c:/build 2>&1 | tee c.txt
> thanks,
> Nesan.
> From: Pavan Balaji <balaji at mcs.anl.gov>
> To: Gnananesan-Antonyraj at utc.edu, mpich-discuss at mcs.anl.gov
> Date: Tue, 24 Nov 2009 19:45:38 -0600
> Can you send us the entire configure output? It's very hard to say what
> the problem is based on just the below information.
>     for csh and tcsh:
>       ./configure --prefix=/home/you/mpich2-install |& tee c.txt
>     for bash and sh:
>       ./configure --prefix=/home/you/mpich2-install 2>&1 | tee c.txt
>  -- Pavan
> On 11/24/2009 07:42 PM, Nesan Antonyraj wrote:
>> Hello,
>> I am getting the error below when configuring mpich2-1.2.1.  Please advise.
>> configure: error: Requested timer clock_gettime (POSIX) is not available
>> thanks,
>> Nesan.
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
