[mpich-discuss] Can I run MPI program without mpirun/mpiexec?
chan at mcs.anl.gov chan at mcs.anl.gov
Fri Nov 20 16:49:31 CST 2009
----- "junli gu" <gujunli at gmail.com> wrote:
> Hi everyone:
>  I want to run mpi program like a normal binary without
> mpirun/mpiexec
> command, like this: ./mpi_hello . Is this possible?
Yes. but without mpiexec, you can only run 1 process.
> This is possible only that I can compile mpi program and put all the
> runtime
> information into a stand alone binary. I don't know if it is
> possible.
Hmm... Since you are using a cross-compiler, alpha-gcc, not sure how
you built it...  Trying adding -static during linking to see if it
links OK.
A.Chan
>  Thank you very much!
> Junli Gu--谷俊丽
> Coordinate Science Lab
> University of Illinois at Urbana-Champaign
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
