[mpich-discuss] [mpich2-dev] About WMPICONFIG
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Thu Nov 19 10:24:51 CST 2009
 Look into the source code of wmpiconfig (https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/pm/smpd/wmpiconfig/) for the required information.
 Let us know if you need further help.
Jayesh
----- Original Message -----
To: "jayesh krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, November 19, 2009 7:00:09 AM GMT -06:00 US/Canada Central
Subject: Re: Re: [mpich2-dev] About WMPICONFIG
Thank you for you answer! I have installed MPICH2 according to the instructions and it runs well in two machines. But I want to check which machines in the workgroup has installed MPICH2 in my own program.If WMPIconfig can be used in command line,that I can use it in my own program. But it has GUIS, I can't use it.My English is poor,I don't if I have expressed my proble exactly and clearly.
> Hi,
> Install the same version of MPICH2 on all the machines and you should be good to go (Make sure that all the machines have the same data model - all are x64 machines or all are ia32 machines). Also make sure that the firewalls are turned off on all the machines (or look into the windows developer's guide - available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs - for info on how to config MPICH2 with windows firewall)
> Let us know if it works for you.
> (PS: mpich-discuss would be the right mailing list for your emails)
> Regards,
> Jayesh
> From: "吴炜" <wuwei at irsa.ac.cn>
> To: mpich2-dev at mcs.anl.gov
> Sent: Wednesday, November 18, 2009 5:18:59 AM GMT -06:00 US/Canada Central
> Subject: [mpich2-dev] About WMPICONFIG
> Hello,Can I config MPI in command line? I want to get the computers which has installed MPICH2 in the loacl area web .My OS is Windows XP. My English is poor, I don't know if I express the problem exactly.
