[mpich-discuss] 答复: how to connect MPI_Send with CH3_isend
hu yaohui loki2441 at gmail.com
Fri Nov 13 03:02:25 CST 2009
thank you very much!
2009/11/13 Darius Buntinas <buntinas at mcs.anl.gov>
> The ability to use different networks for different
> destinations is a feature we intend to add, but it's not
> yet implemented.  Nemesis does use shared-memory communication
> for intranode communication and the network for internode.
> There are several internal interfaces for porting MPICH2 to new
> platforms or interconnects.  This paper has a description of the
> interfaces:
> http://www.mcs.anl.gov/~buntinas/papers/europvmmpi06-nemesis.pdf
> If you're interested in porting MPICH2 to a new interconnect,
> you should write a nemesis network module.  The API is described
> here:
> http://wiki.mcs.anl.gov/mpich2/index.php/Nemesis_Network_Module_API
> I hope this helps,
> -d
> On 11/12/2009 11:29 PM, yaohui wrote:
> > Thank you very much!
> >       Finally I got a response!
> > I am doing some researches on adding HT(HyperTransport) into mpich2,I am
> > just wandering when we configure the mpich2 with
> >                       ./configure ¨Cwith-device=ch3:sock (ch3:nemesis)
> > that means we definitely select one network as the channel to
> communicate,
> > but if there are any possibilities that you can dynamic
> > control the network we use ,sometimes messages go through Ethernet,
> > sometimes go through IB. could you give me some materials
> > to understand what's the difference between ~/ch3/channel/sock
> > ,~/ch3/channel/sctp ~,~/ch3/channel/nemesis/nemesis/net_mod/tcp_module
> > , ~/ch3/channel/nemesis/nemesis/net_mod/sctp_module,
> > ~/ch3/channel/nemesis/nemesis/net_mod/ib_module
> > Thank you again!
> > Best Wishes!
> > -----ÓʼþÔ­¼þ-----
> > ·¢¼þÈË: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs
> > anl.gov] ´ú±í Darius Buntinas
> > ·¢ËÍʱ¼ä: 2009Äê11ÔÂ12ÈÕ 23:30
> > ÊÕ¼þÈË: mpich-discuss at mcs.anl.gov
> > Ö÷Ìâ: Re: [mpich-discuss] how to connect MPI_Send with CH3_isend
> > The best way to understand what happens is to step through the calls
> > with a debugger.  The channel is selected in the configure step, and
> > only that channel will be compiled, so there will be only one copy of
> > ch3_isend in the binary.
> > -d
> > On 11/12/2009 05:54 AM, hu yaohui wrote:
> >> hi guys!
> >>     Could someone tell me the detail calling flow from MPI_Send() to
> >> CH3_isend()?
> >>     How to control which CH3_isend() is called between sock,sctp and
> >> shm? thank you very much!
> > best
> >> wishes!
> >> loki!
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091113/d8547157/attachment.htm>
