[mpich-discuss] 答复: how to connect MPI_Send with CH3_isend
yaohui loki2441 at gmail.com
Fri Nov 13 01:29:42 CST 2009
Thank you very much!
	Finally I got a response!
I am doing some researches on adding HT(HyperTransport) into mpich2,I am
just wandering when we configure the mpich2 with
			./configure ¨Cwith-device=ch3:sock (ch3:nemesis)
that means we definitely select one network as the channel to communicate,
but if there are any possibilities that you can dynamic
control the network we use ,sometimes messages go through Ethernet,
sometimes go through IB. could you give me some materials
to understand what's the difference between ~/ch3/channel/sock
,~/ch3/channel/sctp ~,~/ch3/channel/nemesis/nemesis/net_mod/tcp_module
, ~/ch3/channel/nemesis/nemesis/net_mod/sctp_module,
~/ch3/channel/nemesis/nemesis/net_mod/ib_module
Thank you again!
Best Wishes!
-----ÓʼþÔ­¼þ-----
·¢¼þÈË: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.
anl.gov] ´ú±í Darius Buntinas
·¢ËÍʱ¼ä: 2009Äê11ÔÂ12ÈÕ 23:30
ÊÕ¼þÈË: mpich-discuss at mcs.anl.gov
Ö÷Ìâ: Re: [mpich-discuss] how to connect MPI_Send with CH3_isend
The best way to understand what happens is to step through the calls
with a debugger.  The channel is selected in the configure step, and
only that channel will be compiled, so there will be only one copy of
ch3_isend in the binary.
-d
On 11/12/2009 05:54 AM, hu yaohui wrote:
> hi guys!
>     Could someone tell me the detail calling flow from MPI_Send() to
> CH3_isend()?
>     How to control which CH3_isend() is called between sock,sctp and
> shm? thank you very much!
best
> wishes!
> loki!
> mpich-discuss mailing list
