[mpich-discuss] genvlist & map is not working in config file
abhishek pandey hipandey at gmail.com
Tue Nov 3 00:26:39 CST 2009
Hi ,
Thanks for making a ticket for this.
BTW, I hope this would also take care of the problem coming for "-map".
/*  -map Y:\\machine-1\abhishek\ won't work but -map Y:\\machine-1\abhishek
works. */
Abhishek.
On Tue, Nov 3, 2009 at 3:40 AM, <jayesh at mcs.anl.gov> wrote:
> Hi,
>  If you add quotes, the environment variable is set with the quotes. So
> "-genvlist" option should work with quotes.
>  However there is definitely a bug in the code since it does not escape the
> backslash ("\") character correctly (The quotes are escaped with backslashes
> & environment variables are passed to the process manager within quotes -
> resulting in the code that interprets commands with environment variables
> ending in backslashes as ending with a double quote.).
>  Thank you for reporting the bug.
> (PS: Look into http://trac.mcs.anl.gov/projects/mpich2/ticket/915)
> Regards,
> Jayesh
> From: "abhishek pandey" <hipandey at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Monday, November 2, 2009 1:33:41 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich-discuss] genvlist & map is not working in config file
> Ya, just now I did it with -map. But it is also not helping.
> Thanks,
> Abhishek
> On Tue, Nov 3, 2009 at 12:56 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Did you try adding quotes ("d:\mpi\")?
> Regards,
> Jayesh
> From: "abhishek pandey" < hipandey at gmail.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Monday, November 2, 2009 1:16:51 PM GMT -06:00 US/Canada Central
> Hi Jayesh,
> I found the reason behind this strange behavior.
> The config file
> -host localhost -genvlist CNTRL_MPI_DIR -p 8676 -wdir <Working DIR> -path
> <pathDIR> test.exe -mpion
> won't work if CNTRL_MPI_DIR is set with trailing backslash i.e.
> CNTRL_MPI_DIR=D:\MPI\.
> It works perfectly fine if it is set CNTRL_MPI_DIR=D:\MPI.
> Similarly, -map Y:\\machine-1\abhishek\ won't work but -map
> Y:\\machine-1\abhishek works.
> Now, the question is : Is this known behavior or a bug ?
> Thanks,
> Abhishek
> On Thu, Oct 29, 2009 at 8:55 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Try this config file and see whether the environment variable is set in the
> output.
> # Config file to test genvlist
> -genvlist CNTRL_MPI_DIR -n 1 cmd /c set
> Regards,
> Jayesh
> From: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> To: "abhishek pandey" < hipandey at gmail.com >
> Sent: Thursday, October 29, 2009 10:21:03 AM GMT -06:00 US/Canada Central
> Hi,
> That is strange. It works fine on my Win XP machine.
> Which version of MPICH2 are you using ? What is the version of windows that
> you are using ? Also I noticed that in the failure case you are launching
> test.exe and in the successful case you are launching product.exe (Can you
> try the same executable for all your tests ?).
> Regards,
> Jayesh
> Sent: Thursday, October 29, 2009 10:08:46 AM GMT -06:00 US/Canada Central
> Hi,
> genvlist is working on command line. Also command "set C" on shell shows
> the value of CNTRL_MPI_DIR & CNTRL_MPI_OUT.
> BTW, I have not tried -map command without config file.
> Thanks,
> Abhishek.
> On Thu, Oct 29, 2009 at 8:34 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Does it work when you enter the command in the command line (without a
> config file) ? Have you set the environment variable CNTRL_MPI_DIR (Type
> "set" at the command prompt to see the list of environment variables set) in
> the shell environment used to launch the job ?
> Regards,
> Jayesh
> Sent: Thursday, October 29, 2009 9:59:12 AM GMT -06:00 US/Canada Central
> Hi Jayesh,
> This is my config file.
> In this sample MPICH2 does not launch the test.exe.
> -host localhost -genvlist CNTRL_MPI_DIR,CNTRL_MPI_OUT -p 8676 -wdir
> <Working DIR> -path <pathDIR> test.exe -mpion -controller
> -host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> test.exe
> -mpion -worker
> -host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> test.exe
> -mpion -worker
> However this is working :
> -host localhost -env CNTRL_MPI_DIR d:\mpi -p 8676 -wdir <Working DIR> -path
> <pathDIR> product.exe -mpion -controller
> -host localhost -p 8676 -wdir <Working DIR> -path <pathDIR1> product.exe
> -mpion -worker
> -host localhost -p 8676 -wdir <Working DIR> -path <pathDIR2> product.exe
> -mpion -worker
> In this sample mapping is not done on all the nodes. The workaround : I
> have to map network drive first manually and then use -mapall option on
> controller.
> -host localhost -map z:\\abhishekp-xp\mpi\ -p 8676 -wdir <Working DIR>
> -mpion -worker
> -mpion -worker
> Am I missing something in config file.
> Thanks,
> Abhishek
> On Thu, Oct 29, 2009 at 8:11 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Can you send us a sample config file that does not work ?
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, October 29, 2009 5:26:22 AM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] genvlist & map is not working in config file
> Hi,
> On windows, I tried to use genvlist and map in mpi config file. (
> mpiexec.exe -configfile <config file>).
> But it is not working. Am I missing something ?
> However -env and -mapall options are working in configfile. Also, I always
> have to set environment variables in configfile. Is there a way to just use
> the environment variables once it has been set on command line or in
> my-computer properties ?
> Thanks,
> Abhishek
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091103/70994e5b/attachment.htm>
