[mpich-discuss] Invalid error code (217112352) (error ring index 30invalid)
Ashley Pittman ashley at pittman.co.uk
Mon Nov 2 12:38:02 CST 2009
It could be this one...
https://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/trunk/src/mpi/errhan/errutil.c#L1421
Ashley,
On Mon, 2009-11-02 at 12:32 -0600, Rajeev Thakur wrote:
> This doesn't look like an error message from MPICH2.
> Rajeev
> > -----Original Message-----
> > From: mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tim Stitt
> > Sent: Monday, November 02, 2009 2:59 AM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: [mpich-discuss] Invalid error code (217112352)
> > Hi all,
> > I have a MPI code that runs to completion but generates the
> > following
> > message at the end of every run (note: the numbers change
> > from run to
> > run):
> > Invalid error code (217112352) (error ring index 30 invalid)
> > The output from the code seems to suggest that it is executing
> > correctly so I was hoping if someone could explain why such a
> > message
> > is appearing and how I can remove it.
> > Thanks in advance for any assistance,
> > Regards,
> > Tim.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Ashley Pittman, Bath, UK.
Padb - A parallel job inspection tool for cluster computing
http://padb.pittman.org.uk
