[mpich-discuss] Had a failure in configuring mpich
chan at mcs.anl.gov chan at mcs.anl.gov
Mon Nov 2 08:55:26 CST 2009
You need to do "make install" after "make".  Also don't run
mpich2 as root until you can run it as a regular user.
If you need to run mpich2 as root, be sure to read the section
in install guide, /apps/mpich2/share/doc/install.pdf,
about running mpich2 as root....
A.Chan
----- "Miller Joshua J" <MillerJoshuaJ at JohnDeere.com> wrote:
> I am doing the install in prod.
> Nothing is showing up in my /apps/mpich directory?
> I did the prefix flag in the configure command.
> Please advise.
> Best Regards.
> Joshua Miller
> -----Original Message-----
> From: Anthony Chan [mailto:chan at mcs.anl.gov]
> Sent: Monday, October 26, 2009 10:51 AM
> To: Miller Joshua J
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Had a failure in configuring mpich
> "make ?" means you want to execute target "?" in the Makefile.
> As the error message indicates, there isn't a "?" target in mpich2's
> Makefile.  Just do "make 2>&1 | tee m.txt" on your terminal.
> > root at llabhpc3 /scratch/jm70674a/FORTE/tmpbuild# make ?
> > make: *** No rule to make target `?'.  Stop.
> > Best Regards.
> > Joshua Miller
> > From: chan at mcs.anl.gov [mailto:chan at mcs.anl.gov]
> > Sent: Monday, October 26, 2009 10:43 AM
> > To: Miller Joshua J
> > > That was successful.
> > > The next step is failing now.
> > > I cannot find "make"
> > any error message from make ?
> > Send us the make output, m.txt.
> > A.Chan
